The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Jul 27, 2021 at 11:33 AM
    #4081
    tacowiz
    tacowiz Well-Known Member
    Wing
    Central Valley
    2021 Tacoma OR DCLB Army Green
    PrinsuDesignsStudio Cascadia Vehicle Tents Method Wheels (704) Falken WildPeaks
    Theres like $300k worth of campers stack on top of each other lol
  2. Jul 27, 2021 at 11:34 AM
    #4082
    tacowiz
    Wing
    Central Valley
    It'd be rad if SP would sell a camper with no tent. Or a option for us to take the tent portion off and cap the top while we are not using it.
  3. Jul 27, 2021 at 12:01 PM
    #4083
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Why? It adds very little extra weight and the tent is encapsulated from the cargo area below when closed up. Making a “cap” wouldn’t make it much shorter, so it’s not like you’ll “fit in the garage” better.
    justrussell and tacowiz[QUOTED] like this.
  4. Jul 27, 2021 at 12:16 PM
    #4084
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I would think that's no longer a camper, rather a canopy, and there are lots of companies making those, as well as wedge tents that fit ontop of canopies.
    tacowiz[QUOTED] likes this.
  5. Jul 27, 2021 at 1:11 PM
    #4085
    gnardoggie
    gnardoggie Well-Known Member
    I've seen a gofast proto floating around that's basically their canopy with their tent on a rack above.
    justrussell and tacowiz like this.
  6. Jul 27, 2021 at 6:38 PM
    #4086
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    His IG is _jim_bob if anyone wants to see it.
    tacowiz and gnardoggie[QUOTED] like this.
  7. Jul 27, 2021 at 7:03 PM
    #4087
    bfife
    bfife Active Member
    Barney
    2019 DCLB Concrete
    hope that gray one in the back is mine
  8. Jul 28, 2021 at 9:17 PM
    #4088
    tacomeg
    tacomeg Well-Known Member
    Megan
    Vancouver, WA
    2008 Tacoma DCLB TRD Sport
    Installed the Gzila brackets today with the t-nuts I got from Fastenal. I had to buy longer 1/4-20x3/4 socket head screws. The t-nuts worked okay, but I'd order some others next time. They only fit in a vertical orientation. I'm not sure if that's the correct way and maybe I ordered the wrong size after all, but it worked. A couple people mentioned ordering from McMaster, did those work out? If so, do you have a link or part number?IMG_1223.HEIC.jpg IMG_1296.jpg
    Jessee26, econwatch and Mark77 like this.
  9. Jul 28, 2021 at 9:54 PM
    #4089
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Let me dig mine up. I am lacking on that. I ordered 4 different ones 1 at least that was listed then some other ones that seem to recess better and some that were flat like this. Also they use 8mm to keep it consistent with the rest of the X1.
  10. Jul 28, 2021 at 9:55 PM
    #4090
    nudavinci64
    Robert
    whats the part again for this? I was waiting for the other one but this seems to be working out for folks.
  11. Jul 29, 2021 at 9:57 AM
    #4091
    tacomeg
    Megan
    Vancouver, WA
    Just wondering what t-nuts you ordered from McMaster Carr that are 14-20 or smaller? I need to install some other things. No big deal though if you don't have them handy. Like you said, I wanted to use 8mm to keep it consistent with SP, but the screws were too big to fit in the GZila brackets. I have a bunch of M8 t-nuts that worked out great for other things . . .
    Probably just easier to grind down GFC t-nuts like others have done for anyone that is still planning on getting these. I just don't have a ton of tools here.
  12. Jul 29, 2021 at 10:09 AM
    #4092
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So what do we need? Custom sized T nuts with M8x1.25 threads? This would allow for general fitting of mounts right.. and match the rest of the camper.. Plus used for the below..
    Then also a custom part to bolt to said T nut with the angled bore in it for the rear awning poles?
    Just trying to gather info to see what I could come up with for a solution for everyone. Sold as a kit (Custom T Nuts and Mounts with hardware) and or a bulk kit of the Custom T nuts for general use.
  13. Jul 29, 2021 at 11:03 AM
    #4093
    gnardoggie
    benches are wrapped
    Kbattlefield, tacomeg, VE7OSR and 7 others like this.
  14. Jul 29, 2021 at 11:04 AM
    #4094
    gnardoggie
    so the hinges on the back door are designed to fit an insert for the poles - maybe you can use that somehow instead of mounting to the extrusion?
    tacomeg likes this.
  15. Jul 29, 2021 at 11:22 AM
    #4095
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    They are? Oh. I didn't know.
  16. Jul 29, 2021 at 2:50 PM
    #4096
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Curious about this too. Sent Josh an email. Any pics?
  17. Jul 29, 2021 at 2:59 PM
    #4097
    gnardoggie
    nope - it's on the list of accessories, hopefully sooner than later but who knows. there are a lot of ideas in the pipeline, but they need to work through the orders pending first in order to free bandwidth to work on the rest of the add-ons.
  18. Jul 29, 2021 at 3:07 PM
    #4098
    econwatch
    Utardia/Kanook Eh
    Naranja 7545
    Where is this list? Searched through the FAQ page and couldn't find anything other than basic hinge info.
    https://www.superpacificusa.com/faq-page
    Thanks in advance.
    Edit: ok, after reading your edit, thinking you meant "planned list of accessories" when I interpreted there was an actual published list that I couldn't find.
  19. Jul 29, 2021 at 3:09 PM
    #4099
    gnardoggie
    the list is in the brains of the team at SP :)
    "Do you make any accessories:
    Not yet, but we have big plans. As we launch Super Pacific to the adventurous public, we are focused on delivering the highest quality of production on our Switchback X1 units with short turnaround time being our top priority. We have big plans for accessories that are focused on getting the most out of your camping endeavors, that we will have more info on later in 2021. If you want to stay up to date on all the latest company info and product releases, follow us on Instagram @SuperPacific_USA"
    econwatch[QUOTED] likes this.
  20. Jul 29, 2021 at 3:31 PM
    #4100
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    When i talked to them and placed my order, the coolest thing i was told is that any of the options they offer will work on the original camper design. So if they end up making it more roomy, an older camper can use this option. Very cool and smart idea.
