The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Sep 13, 2021 at 8:07 PM
    #4561
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Unfortunately that's what happens when you create a bolted connection using stainless hardware without adding lubricant between the threads.
    PS: I will be swapping my hardware out for non stainless. When I adjusted mine, they were very tight, like a cross thread feel for the same reason. Even though they were installed with a lubricant .
    It's just very very hard to remove the mounting on first gen so I'm dreading it.
  2. Sep 13, 2021 at 8:09 PM
    #4562
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yah I picked up some new ones and was going to do that.
  3. Sep 13, 2021 at 8:11 PM
    #4563
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    Yea, I just saw that on the website. I have #18 and I’m pretty sure mine are plexiglass, I’ll check tomorrow.
    My leer camper before this was plexiglass on all 4 sides, not sure what the benefits of glass would be in a camper anyway. But if the website says glass I agree it should come with glass.
  4. Sep 13, 2021 at 8:24 PM
    #4564
    nudavinci64
    Robert
    Makes sense I always thought the leer was glass but maybe it wasn’t.
  5. Sep 13, 2021 at 8:27 PM
    #4565
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    I guess I should add, like Frenchee, I’ve got a 1st Gen, and the 4 bolt mount through the bed rails did surprise me. I was told when I had a Flippac that bolts would likely shear and that clamps had some needed flex, so the SP bolts have me worried. I think the inner lip helps but all that weight shifting on 4 bolts seems like a design afterthought. I agree with the general topic that the way it’s attached needs improvement. Not sure exactly what can be done.
    frenchee likes this.
  6. Sep 13, 2021 at 8:34 PM
    #4566
    nudavinci64
    Robert
    Yah def interesting. I would look at other brands and see if it can be adopted
  7. Sep 13, 2021 at 9:51 PM
    #4567
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    My flippac was bolted through the bed on my 1st gen.
    I replaced those with giant GCI clamps, I forget which model.
    only one fiberglass shell I had (SnugTop) had “J-bolts” around the bed lip. All others are a clamp that puts pressure on the same surface and uses that tension to keep the top from moving.
  8. Sep 14, 2021 at 8:18 AM
    #4568
    tacomeg
    tacomeg Well-Known Member
    Megan
    Vancouver, WA
    2008 Tacoma DCLB TRD Sport
    Here are some photos. I've been debating if our has shifted, but I don't think so.
  9. Sep 14, 2021 at 8:29 AM
    #4569
    nudavinci64
    Robert
    Based on yours which I was curious you can see mine has shifted forward. I need to look at the front lip when I have more time later.
    9BED7A68-499D-4925-B0AE-785981F47C56.jpg FC7EC2B6-CE9B-4861-9EA8-D9371E9C81CF.jpg
  10. Sep 14, 2021 at 8:32 AM
    #4570
    frenchee
    Oceanside CA Area
    To be fair, when they installed ours, there was no exact method of locating front to back, it was eye balled, so there could in general be variation.
    tacomeg likes this.
  11. Sep 14, 2021 at 8:49 AM
    #4571
    nudavinci64
    Robert
    True I showed the last pick where I installed an extra seal which now has a gap. I need to go hack and look at some photos but it’s def gotten closer as my wired that run between are smashed in there. I’d also be worried about the rear glass. Other brands I’ve seen the canopy hit and shatter. Not really it moving but bed flex when it’s too close.
  12. Sep 14, 2021 at 9:15 AM
    #4572
    gnardoggie
    gnardoggie Well-Known Member
    Honestly I'm more for the plexi window than glass. Less likely to shatter and also way harder to just break the glass and get in usually (plus I'd assume plexi is lighter)
    EnBoo and Mark77 like this.
  13. Sep 14, 2021 at 9:22 AM
    #4573
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lighter for sure and easier to replace. But I can only imagine the glare/lack of visibility between 2 sheets of it.. especially after some time in the sun and some scratches.
    @RangeRick about the Expo.. I don't even know if SP will be there.. but regardless, if you go.. I'll drive up so I can check out a SP in person. I was hoping to have mine in time for Expo... Guess not.
  14. Sep 14, 2021 at 9:25 AM
    #4574
    gnardoggie
    Fair - I've got both front and rear windows and don't even use them anymore. Even with glass there was plenty of glare and once I finished my buildout it was sort of pointless to even try. Now I'm considering a digital rearview mirror ha!
  15. Sep 14, 2021 at 9:35 AM
    #4575
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I definitely will be doing the same. Found the one I want on Amazon. More so to ditch the factory rearview camera and use that instead for a rear camera. I know it'll be minimal visibility regardless.. but I just want glass. Personal preference I guess
  16. Sep 14, 2021 at 9:42 AM
    #4576
    gnardoggie
    which mirror you looking at? I'm struggling with the true need - I have the convex blind spot mirrors that work well enough - and I'm starting to lose motivation to run wires etc anymore ha!
  17. Sep 14, 2021 at 9:49 AM
    #4577
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    AKASO DL12 2.5K Mirror Dash Cam Voice Control 12" Touch Screen Front and Rear Dual Dash Camera for Cars Night Vision Backup Camera with Sony Starvis Sensor GPS G-Sensor Parking Assistance https://www.amazon.com/dp/B0855GMKMD?_encoding=UTF8
    I have a couple ideas for trail cameras as well on top of this. I want to utilize this for my main rearview and backup (plus the dash cam features).. and then wire in a front facing camera for break over views on my head unit.
  18. Sep 14, 2021 at 9:57 AM
    #4578
    gnardoggie
  19. Sep 14, 2021 at 10:05 AM
    #4579
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh damn. Lol. That is nice. I don't need all the Android stuff tho. I have an Android Car play headunit now for music and nav. Plus my Garmin for off grid.
  20. Sep 14, 2021 at 10:17 AM
    #4580
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    This question may have been already asked, but I would like to know: Will the Super Pacific Camper clear a Uptop Overland roof rack on a 3rd gen?
