The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Feb 13, 2022 at 10:13 AM
    #5761
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yeah, sure for Lil' Buddy, Mr Buddy and similar where you're burning and exhausting into your cabin. These will also kill you with Carbon Monoxide and/or fire if it gets knocked over and sets your gear on fire.
    This is important to distinguish from a much nicer and more expensive heater that only transfers the heat into your sleeping area and exhausts to the outside, like @evdog has.
    Some of the "expensive", safe and non-humidity inducing options:
    • Propex
    • Dickinson Newport P12000 Propane Fireplace (Evdog has this one)
    _kmg_, J4YD33, gnardoggie and 2 others like this.
  2. Feb 13, 2022 at 10:16 AM
    #5762
    BudLoomis
    BudLoomis Well-Known Member
    Colorado
    2018 TRD Off-road
    Toytec Aluma Series 2.0 (2.5" x 3.5" lift), JBA UCA, Deaver stage 3 Leaf pack, CMC, Viair OBA set-up, KBVOODOO mid rack, Roofnest Condor RTT, CaliRaised Premium Roof Rack w/ 360 lighting, Custom Bed box w/ camp stove built in
    I totally agree, but the person trying to use a cheap $20 space heater is not going to be able to afford a Dickinson for $1200+
    You are correct though.
    Ridgewalker1 likes this.
  3. Feb 13, 2022 at 10:20 AM
    #5763
    JasonLee
    15 TRD OffRoad
    The cheapest is going to collect 6V old flooded lead acid car batteries for free/cheap from a golf cart, run them in a mix of parallel and series and then that $25 electric blanket. You can run them all night off a bed full of golf cart batteries.
    BudLoomis likes this.
  4. Feb 13, 2022 at 10:21 AM
    #5764
    gnardoggie
    gnardoggie Well-Known Member
    yea, that's the spot on summary.
    in short, you dont need "forced air" heat per se unless youre hanging out inside the camper. I've found that a 12v blanket and good bedding go a long way and don't use much power.
    if you want something to heat the air, a diesel heater or propex are great. I went with the dickinson fireplace as to not use any draw off of my aux battery sans a small computer fan for circulation. if you live in a boat-heavy area like the pnw you can sometimes find the dickinsons for a decent price. I think i paid $400 for mine. all three of those options are externally vented and have an external air intake and thus don't produce moisture in the heated area if installed right.
    from both my experience and some anecdotes from others you'll get approx 20-25F increase in inside temp vs ambient from any of those three heat sources, unless you insulate. Diesel might push out slightly more heat than that but you do also have to deal with the noise etc and it will most likely be running at full blast to get you there.
    any "space heater" is going to be super inefficient and not run for very long at all, even with a huge battery bank. the heat is basically coming from a specifically designed inefficient electrical circuit creating the by-product of heat - think like when you wire something poorly and the wires start to get warm but on a more strategic scale. now if youre on shore power, then go full in with an electric heater - they work great as long as the truck itself isn't the power source.
    priorities should really be ordered as below if you want to go down the winter adventure:
    good bedding
    12v blanket (i have a timer one that only runs for 45min at a time)
    insulation
    more robust heat source (externally vented) + aux battery
    justrussell, J4YD33 and Ridgewalker1 like this.
  5. Feb 13, 2022 at 10:21 AM
    #5765
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    LOL!
    JasonLee[QUOTED] likes this.
  6. Feb 13, 2022 at 10:24 AM
    #5766
    gnardoggie
    maybe, maybe not - but chinese diesel heaters are close to $100 these days and paired with a jackery or goal zero you should be able to get a night or two of comfort out of one.
  7. Feb 13, 2022 at 10:31 AM
    #5767
    gnardoggie
    That's partly why I went with propane as well, plus I carry a propane fire pit in the rig as well so I can use it for both.
    Dickinson doesn't require electricity but it helps, but you do have to cut a hole in your camper ha! Either way the electricity draw is pretty minimal relatively speaking for the Propex or diesel units - most of the draw is on startup to fire the burners up, beyond that it's a glorified computer fan pushing the air - maybe 5amps max.
    I get 5-6 nights of heat out of $10 of propane via an 11lb tank. Propex heaters are slightly less efficient but not all that different.
  8. Feb 13, 2022 at 10:31 AM
    #5768
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    A badass 0 degree two person bag that works just fine 90% of the time.. and a propane heater to take the chill out when really needed. Just be smart with the heater. My wife and I have ran this combo for years. Simple and effective.
    Ridgewalker1, JasonLee and gnardoggie like this.
  9. Feb 13, 2022 at 11:01 AM
    #5769
    MapJunkie
    MapJunkie Well-Known Member
    Washington
    2015 Tacoma OffRoad w/ Drifter
    I disagree that propane is an expensive fuel source. I used to have a Mr. Buddy, but the CO detector went off constantly unless we had the windows open, defeating the purpose. So, I installed a Propex to use in my wedge camper. We do have an insulation package, which allows the temps to rise 5-10 extra degrees bs non-insulated.
    I went camping last weekend in Eastern Washington where the temps were low 20s at night and 40 during the day. We put the Propex on 55 deg at night and 65 deg. Since it was winter, we left the heater continuous for two nights and all the time during the day. So, 40 hours of heat.
    After the trip, I refilled my propane tank for $3.50, just under a gallon. I am not convinced the Diesel heaters are any more efficient or cheaper than that.
  10. Feb 13, 2022 at 11:05 AM
    #5770
    BudLoomis
    Colorado
    2018 TRD Off-road
    You're right I guess I was only referring to cheaper propane heaters like Mr buddy that takes a 1lb cylinder and costs $4-6. But if you buy a nice propex or Dickinson heater you can definitely run them off an 11lbs propane take affordably.
  11. Feb 13, 2022 at 11:18 AM
    #5771
    Taco_gloom
    Taco_gloom Member
    2020 TRD OFFRD
    Curious how people have been using their molle panels..
    Anyone wish to share their setups?
    Juliemtbnski likes this.
  12. Feb 13, 2022 at 11:21 AM
    #5772
    gnardoggie
    fwiw you can run a Mr Buddy off of a larger refillable tank too
  13. Feb 13, 2022 at 1:20 PM
    #5773
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    Haha, not me! I'm still on step 1 in @gnardoggie list. So far so good down to low 20's. No hardcore winter camping here though, just shoulder season at mid to high-ish elevations that can get chilly.
    Ridgewalker1 and gnardoggie like this.
  14. Feb 13, 2022 at 1:35 PM
    #5774
    JasonLee
    15 TRD OffRoad
    Maybe that was a nudge for you getting a Dickinson fireplace…
  15. Feb 13, 2022 at 3:04 PM
    #5775
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    Thanks for the informative discussion. 12 v blanket sounds good, also may want a solution to warm up interior in the morning while making coffee, or if inside in cold rain/snow.
  16. Feb 13, 2022 at 6:33 PM
    #5776
    evdog
    San Diego
    2019 DCLB TRD OR
    Haha, maybe!
    A heater isn't really worth it for me right now, not enough time spent in cold weather and when I do I can get by with lots of layers, blankets and a warm sleeping bag. Lack of insulation in the camper/tent also makes it seem kinda pointless. It would help if hanging out inside but usually just getting out of the wind makes the temps bearable enough. Pics are from last weekend when it got real windy after dark and temps dropped. I usually sit outside at night.
    I'd be interested in a heater if its power source could also be used for a water heater, realistically that means propane. Might look into it if my electric water heater doesn't pan out.
    pdxchevyguy, Ridgewalker1 and J4YD33 like this.
  17. Feb 14, 2022 at 6:41 AM
    #5777
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    Lots of great heater discussion. I pick up my camper in a week(!) and do a ton of high altitude (>10k) skiing and camping in CO. I plunked down the cash for a propex HS2000, will be running it through the passenger bedside cubby off a full size propane tank. With the megamat 10 and warm sleeping bags I'm not super concerned about sleeping in the cold, more to make morning and evenings a lot more pleasant instead of being stuck inside your sleeping bag. I'll be camping and hitting resort and backcountry ski areas on my way back from Portland to CO to test things out.
  18. Feb 14, 2022 at 8:10 AM
    #5778
    JasonLee
    15 TRD OffRoad
    Hopefully you have a way to keep your propane tank warmer. I had issues with an almost full 20lb tank in Ouray fueling my 2-burner stove.
    Pv=nRT states that pressure (very important to propane) is relative to temperature.
    Also, the temperature that propane liquifies varies with the pressure.
    I found out the hard way about devices designed to burn propane in a gaseous state vs liquid propane.
    Short story, you may want to keep your propane tank inside the truck bed and definitely not sitting on the cold ground outside.
  19. Feb 14, 2022 at 8:39 AM
    #5779
    Hikerbox
    2015 SR5 Access Cab
    Definitely something I'm hoping isn't a deal breaker!
    Just to nitpick, Pv=nRT is a simplified equation for ideal gases that don't change states. The issue with propane is it takes extra energy to boil a liquid. The liquid propane boils and draws heat from outside, icing over the tank. The same thing happens with liquid nitrogen exposed to atmospheric pressure since its boiling point is very low at that pressure but high when it's in a pressurized container.
    I've also found that 90% of my cold weather propane stove problems are actually related to the pressure regulator tripping when opening the tank valve too fast. Once the tank ices over from the state change of the propane then you are dealing with cold weather problems. I'm hoping the larger tank kept in the bed will have enough juice to warm itself up before icing up. I may end up having to run the heat overnight when the low is extra cold just to keep the tank warm for the morning.
  20. Feb 14, 2022 at 1:57 PM
    #5780
    urshur
    urshur Well-Known Member
    2020 TRDOR ACLB
    An update on my water intrusion issue for anyone who's interested - early returns on sealing the interface between the white panel and the black extrusion around the roofline on the outside of the camper seem promising. It's raining a decent amount today here, and when I opened up the camper just now it was bone dry. I spoke with SP a bit about the issue, and it seems like @gnardoggie 's hunch about roof panel tolerances may be correct. At the very least, SP is going to be awesome about it and take care of us however they need to. They've since remedied the issue (if that's what it was in my case) on new models, so new buyers shouldn't be concerned about it.
