The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Mar 28, 2022 at 6:10 PM
    #5961
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
    Well I’m glad you are improving enough you can finally get it!
    Mark77[QUOTED] likes this.
  2. Mar 28, 2022 at 6:32 PM
    #5962
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Thank you. Im hoping the paranoia goes away soon. Always seem to be waiting for something else to go wrong.
    Ridgewalker1[QUOTED] likes this.
  3. Mar 28, 2022 at 7:32 PM
    #5963
    Cathugra.mo
    Cathugra.mo Member
    Ontario Canada
    2022 SCLB TRD Off Road
    Incredible rig.
    My order in a Super Pacific is in! I am hyped!
    Been doing some reading on this thread, have gotten back a couple dozen pages, and I'm picking up bits and pieces of info. Some people put leaf stiffeners, some don't. I've seen some mention of airbags online in various places.
    Is there any general sort of consensus on what is a good idea to do to a stock suspension on a 3rd Gen 6ft bed?
  4. Mar 28, 2022 at 7:43 PM
    #5964
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If you don't carry much gear, don't have a motorcycle on a hitch or multiple bikes on a bike rack, stock springs will work ok on the road. At minimum you'll want a cheap add a leaf (and probably need longer U-bolts).
    If you plan on having a fridge/cooler, propane tank, gear, water, and more stuff, an add-a-leaf will last a year or so. You'll likely be bottoming out off-road. Air bags would be fine if you stick to pavement and gravel roads.
    If you off-road, just save yourself the headache and time wasted with the stock suspension and just order replacement leaf springs for your intended weight. Dobinsons are a good value.
  5. Mar 28, 2022 at 10:31 PM
    #5965
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    +1 seconded
    @Cathugra.mo
    3rd gen?
    Also consider the longer piston bilstein 5100 as entry to suspension world.
    https://www.amazon.com/gp/product/B00BYNJ93Q/
    The Dobinson's L59-111-R (or 112) lifted my '17 DCSB enough to warrant them.
    You'll also need to detach the e-brake cable stay and get a stay extension as it will be a tighter path to the wheel.
    I wouldn't do ride-rites again. They were a stop-gap at the time.
    ps - suggestion, add your rig / state (guessing MO?) to your profile. Will help with any advice requested/given.
    Cathugra.mo and Ridgewalker1 like this.
  6. Mar 29, 2022 at 7:03 AM
    #5966
    truello
    truello Well-Known Member
    Issaquah, WA
    2021 Tacoma TRD OR DCLB
    I can measure in a bit. FWIW the Prinsu racks fit under the overhang on 3rd gens with plenty of space to spare, though obviously the bit under is not very useful.
  7. Mar 29, 2022 at 7:49 AM
    #5967
    truello
    Issaquah, WA
    I get 34" from the top of the windshield to the front of the camper, along the driver side rain gutter. 8" from between the two doors. The angle of this photo is not great but it was right at 8".
    EVSTAXI likes this.
  8. Mar 29, 2022 at 8:01 AM
    #5968
    JasonLee
    15 TRD OffRoad
    Will you be going off road with this truck? You are likely going to start seeing witness marks on the top of the rack where the camper overhang touches it when the Tacoma frame flexes and the camper is bouncing up and down...
  9. Mar 29, 2022 at 8:52 AM
    #5969
    truello
    Issaquah, WA
    Nothing very aggressive. There's a good inch of clearance, which I'm sure a rough bump could flex enough but that's not really why I'm in this so I don't anticipate it happening much if at all.
    Mark77 likes this.
  10. Mar 29, 2022 at 10:38 AM
    #5970
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Super clean. Is it bolted through?
  11. Mar 29, 2022 at 11:55 AM
    #5971
    frenchee
    Oceanside CA Area
    Duuudee.... I love the propane idea. Thanks
  12. Mar 29, 2022 at 11:58 AM
    #5972
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    I added a license plate frame backup camera when I upgraded my radio to one with a 7” screen and Apple Car Play (different story, but on the 1st Gen the screen is so low and reflects so much light that I wish I had gotten one that tilts up, or had gotten a different setup). ANYWAY turned out my backup camera was blocked by my bike rack so I moved it up to the third stop light. I cut the license plate frame off except for a small portion, removed the third light, ground a channel into the plastic wire protector behind the light, routed the wires inside, and reconnected the light with vhb tape. Total pia. Notice in the photo that I screwed up the light lens by trying to take off the existing tape with some acetone. Then I find that my backup camera has built in guidance lines that can’t be turned off. Bottom line, wish I’d gotten a different camera in the first place. But it is very nice to have that top down view when backing in various circumstances. Edit: AND I’m not taking up any room on the t-tracks, don’t have to route wires inside from there, etc.
  13. Mar 29, 2022 at 4:32 PM
    #5973
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    :bowdown:
    This is amazing.
  14. Mar 29, 2022 at 5:30 PM
    #5974
    Mark77
    Mark
    Nothing yet
    So, im a douche and im asking. But some of you have roof rack/cross bars for the super pacific. What did you all get? I know im going to need some for my trip home, my tonneau cover will need to go up there. I wont drive cross country with all my gear in an open bed, so ill leave the cover on till i arrive, then remove it.
    Going_Wilder likes this.
  15. Mar 29, 2022 at 5:37 PM
    #5975
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I drove up in November and just covered everything in the bed with a tarp. Just an idea.
  16. Mar 29, 2022 at 5:39 PM
    #5976
    Pagan220
    Pagan220 Well-Known Member
    Brent
    2021 DCLB OR
    I just left my tonneau cover there. It was $200 a year ago so I gave it to an employee there. I didn’t need it anymore. I just built up a roof rack with three cross bars using 8020. Total $300.
    Ridgewalker1 and frenchee like this.
  17. Mar 29, 2022 at 7:31 PM
    #5977
    couplefunones
    couplefunones Well-Known Member
    Thx folks and @frenchee yep its bolted to the truck bed. The SP team did say they were working on new bed clamps though.
    @Pagan220 any chance you have your 8020 roof rack parts list still? I’m in the market for a roof rack and figure others will want to copy too.
  18. Mar 29, 2022 at 8:19 PM
    #5978
    Pagan220
    Brent
    2021 DCLB OR
    Had the bars cut at 56.5” and the ends tapped for 5/16 x18. Mount the side plates on the X1 then bolt the bar across. I did 3 bars because I’m mounting a solar panel but I also wanted to carry a ladder/ boards/ canoe etc at times. The space between the two solar panel bars would be too short. I got the idea from another member on here.
    Taco_gloom and couplefunones like this.
  19. Mar 29, 2022 at 8:20 PM
    #5979
    Pagan220
    Brent
    2021 DCLB OR
    When I get it put together I’ll post pics.
    Tacomags and couplefunones like this.
  20. Mar 29, 2022 at 8:54 PM
    #5980
    truello
    Issaquah, WA
    Maybe you could find a buyer for your tonneau cover in Portland
