The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Sep 28, 2022 at 12:14 PM
    #6801
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Since you are a 3rd gen it may not be an issue for you. It depends how far down it sits. It would sit lower so likely cause impact with the prinsu. For the 2nd gen it it front and bottom but mostly front. It is one piece so you ould not be able to use any of it on a 2nd gen if you retain the rack or do not modify it. I have my front baja linkables and side lights so likely ill go under the knife again.
    EnBoo[QUOTED] likes this.
  2. Sep 28, 2022 at 2:35 PM
    #6802
    nudavinci64
    Robert
    pretty common when its raining maybe not as bad on 3rd gens but it drips all over your seat when the door is open. common issues with Vagabon and GFC too.
  3. Sep 28, 2022 at 2:38 PM
    #6803
    ChrclTaco
    ChrclTaco Active Member
    Tacoma DCLB OR
    I'm in a 3rd gen in the pnw and this issue almost caused the end of a relationship!
  4. Sep 28, 2022 at 8:18 PM
    #6804
    nudavinci64
    Robert
    Anyone using scepters or other water there is a guy that made a magnetic mount for the Amazon water faucets.
    IAlso here I was running off a water bottle but had an adapter that screws onto a 5 gallon Scepter but he is working on a few other mounts for the bottle end. If anyone is interested PM me and I can see how to connect you. If you’re on IG that’s best contact method. I’ll grab another that shows the other side that connects later if interested.
    Ridgewalker1 and 99ranged like this.
  5. Sep 29, 2022 at 5:37 AM
    #6805
    DividedSky
    DividedSky Well-Known Member
    Jeff
    2018 TUNDRA
    Mid-Travel ADS Shocks, MCM UCA, Full Armor
    With the X1 being made out of Aluminum, I take it that these wouldn't magnetically stick to our toppers?
    Mark77 likes this.
  6. Sep 29, 2022 at 5:59 AM
    #6806
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Ah, no.
  7. Sep 29, 2022 at 8:19 AM
    #6807
    nudavinci64
    Robert
    I plan to use it on my rear swingout. Some folks have steel plates for magnetic things.
  8. Sep 29, 2022 at 9:23 AM
    #6808
    DividedSky
    Jeff
    2018 TUNDRA
    Are the SP Molle panels magnetic?
  9. Sep 29, 2022 at 9:49 AM
    #6809
    Mark77
    Mark
    Nothing yet
    ALUMINUM
    nudavinci64 likes this.
  10. Sep 29, 2022 at 12:33 PM
    #6810
    Mark77
    Mark
    Nothing yet
    Ive used suction cups too, held my shower nozzle.
  11. Sep 29, 2022 at 12:37 PM
    #6811
    nudavinci64
    Robert
    nice yah this worked with the electric 5 gallon pumps and a local guy was making it. Less about shower and more for water use. If anyone is interested Ill pass you the info.
  12. Sep 29, 2022 at 8:23 PM
    #6812
    tacomavan
    tacomavan Well-Known Member
    Oregon
    anyone fashioned a bracket to hold a small camp table under the cab over out of c-channel or something yet?
    Tacomags likes this.
  13. Sep 29, 2022 at 10:06 PM
    #6813
    Tacomags
    Tacomags Well-Known Member
    Austin, Texas
    2021 TRD OR DCSB 4x4
    17" 4Runner wheels, 32" Nittos, Dobinsons IMS, RRW sliders, Total Chaos bed stiffeners, custom seat delete, Decked, Super Pacific X1
    Was thinking of this recently. Front runner has something like this for their racks, I'd like to do something similar.
  14. Sep 30, 2022 at 12:08 AM
    #6814
    nudavinci64
    Robert
    if you are not running a rack under your X1 that may be a good use of space. Another setup I saw that was genius was when they put in bed plate in their bed they mounted it 1" or 3/4" raise. Something alone those lines and slide the table under neath the floor plate. I think it may have been the front runner table too but that was a nice use of space and did not use up much space at all. I would tag him but not sure his TW name.
  15. Sep 30, 2022 at 6:45 AM
    #6815
    Pagan220
    Pagan220 Well-Known Member
    Brent
    2021 DCLB OR
    I just Velcroed my pump to a spot on my x1. Works well.
    BrashBrusier likes this.
  16. Sep 30, 2022 at 7:55 AM
    #6816
    tacomavan
    Oregon
    what do people typically use for a bed plate, raised or not, if they are going to do a 80/20 cabinet build out?
  17. Sep 30, 2022 at 6:29 PM
    #6817
    nudavinci64
    Robert
    It’s all plywood. marine treated is ideal as it’s better weather resistant. Goose gear is made from plywood then coated in a liner. if you wanted it raised add some 1x1s or similar under it then you have that secret spot for the table. I’ll see if I can snag a photo from him or link if it he posted. My end goal is an 80/20 bound when I stop doing other things.
  18. Oct 2, 2022 at 2:04 PM
    #6818
    kikoman
    kikoman Member
    2021 MGM Tacoma TRD OR DCLB
    Super Pacific
    Made the 15 minute trek from my house to the SP shop Tuesday and picked up #388. I never visited their previous shop, but their current shop is rad. I thought that adding showers for those of you making the roadtrip out to OR is a nice touch. Pretty stoked with it so far but won't have the opportunity to use it for a few more weeks.
  19. Oct 3, 2022 at 11:21 PM
    #6819
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    No base plate for me. My 80/20 cabinet sits on my bed mat and is bolted to the rivnuts on the camper. It's very solid and has never moved. I've posted pics before in this thread if you search my username.
  20. Oct 4, 2022 at 12:13 PM
    #6820
    Tacomags
    Austin, Texas
    Found this table slide meant to be mounted for roof racks that let you use standard 4ft plastic tables. The only catch is that the company is based and ships from AU. https://www.kaon.com.au/roof-rack-table-slide-mount
    Did the measurements for the 3rd gen and it seems like it should work out.
    ETAV8R and Pagan220 like this.
