The old 5k or 10k oil change debate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProTrdRex, Apr 14, 2022.
  1. Apr 14, 2022 at 7:41 PM
    ProTrdRex
    ProTrdRex [OP] Member
    Raphael
    Trd pro
    Just checking if anyone has had any negative experience with 10k oil changes. Personally, I feel like 5k is already pushing the limit. And I would normally go with what the dealership recommends.But I’m getting different answer so “save me Tacoma world you’re my only hope”
    DocJ and Travlr like this.
  2. Apr 14, 2022 at 7:46 PM
    Bishop84
    Bishop84 Well-Known Member
    First hand, I can tell you, there's more issues after 10+ years with the longer intervals. (in my cold weather region)
    The Tundra suffers the most from the 10k oil changes. They really react poorly to the 10k intervals and we see more leaks and timing chain tensioner failures.
    The 3.5 Tacoma's are fairly reliable but the tarnishing will be far worse with 10k and will lead to earlier wear and failure of parts.
    No one I work with does 10k, we all do 5-6k (or 8000kms in our country :p )
  3. Apr 14, 2022 at 7:46 PM
    Shellshock
    Iowa
    I’ve only done oil changes at 10k. Zero issues on any of my vehicles
    zoo truck, wood714, geo8866 and 8 others like this.
  4. Apr 14, 2022 at 7:48 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same. Any how many miles u at?
    A Taco likes this.
  5. Apr 14, 2022 at 7:50 PM
    Shellshock
    Iowa
    123k on my 17
    50k on my 16 when I traded it for the 17
    treyus30 likes this.
  6. Apr 14, 2022 at 7:53 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    1. You are supposed to post these types of questions on Fridays.
    2. If you operate the truck the majority of the time in "Special Operating Conditions" your factory recommended oil change interval is 5,000 miles. If not, your factory re commended oil change interval is 10,000 miles.
    3. The "special Operating Conditions" are:
    a. Driving on dirt or dusty roads.
    b. Using a car top carrier, towing or running heavily loaded.
    c. Repeated trips of less than 5 miles in temperatures below freezing.
    d. Extensive idling or low speed driving, or door to door delivery service.
  7. Apr 14, 2022 at 7:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    Send a sample to Blackstone and let them tell you what they find for your specific engine and usage.
    If you're using the correct SAE and viscosity, I think you'll be surprised at their findings.
    Or you can just continue by 'feel'. Or maybe color. Just don't taste it.
  8. Apr 14, 2022 at 7:58 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Never seen this sort of chart. Interesting how after 30k miles, it seems to convert to a 5k mile oil change internal. Excluding if "special driving conditions" are your primary driving circumstances, this chart doesn't line up with the factory literature.
    I'll stick with 10k intervals.
    ORtoCOTaco likes this.
  9. Apr 14, 2022 at 8:01 PM
    Grindstone
    Grindstone Requires Adult Supervision
    Why
    Coppertone, TS4x4, Auzea and 3 others like this.
  10. Apr 14, 2022 at 8:02 PM
    Grindstone
    You'll notice the free oil changes also end after 30k miles...
  11. Apr 14, 2022 at 8:06 PM
    TacoMamba35
    PNW
    Then they ran out of room on the page, and had to jump from 95k to 120k just to loop in one more major service! What about 100, 105, 110, and 115??
    jordandogtown and gsubioguy like this.
  12. Apr 14, 2022 at 8:07 PM
    ProTrdRex
    Raphael
    Trd pro
    I know it’s old school thinking but it’s drilled in my brain “oil changes every 3k “
  13. Apr 14, 2022 at 8:09 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    another oil thread.....:frusty:
    pltommyo, Lawfarin, Anton338 and 6 others like this.
  14. Apr 14, 2022 at 8:11 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Do what gives you peace of mind.
  15. Apr 14, 2022 at 8:14 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Oil brands and oil change intervals are one of the most opinionated and passionate conversations to be had on every car forum.
    Pick a brand name oil, OEM filter, and change however often you can routinely manage/afford. 5k if you meet the special operating conditions listed in the manual, 10k if you don't. Engine failures related to oil are very rare when the correct oil spec is used with mfr recommended oci.
    There should be one sticky oil thread and all the rest locked and deleted. :deadhorse:
  16. Apr 14, 2022 at 8:17 PM
    Tradbow
    Tradbow Active Member
    Phil
    To each his or her own, but I follow the 5,000 miles or 6 months whichever comes first.
  17. Apr 14, 2022 at 8:19 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I always quote this guy. He’s a Toyota tech. Take this as it is. It’s your truck, your call. https://youtu.be/xdNCnYHhEm8
  18. Apr 14, 2022 at 8:20 PM
    Shellshock
    Iowa
    The free oil changes are only 10k and 20k.
    5k, 15k & 25k are all sunshine treatments
    gsubioguy, Lt. Dangle and Taco_Coma like this.
  19. Apr 14, 2022 at 8:22 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Blackstone labs actual lab results on my 154k mi 2017 Tacoma tells me that 5k mi oil changes are the way to go so all you haters on 5k intervals can go eat a big bag of D's
  20. Apr 14, 2022 at 8:22 PM
    Grindstone
    I guess the implication wasn't clearer.
    With 10k and 20k free oil changes, Toyota pays for the oil twice. After that, you pay for the oil every 5k...
    Funny enough, my local dealer changed my oil free every 5k under Toyota Care.
    shotgunbilly420 likes this.
