The old 5k or 10k oil change debate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProTrdRex, Apr 14, 2022.
  1. Aug 1, 2022 at 6:37 AM
    #401
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Possibly more important than total surface area of the filter element the “type” of filter media may play a larger role. Generally, there are two types of filter media- cellulose and synthetic. They say one is better than the other.
    Wix filters for example. 51393XP is synthetic where 51393, no XP suffix, is cellulose.
    My White Tacoma likes this.
  2. Aug 1, 2022 at 6:40 AM
    #402
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep, you don't want to use a roll of toilet paper, especially if its charmin.
  3. Aug 1, 2022 at 10:34 AM
    #403
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    No no no no no...
    That IS NOT the TW way. Never has been, never will be.
    Just about every topic that gets "discussed" on this forum turns into the same shit lol.
  4. Aug 1, 2022 at 11:23 AM
    #404
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I looked at that TSB and can’t see how it relates to the video at all. The TSB covers to 2011 models and the fix was upgraded pistons and piston ring sets (new part numbers). The video is a 2015 Camry. By 2015 they wouldn’t have been using the problem parts they would have been using the lastest pistons and ring sets.
    Ozark_RegCab likes this.
  5. Aug 1, 2022 at 11:49 AM
    #405
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    LOL!
    On a sad note...you are correct in your overall opinion about how things turn sour.
  6. Aug 1, 2022 at 12:24 PM
    #406
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Good point but the video doesn't relate to our trucks either... Yet everyone keeps saying here's why I do 5k and using it as a justification.
  7. Aug 1, 2022 at 12:30 PM
    #407
    davidstacoma
    David
    NC
    Not sure folks are using that as “justification” since none of us have to justify the decisions we make to anyone here, I think it’s more to inform that the Toyota Master tech has an educated opinion that’s worth considering. No different than someone pointing to 10k/1 year OCI in the manuals (while failing to mention the 5k/6mo conditions that may apply.)
    Pretty sure at this point with all the OCI threads people have their minds made up by now lol.
    33yrsoftoys likes this.
  8. Aug 1, 2022 at 12:30 PM
    #408
    saint277
    saint277 Vigilo Confido
    Lol how long did it take Toyota to include 3rd gens in the fuel pump recall? They were installing the same recalled pump a decade after the first ones were recalled, so there is no reason to believe they would install the upgraded parts stock. If you spend some time on the rav4 forums you will the same problem being reported in later models. Also given that it was a TSB and not a safety recall Toyota had no reason to extend it to later models even though the problem persisted. There are also several other problems with the video, like calling a vehicle maintained with the cheapest oil available and ignoring a serious oil consumption problem till the seized piston rings destroyed the block "impeccably maintained". I think that falls under the category of owner neglect, not impeccable maintenance.
    Also this.
    MOC221_ likes this.
  9. Aug 1, 2022 at 12:35 PM
    #409
    davidstacoma
    David
    NC
    I get it. No one is going to change your mind about OCI, nor should they try too. Conversely you can poo-poo any mention of 5k oil changes until the cows come home and people still gonna do what they’re gonna do, based on their research, experiences, and biases. Such is life.
  10. Aug 1, 2022 at 12:38 PM
    #410
    MOC221_
    Frank
    Well, to be fair the owner of that Camry and I suppose also Toyota would deem that the vehicle was impeccably maintained, since every service was completed (between two dealerships). Also, until the owner first started noticing oil consumption, how would he know or even suspect he had a problem? Also from the video, it was stated that the vehicle was brought in for consumption tests twice, and that oil was being topped up regularly. That doesn't sound like neglect to me. I don't think you can reasonably lay the blame at the owner's feet.
    davidstacoma likes this.
  11. Aug 1, 2022 at 12:40 PM
    #411
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Hi everyone, just checking in to see who won.
    Junkhead, Sprig, IrishRed and 3 others like this.
  12. Aug 1, 2022 at 12:42 PM
    #412
    saint277
    I really haven't advocated for a specific OCI (on this thread at least). That video was just annoying me because I doesn't have much to do with our trucks and has some odd discrepancies in it, but if you MUST know my opinion everyone should do oil analysis tests to work out the best OCI for there engine, because every engine is a special little snowflake, and what works for one my not work for others.
  13. Aug 1, 2022 at 12:43 PM
    #413
    MOC221_
    Frank
    Are these issues being seen across the whole 3rd Gen run, or just earlier engines?
    I guess it would also be notable if other vehicles with the 2GR-FKS are experiencing the same problems.
  14. Aug 1, 2022 at 12:44 PM
    #414
    davidstacoma
    David
    NC
    lol
  15. Aug 1, 2022 at 12:46 PM
    #415
    MOC221_
    Frank
    It's TW. Therefore the answer should be obvious. Nobody wins.
    Junkhead and davidstacoma like this.
  16. Aug 1, 2022 at 12:49 PM
    #416
    davidstacoma
    David
    NC
    The winners are those who just go with what the OCI they prefer and only post info for others to consider if they wish to. The losers are those who have an innate need to convince the rest that only their OCI is the correct answer, because TW folks gonna do what TW folks do, lol.
  17. Aug 1, 2022 at 12:52 PM
    #417
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    The takeaway of the video for me was that the owner apparently followed the dealer-suggested maintenance to a tee and still ended up with these oil consumption issues at a relatively "low" mileage. Ahmed said that it was his informed opinion that 10k mile oil changes were at least a contributing factor to the ring wear observed on this engine.
    Whether these issues are a result of the 10k OCIs or some design flaw particular to the 2AR-FE might be deserving of further research, however.
    It seems like Toyota never could get those Camry 4 cylinders quite right after the 5S-FE in the 3rd gen Camry. After that they started having various issues like headgaskets and oil consumption. But this is just from my research online; it would be interesting to see if @Bishop84 has observed this in his work.
  18. Aug 1, 2022 at 12:52 PM
    #418
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Well put.
    Alright so what next, politics or religion?
    davidstacoma[QUOTED] likes this.
  19. Aug 1, 2022 at 12:54 PM
    #419
    saint277
    Ya the master tech didn't include some perinate information like at what miles the consumption test was done and how many miles it drove while consuming oil, but from the way he described the problem it sounds like the consumption got worse and worse till the owner couldn't keep oil in the thing. Which would definitely be neglect in my book.
  20. Aug 1, 2022 at 12:54 PM
    #420
    davidstacoma
    David
    NC
    Oil brands. lol
    zoo truck likes this.
