The old 5k or 10k oil change debate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProTrdRex, Apr 14, 2022.
  1. Jun 28, 2023 at 1:47 PM
    #661
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    :rofl::rofl:
  2. Jun 28, 2023 at 1:55 PM
    #662
    raw2136
    raw2136 My Pro-Nouns are Dude/Bro
    2018 Gray Tacoma SR Access Cab
    Rear Speakers, Intermittent Wipers, Side Step tubes, Wheels & Tires, Towing Hitch & Harness
    I feel like oil changes are cheap in the grand scheme of things and I like to rotate my tires every 5K anyway. So while I am at it, why not change the oil. Gives me an excuse to play with my tools and hang out in the garage for awhile. Also, remember the factory has a motivation to advertise low cost of ownership for their vehicles. So on one hand, it benefits them to advertise their vehicle requires less trips to the dealership for maintenance.
  3. Jun 28, 2023 at 2:02 PM
    #663
    Bob K
    Bob K Well-Known Member
    Bob
    2017 TRD Off Road
    A UOA measures all aspects of an oil's characteristics and performance. What data point indicates the oil is "dirtier" and more damaging at 10K versus 5K?
  4. Jun 28, 2023 at 2:07 PM
    #664
    raw2136
    On a side note, Costco has 10 quarts of 0w/20 full synthetic for $30. I have been hesitant to switch over from Castrol, but at that price, it is worth a little research.
    NIU_Huskies, AM6217 and Starman2112 like this.
  5. Jun 28, 2023 at 2:27 PM
    #665
    Starman2112
    Starman2112 Well-Known Member
    2018 SR5 AC 4X4 Blazing Blue Pearl
    That’s a sweet deal! Unfortunately, the closest Costco to me is 2 hours away.
    raw2136[QUOTED] likes this.
  6. Jun 28, 2023 at 3:13 PM
    #666
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I can’t wait to see what they say on the new Tacoma. Turbo charged … 10 k …. Planned obsolescence
    It should be interesting
    AM6217 likes this.
  7. Jun 28, 2023 at 3:26 PM
    #667
    1997TacomaSR5
    1997TacomaSR5 OG TACO - 3ook+ ...where 2 wheel next
    The engines of today will someday be 26 years old :)
  8. Jun 28, 2023 at 3:59 PM
    #668
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Im rocking their 5w-30. Truck runs just fine on it. Smells like baby dinosaurs.
    Junkhead likes this.
  9. Jun 28, 2023 at 4:01 PM
    #669
    AM6217
  10. Jun 28, 2023 at 11:10 PM
    #670
    Maxx
    Maxx Well-Known Member
    11.8:1 compression ration isn’t that high for todays standards with direct injection and again cylinder pressure are not that high with N/A motors. Start throwing a lot boost at an engine and you will see way higher combustion chamber pressures which will cause actual blow by and oil contamination. A turbo will also generate a lot more heat in the oil since it is pumped through the bearing cartridge for cooling and lubrication.
  11. Jun 28, 2023 at 11:15 PM
    #671
    Maxx
    Use 100% synthetic oil like Amsoil and change the filter more frequently. 100% synthetic oil can last 25,000 miles with no issues. I’ll post my 15,000 mile test results from my recent oil change whenever they arrive in my inbox. I’m slowly working up to 20-25k OCI.
    I can guarantee my motor runs way cleaner, quieter and smoother than you guys using other “synthetic” oil. There was a noticeable audible difference when I switched from OEM Mobile 1 to Amsoil.
    By law, only 25% of the oil is required to be synthetic to be labeled and advertised as such.
    Again, it really helps to understand how engines and lubricants actually work.
    If you all are going to change engine oil at 5k miles then you should be changing your gear oil and ATF every 10-15k by your standards but I doubt y’all will dish out the cash for that maintenance.
    Here are some YouTube videos since that seems to be the data point source for everyone in this tread.
    Deeahgee and Firn like this.
  12. Jun 29, 2023 at 1:44 AM
    #672
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
  13. Jun 29, 2023 at 4:17 AM
    #673
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Heck at that price, you can do oil changes every week.
    asuchemist and raw2136[QUOTED] like this.
  14. Jun 29, 2023 at 4:24 AM
    #674
    zoo truck
    None
    You don't need amsoil to do 15k mile oil changes, just use mobil1 extended. It worked fine in my 4.7 tundra the 19 years I owned it. Imo, the amsoil would be better suited for turbo powered engines.
  15. Jun 29, 2023 at 5:32 AM
    #675
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    “carcinogens”? What? I’m not drinking it!
    I have been handling gasoline and motor oil for over 60 years. No cancer problems here (but YMMV.)
    Even in California, where everything has a label that says it causes cancer, no matter what it is (because of wealthy lawyers and frightened citizens.)
    Anyhow, all my used oil goes back and they recycle it into new motor oil, so it’s not like I’m pouring it on the ground.
    And it’s not like we’re ever going to run out of oil, because we can make synthetic oil from scratch. It’s just not as inexpensive as pumping & refining crude.
    asuchemist, e6400ultra and zoo truck like this.
  16. Jun 29, 2023 at 5:46 AM
    #676
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Ummm . . . feel better about what? I don’t feel bad about it. Where do people get these ideas?
    Also I own eight bicycles. Perhaps I should feel eight times as good as I do? LOL <voice = potus actual> “Come on man!” </voice>
    If it makes you feel better, one time I only drove his truck 3000 miles the whole year and I only changed the oil one time.
    Even though it was only about 1500 miles, skipping that oil change made me feel bad. :D
  17. Jun 29, 2023 at 6:13 AM
    #677
    Maxx
    I didn’t say you needed it for 15k. I said I’m slowly working towards 25k OCI.
  18. Jun 29, 2023 at 6:23 AM
    #678
    zoo truck
    None
    I feel fine, but I do detect some guilt on your part.
  19. Jun 29, 2023 at 7:09 AM
    #679
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Used oil is oxidized and the chemical reactions that occur within used oil happen to make it more carcinogenic. It’s beyond the “everything causes cancer in California“ trope. Limiting one’s exposure to it, in general, is not a terrible idea. This means just contact with the skin and breathing the fumes.
    This is just one relatively minor reason I wouldn’t change after just 2k and 6 months, like you’re saying is necessary. The main reason is that my own UOA at 3k and 15 months that I posted earlier proves it’s completely unnecessary to change after a year, let alone 6 months.
    PS synthesizing motor oil when there’s also presumably no remaining natural oil that can be refined into gasoline doesn’t make any sense. I’m a petroleum geologist btw.
    cryptolime likes this.
  20. Jun 29, 2023 at 8:35 AM
    #680
    Firn
    Firn Well-Known Member
    White OR
    I was under the impression that even high quality synthetics start with a petroleum base product. Maybe I'm just thinking of Penzoil Platinum/Ultra that are refined from Natural Gas.
    Point being though, I was under the impression we still need/use "dino" products to get to synthetics.
    I don't think there needs to be any guilt or health concerns over changing ones oil frequently, nor really any major environmental arguments if the oil is recycled properly. There is some energy in recycling used oil but frankly if that is an argument then there are other things one should be doing that have a FAR greater impact.
    I think the point most drive to is if it NECESSARY to do so, as in that it offers some benefits to the longevity of the engine ("peace of mind" being different).
    That said, I see more folks try and rationalize short oil changes than I see folks rationalize longer ones (but not saying it doesn't happen).
