The ole backspace question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DIYReefer, Feb 1, 2021.
  1. Feb 1, 2021 at 1:38 PM
    DIYReefer
    DIYReefer [OP] Well-Known Member
    Lebanon Oh
    2015 double cab long bed
    Brand new and no mods yet
    Guys,
    I’ve been a member here for a few years. I remember finding threads all about tire size wheels and backspacing.
    Maybe someone can point me to that thread because I cannot seem to find it.
    My setup,
    2015 DCLB
    2.75 OME LIFT WITH 885’s and new Dakar’s new upper control arms.
    At the moment I’m running 285/70R17’s on stock wheels with 1.25 wheel spacers.
    I’m due for some new tires, and I want to eliminate the wheel spacers and go with new wheels. 20x9 rockstars with 4.53 backspacing. Is this the correct size back spacing to eliminate the wheel spacers?
    Thanks in advance for any and all responses.
  2. Feb 1, 2021 at 1:51 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What’s your current wheel width and offset?
  3. Feb 1, 2021 at 1:58 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Knowing offset is easier but.... i think 4.5 is still on the high side
  4. Feb 1, 2021 at 2:11 PM
    DIYReefer
    Lebanon Oh
    Running stock wheels at the moment with 1:25 wheel spacers
  5. Feb 1, 2021 at 2:12 PM
    DIYReefer
    Lebanon Oh
    I’m just having a hard time wrapping my head around it.
  6. Feb 1, 2021 at 2:45 PM
    gotoman1969
    That’s didn’t answer the question. Do you not know the width and offset? 4.5 backspace should be fine, the 20” wheel may more of an issue, you may need less offset because of that. Knowing your current width/offset will help determine if the outer lip of the wheel you want go to will be sitting in approximately the same spot.
  7. Feb 1, 2021 at 4:23 PM
    DIYReefer
    Lebanon Oh
    Not sure what the stock wheel offset is.
  8. Feb 1, 2021 at 5:50 PM
    gotoman1969
    Got it. It definitely would help knowing. If you get it. Post it.
  9. Feb 2, 2021 at 8:23 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  10. Feb 2, 2021 at 9:23 PM
    Taco-Obsessed
    To get a good answer, everyone would need to know what you current stock wheel backspacing, or wheel width & offset is. I quickly googled 2015 stock wheels and it looks like only two 17" wheels were offered for 2015s. They were both 17x7.5 with +30 offset. That width/offset combo converts to 5.43" backspace. So, with your 1.5" spacers, your backspace right now would essentially be 5.43-1.5= 3.93". If my Google guess of what your stock backspacing is correct, your proposed new wheels will have a difference in backspacing of .6" (.6" less the wheel will be pushed out, .6" more in backspacing value).
    Whether or not that'll work for your setup, I dont know. Honestly, I don't know shit about 20s and potential issues fitting those.
    With 4.53 BS your wheel won't be pushed as far out anymore, which decreases the likelihood of rubbing on your cab mount/firewall, but you are a little closer to your UCA, coilover, spindle, etc (typically less of an issue compared to contacting your cab mount/firewall).
    I recommend you figure out exactly what your backspace is for your stock wheel and provide that here for feedback. Also, if you wheel, why not just stay in the 16-17" wheel range? You could find one to eliminate the need for spacers. 20s aren't really wheels for for wheeling. However, if it is just the look you're after and it's a street truck, than do what makes you happy.
    If my assumptions are correct, and you want to run the same backspacing you are now without spacers (or within .1" of it), than seems like that wheel is not what you're looking for.
  11. Feb 2, 2021 at 9:32 PM
    Taco-Obsessed
  12. Feb 3, 2021 at 2:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Backspacing is really the only spec that matters then wondering if you’ll rub on suspension components or not. 4.5” or less is fine for 285s so to answer your question, yes those will be fine. That said, a 9” wide wheel will give you rubbing issues at the firewall/cab mount. An 8” wide wheel with 4.5” BS is ideal for 285s.
