The original! Relentless fab tailgate reinforcements
Discussion in 'Relentless Fabrication' started by RelentlessFab, Mar 10, 2014.
  1. Jun 17, 2016 at 10:21 PM
    #121
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yep available and in stock, both aluminum and steel, and bare or powder coated finish. Just no diamond plate, havent done any batches of them for at least the last 6 months. The diamond plate is not the most popular.
    Spencer97TJ[QUOTED] likes this.
  2. Jul 5, 2016 at 7:28 PM
    #122
    WrecklessWilli
    WrecklessWilli Member
    Austex/Telluride
    2009 Access TRD OR
    nada
    Would it not be possible to also fold over the "bottom edge" of the tailgate reinforcement as well, increasing the overall strength of the bottom edge? Seems quite doable.
    sdogga[QUOTED] and At The Helm like this.
  3. Jul 6, 2016 at 9:02 AM
    #123
    RelentlessFab
    Eric
    Sparks, NV
    Possibly, I was just talking about doing just that with another customer the other day, we'd have to do a bit of measuring and test fitting to see if it would fit
    At The Helm likes this.
  4. Jul 6, 2016 at 9:20 AM
    #124
    WrecklessWilli
    Austex/Telluride
    2009 Access TRD OR
    nada
    Probably wouldn't have to have much of fold, maybe 3/4" and it would make a huge stiffness gain at the edge.
  5. Jul 6, 2016 at 9:31 AM
    #125
    scocar
    scocar Patron of the Farts
    From my experience fitting one of these on a 15, it could make installation extremely tight or nearly impossible unless some additional depth were added to keep that new break across the bottom about 1/2 inch or so away from the bottom of the gate structure.
    In other words, don't increase overall size and break right at the bottom edge. Instead, add enough material to break it a bit farther out, so there is some play to accommodate installation.
    Another issue is that it would also affect the ability to re-use the fiberglass cover over the reinforcement plate, because it curves around the lower edge as is. With the plate underneath, it contacts the end of the bed. This may not be an issue for folks who wish to use it bare, but I found the fiberglass cover eases material loading and unloading.
    The 15 does have additional screws sticking out of the top corners that make it nearly impossible to install the plate as it is unless you remove the screws.
    I recommend careful fitment R&D on a prototype first.
  6. Jul 7, 2016 at 11:31 AM
    #126
    Warfarin
    Warfarin Member
    NW Arkansas
    What do you have in stock for a 95.5 Tacoma 4x4? I was contemplating a new tailgate because mine was beat to crap by the previous owner, but this looks like it would hide the beat up inside of the tailgate as shore up the beat up top and bend in the middle!
  7. Sep 15, 2016 at 10:19 AM
    #127
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    For those that reused the stock plastic on top of the alum plate, did you have to buy all new longer fasteners, or do the stock ones still work?
  8. Sep 15, 2016 at 10:27 AM
    #128
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just drilled out the holes in the factory piece to make them large enough.
    Worked perfect.
    Crom[QUOTED] likes this.
  9. Sep 15, 2016 at 1:47 PM
    #129
    Crom
    Nick
    San Diego, CA
    Millions
    Question for you. I Read that initially you just used the reinforcement, for a few weeks, then added back the stock cover over the reinforcement? Just curious why. thanks
  10. Sep 15, 2016 at 1:54 PM
    #130
    T4RFTMFW
    I didn't want to see scratched up powdercoat every day. Only reason.
    I'd rather abuse a piece of fiberglass.
    Crom likes this.
  11. Sep 15, 2016 at 1:54 PM
    #131
    Crom
    Nick
    San Diego, CA
    Millions
    Very good. Thanks!
  12. Sep 17, 2016 at 4:38 AM
    #132
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Tundras getting some love with these soon!?
  13. Sep 17, 2016 at 11:31 AM
    #133
    RelentlessFab
    Eric
    Sparks, NV
    I've thought about it! But they seem to be reasonably strong from the factory. I'll think about it some more. :cool:
  14. Sep 17, 2016 at 9:09 PM
    #134
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    Just got mine last week. Installed it Friday. I must say I like the difference. Nice workmen Ship!!
    RelentlessFab[OP] likes this.
  15. Sep 18, 2016 at 12:07 AM
    #135
    Spvrtan
    Kris
    Do it! Better safe than sorry but yea I'm sure the tailgates can handle ~200lbs safely. I just like having things overbuilt, haha.
  16. Sep 29, 2016 at 12:06 PM
    #136
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    Anyone?
  17. Dec 28, 2016 at 8:45 PM
    #137
    raymond32j
    raymond32j Well-Known Member
    Raymond
    Seattle, WA
    2013 Tacoma Regular Cab 4x4 Base
    Not yet.
    Do you have any steel power-coated available? If not, how long before you would have some? Looking to get one
  18. Dec 28, 2016 at 8:51 PM
    #138
    RelentlessFab
    Eric
    Sparks, NV
    Think we just ran out, but we've got more at the coater. Bare are in stock still
  19. Dec 28, 2016 at 9:04 PM
    #139
    raymond32j
    Raymond
    Seattle, WA
    Not yet.
    Thank you. I will keep an eye for when the power-coated comes back in stock
  20. Jan 2, 2017 at 1:59 PM
    #140
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    When I installed mine, I used the factory fiberglass over it.
    However, I'm thinking of removing it and doing outdoor carpet with rubber padding underneath. Y'all have any suggestions for that?
