The passenger window lockout effects the driver's side switch? Really?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zooks527, Apr 29, 2017.
  1. Apr 29, 2017 at 11:57 AM
    Zooks527
    Zooks527 [OP] Active Member
    Mansfield, MA
    2005 Tacoma TRD Sport Access Cab
    DDX3 BT radio, tailgate cam, heated seats
    So, yesterday, I went to drop the passenger window while I was driving and nothing happened. First thought was "Damn. Fuse or motor?" Then I noticed the lockout was pushed, so I released it and tried again, with the window working fine.
    40+ years of driving, and this is the first time I've come across a lockout button that takes the driver's controls out as well as the point-of-use.
  2. Apr 29, 2017 at 2:13 PM
    Tacotruck422
    Tacotruck422 Well-Known Member
    Seattle, Wa
    2015 DCLB
    Pro wheels, bilstein 5100's, 265/70/17 ko2's
  3. Apr 29, 2017 at 8:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is a feature. :)
  4. May 27, 2017 at 1:11 PM
    brad5610
    brad5610 New Member
    Brad
    2015 SR5 DCLB 4X4
    Yep, When the lock is engaged, the only window that can be moved is the drivers window. Stumbled across this thread looking for a solution to my problem. I have a dog that rides in the back seat of my truck, and likes to stick her head out the window. I only put the window down about half way, so she can't fall out. I keep the lock engaged so she can't open it when she steps on the switch. Problem is that I have to disengage it every time I want to open or close the window, or even the front passenger window. I thought I'd be smart, I took the door panels off and unplugged the switch, but now the windows don't work at all. I'm currently looking for a solution, maybe I can put a jumper in the harness to "bypass" the rear switches?
