The Perfect Offset for 285/75/16 ???
Discussion in 'Wheels & Tires' started by george2pak, Feb 1, 2013.
Wich Offset for 285/75/16 on 8"wide with 3" lift?
  1. 0 mm
    39 vote(s)
    52.7%
  2. -6mm
    8 vote(s)
    10.8%
  3. -12mm
    23 vote(s)
    31.1%
  4. Other
    4 vote(s)
    5.4%
  1. Feb 16, 2017 at 12:42 PM
    #61
    mark1285
    mark1285 Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    Negative offset moves the center line towards the inboard side of the rim, moving your tires further out, so you have it right. 2016-17 Tacos Come with a factory offset of 25mm. Moving lowering the number from there would just move the tires further out, further from the UCA.
    I'm putting 0 offset 4.5" backspace 17" Pro Comp wheels with 285/70 Toyo's on my 2017 in a few weeks. I'll respond here and other places with how much, if any trimming i had to do.
  2. Feb 20, 2017 at 9:15 PM
    #62
    iridebikes
    iridebikes Well-Known Member
    Scott
    2016 TRD Sport Manual
    Bilstein 5100 / Icon AAL / SCS SR8s
    I put 285/75/16 on SCS SR8s today with an approximate 2" lift (Bilsteins on the 4th notch with a 1/4 spacer on top), Icon progessive AAL and have zero rub even at full lock in reverse. That's pre-alignment too. -12 offset, 4" backspace. Hope that helps.
    Klondike Kid and gutsybuttsy like this.
  3. Feb 21, 2017 at 5:32 AM
    #63
    mark1285
    Mark
    That is great to know. Do you have a picture of the stance with that setup? I'm going to only be around 1 1/2" in the front but I have a little more offset. Hopefully I'm good but I'm worried that I may need a CMC because of the wider stance. Time will tell.
  4. Mar 7, 2017 at 8:51 PM
    #64
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    OT, but is there a "show off your 285" thread?
  5. Mar 8, 2017 at 1:12 PM
    #65
    mark1285
    Mark
    So I had extensive rubbing with 285/70R17 with zero offset 8" wide rims. No Lift. I required a CMC. However with the CMC I can say that I will not have rubbing at all anywhere, even at full stuff.
  6. Mar 8, 2017 at 7:43 PM
    #66
    umpi5
    umpi5 Well-Known Member
    PNW
    07 Tacoma SR5 TRD Sport
    All Pro Pack Rack CVT RTT OME Lift and Dakar leafs
    Maybe you guys can help me. Got an 07 taco with OME lift(885 coils and nitrochargers shocks dakars leafs) and SPC uca. Currently running 265/70/17 now. Got a set of wheels that are 17"x9" -12 offset. They rubbed like crazy before the lift. I assume they wont now since i got the lift on? And would they rub if i put 285/70/17 on?
  7. Mar 9, 2017 at 7:20 AM
    #67
    mark1285
    Mark
    Really hard to say without trying it. Worst case, they rub the cab mount and you need a CMC. The fenders can be easily pushed back with a heat gun.
    My best guess after doing mine is that you wouldn't rub with 33"s and a -12 offset with a lift for daily driving. You'd be closer to the UCA than I am, but the lower pivot point should mean that a 33 will clear the cab mount by a little more. Again this is a guess only.
    Another way to look at is that if they rub before a lift, they probably will rub after a lift at full stuff. This is why serious off road guys typically always do CMC even with 33's and a lift. IF they stuff the wheel and turn it towards the cab mount it probably will rub even with a lift. But for daily driving on pavement, they would never hit. I'm doing the CMC today actually so that my 33's wont rub at all with stock suspension. That way I know i'll always be good, unless I go Long travel (someday)
  8. Mar 9, 2017 at 6:15 PM
    #68
    umpi5
    PNW
    Thanks man for the intel. Yea the CMC is prob what ill end up doin. Being a welder at CAT has its preks but once thats chopped i should be ok I thought no with 33's
  9. Mar 17, 2017 at 2:13 AM
    #69
    electra_boogaloo
    electra_boogaloo Well-Known Member
    2007 Double Cab Long Bed
    found this thread hiding on google. are there any low cost wheels that will fit? i have a "leveling kit" and 285-75/16s with good tread that i'd like to move onto new rims. but i really want steels for their low cost and i just like the way they look. i'm still using stock wheels and the used lot i got the truck from threw on some of those cheap wheel spacers from auto-bone. they also installed the "leveling kit" before i bought it so i have no idea what exactly it is.
    bonus TITS
  10. Oct 2, 2018 at 7:00 PM
    #70
    Victro
    Victro New Member
    2014 Magnetic Grey Tacoma TRD Sport
    265/70/17 BF Goodrich AT KO2 ARE Z Series Truck Cap
    I have Nitto Trail Grapplers 285/75/16 on Method NV 16x8 4.5-BS 0-Offset on 3 in lift and i have no rubbing at all.
  11. Apr 30, 2019 at 6:17 PM
    #71
    Happy 8832@hotmail.com
    Happy 8832@hotmail.com New Member
    Hap
    2019 Tacoma
    3-1 pro comp lift
    I have the same question
    I’m gonna use the TRD wheels with 4 mm offset with 285 /70/17. ???
  12. Jul 11, 2019 at 10:09 PM
    #72
    george2pak
    george2pak [OP] Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    I know that there are some TRD wheels that have the perfect for 33" tire.
  13. Jul 14, 2019 at 7:56 AM
    #73
    JC103
    JC103 New Member
    2020 TRD PRO
    I have 265/70/16 which is stock tire size. Rims Ray 10s -12 offset . I recently just did 1 in leveling kit in front to get rid of some factory rake. Can anyone help out, I want to go up to 265/75/16 tire, pretty confident it wont rub. Any thoughts before I purchase. Greatly appreciate any feedback.
