THE PLASTI-DIP MEGA THREAD!!!!!!
Discussion in 'Detailing' started by mmtaco06, Aug 10, 2010.
Plasti-Dip
  1. Good Idea
    69.1%
  2. Bad Idea
    6.7%
  3. Plasti-Derp
    18.2%
  4. I'm jelly...
    6.3%
  5. You jelly???
    8.1%
  1. May 24, 2012 at 11:04 AM
    #2561
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I dipped my front grill to get rid of the chrome, I has noticed peeling because I didn't clean it well and then spent 14 hours on the interstate
  2. May 24, 2012 at 5:57 PM
    #2562
    anormis
    anormis Well-Known Member
    Anthony
    St. Charles MO.
    BarcelonaRed 2010 D.C V6 4.0 Liter 4x4
    Hunter trucks brush guard, pcd performance chip, tailgate theft mod,blacked out badges, painted engine cover, black tail lights, modded mud flaps, painted black grill, seat belt beep mod, rear TSB!.yellow fogs red led map lights. Painted switches black, painted hood scoop, black center console and overhead console. Black wheels! Red calipers.
    Ok so a little spot on my hood scoop pealed up. I dont have any way to buy plasti dip for about 9 weeks. So I went to start pealing it off but this shit wont let loose. I mess with it for 30 min and only got like 6 square inches off. Does any one know a trick to get sunbaked plasti dip off? I have used this stuff plenty of times so I know it shouldnt be this fucking hard.
  3. May 26, 2012 at 10:56 AM
    #2563
    crazyengineer
    patrick
    Bristol, TN
    aefc9b28-1945-9f85_7388c4388a030bf67c45877f1c73c51409077282.jpgaefc9b28-1955-1a77_256ac083837221b2d634cfcf0bd0d63f9821e76f.jpg
    Dipped my wheels
  4. May 26, 2012 at 11:41 AM
    #2564
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    lol, how many coats did you put on it? also I always wait an entire day before putting out the dipped part into the world.
    it should come off even by rubbing it with your finger. When I was re-dipping my shift panel I had that same thing happen to me. Some parts would peel off fine but the rest I had to use a rag to get off. Just the abrasion from the rag (was an OR rag my mom brought home) was enough to get the dip off. Just try using a rag.
  5. May 26, 2012 at 7:07 PM
    #2565
    crazyengineer
    patrick
    Bristol, TN
    It was a few weeks after
    I'd say 3 coats, but it was also a little uneven
    Ya, most of the pics that I post as of small things , so you don't see them much
    My hood, emblems, and bumper are next in line
    Gonna get a few fans tomorrow
  6. May 27, 2012 at 6:25 AM
    #2566
    crazyengineer
    patrick
    Bristol, TN
    [II found something new about plastidip Today
    Meguires hot shine tire cleaner and shiner works on plastidip
    Check it put
    Edit: don't try this, it makes it start peeling, I need to redo it now
  7. May 28, 2012 at 7:19 AM
    #2567
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I got the red today. Ordered it online from a store on Amazon.com. Will post pics when I use it.
  8. May 28, 2012 at 7:33 AM
    #2568
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Plasti dip is awesome
  9. May 28, 2012 at 7:49 AM
    #2569
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Only use I've found, so far.........Pinch Weld, makes it disappear :thumbsup:
    Now ya see it
    Now ya don't
    CC
  10. May 28, 2012 at 4:07 PM
    #2570
    crazyengineer
    patrick
    Bristol, TN
    Badges now done
  11. May 28, 2012 at 6:09 PM
    #2571
    Junebug55210
    Junebug55210 2011 TRD Sport 4x4
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    Cat back magnaflow, toolbox, camo seat covers
    When plasti dipping badges do most people clear coat them or do they hold up fine with out it?
  12. May 28, 2012 at 6:19 PM
    #2572
    Junebug55210
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    ok thanks. I'm thinking that I will probably take them off and paint them then.
  13. May 30, 2012 at 6:15 AM
    #2573
    Tacoma333
    Tacoma333 Active Member
    NV
    Tacoma doublecab 4wd SR5
    3" lift
    This stuff is great. I plast-dipped my valence and badges on my truck last night, doesn't look too bad? what do you think?
    I agree with others, don't just spray the badge, spray around the badge as well, helps with the removal:cool:
  14. May 30, 2012 at 6:37 AM
    #2574
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    PlastiDip'd the front bumper valance today! I love it! put a nice coat of wax down before i sprayed it so it comes off easier when I want it to.
  15. May 30, 2012 at 11:26 AM
    #2575
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I test dipped the honda, just to see if it was indeed as awesome as everyone says.
    Indeed, its super easy, and awesome!! So I did the emblems on the taco first, then my fiance talked me into doing the wheels too. Next is the valance, which she is totally against. I dig it though so I'm going to try it. I just have to scrub the bugs off first...
  16. May 30, 2012 at 12:28 PM
    #2576
    DoubleTake
    DoubleTake Well-Known Member
    Has anyone done the chrome/black fender trim on 1st gen Tacoma? Thinking about giving it a try.
  17. May 30, 2012 at 6:46 PM
    #2577
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    i did that on monday:D
  18. May 31, 2012 at 3:49 PM
    #2578
    Cape Codder
    Jack
    You've got a Supa White?
    Did it make a Big Difference?
    Post a pic. Before and after, if ya gat 'em
    CC
  19. May 31, 2012 at 6:16 PM
    #2579
    Junebug55210
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    I know you have to dig the center out of the letters but do you have to cut around the badge to get the excess off?
  20. May 31, 2012 at 6:21 PM
    #2580
    crazyengineer
    patrick
    Bristol, TN
    Nope
    Just pull it off, it peels off and will break at the letters if you are careful
