THE PLASTI-DIP MEGA THREAD!!!!!!
Discussion in 'Detailing' started by mmtaco06, Aug 10, 2010.
Plasti-Dip
  1. Good Idea
    69.1%
  2. Bad Idea
    6.7%
  3. Plasti-Derp
    18.2%
  4. I'm jelly...
    6.3%
  5. You jelly???
    8.1%
  1. Dec 1, 2010 at 3:43 PM
    #241
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    But how well does it hold up ?
    I want to do my flares in black but worried that tree branches would just peel it off ?
  2. Dec 1, 2010 at 6:16 PM
    #242
    SR54x4
    SR54x4 Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    Yup you can just peel it right off. The stuff is pretty durable but if you pick at a corner you will be able to peel it off, like a sticker.
    The way I did it was I masked off the area and did about four coats letting it dry 5 minutes in between. As soon as the last coat was sprayed I quickly pulled off the masking. I was afraid thay if I let it dry the overspray on the masking would dry with the part I wanted to stay and it would all peel off. It came out pretty good this way. Only have one run in it, my own fault, and its mostly covered by the liscense plate. If this seems to stay on the bumper ill probably peel it off in the sspring and re-do it so that run is gone.
  3. Dec 1, 2010 at 6:25 PM
    #243
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Where do you get the Plasti dip...or whatever its called
  4. Dec 1, 2010 at 6:26 PM
    #244
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    Home Depot or Lowes....wow never thought i would tell chris something he didnt know.......
  5. Dec 1, 2010 at 6:28 PM
    #245
    SR54x4
    Mark
    Hudson Valley
    Hard to say since I haven't had it on my truck too long. I also did my wheels with it a few weeks ago and so far so good. The stuff is pretty durable so I think it would hold up ok. I say since its cheap go for it. At a minimum you'll get to see if you really like the flares black and get some practice for when and if you do use real paint.
  6. Dec 1, 2010 at 6:32 PM
    #246
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i was wondering same thing.....i checked autozone and advance no bueno
  7. Dec 1, 2010 at 6:34 PM
    #247
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool! Thanks man :)
    SILENCE! i keel you!
  8. Dec 1, 2010 at 6:41 PM
    #248
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    how did you keep it from peeling off when you removed the tape... i did my badges, and when pulling off the tape it pulled up all the edges of the stuff.....
    coat with short gaps b4 it tacks up and pull off tape while its still wet?
  9. Dec 1, 2010 at 6:51 PM
    #249
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    im still waiting for my chance lol. :D
    chris4x4 is like one of the head hanchoes here at TW :bowdown:
  10. Dec 1, 2010 at 6:56 PM
    #250
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im sure you'll get a chance...I dont know that much :eek:
  11. Dec 1, 2010 at 7:02 PM
    #251
    SR54x4
    Mark
    Hudson Valley
    Yup
  12. Dec 1, 2010 at 7:05 PM
    #252
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    Very nice! I Plasti-Dipped mine last weekend too.
    I used an exacto knife. Worked like a charm!
  13. Dec 1, 2010 at 7:13 PM
    #253
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Is that what you kids are calling it now? We just called it the old frank and beans in my day.
  14. Dec 2, 2010 at 6:50 AM
    #254
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So none of you sanded, or roughed up, the surface before you applied the Plasti-Dip? Just cleaned, masked and sprayed?
    FYI, you can also find Plasti-Dip at most Ace Hardware stores.
  15. Dec 2, 2010 at 7:52 AM
    #255
    BeardedWeirdo
    Texas
    Yep. I just cleaned the bumper really good and then wiped it down with rubbing alcohol afterward and let it dry. Then I masked off the area and applied the Plasti-Dip. I waited roughly 30 minutes between coats. I applied 5 coats which used about 1/2-3/4 of a can. Then I let it dry for 4 hours and then carefully used an exacto knife and went over the tape edges and removed the tape.
  16. Dec 2, 2010 at 12:08 PM
    #256
    Grande
    Victorville, CA
    did u use it on ur grill too, or just ur bumper, looks like one is more glossy than the other
  17. Dec 2, 2010 at 1:02 PM
    #257
    BeardedWeirdo
    Texas
    The grille is painted black. My problem is now I'm kind of wanting to do a matte black grille to match them up. I have a matte black stock grille, but I really don't want to Satoshi it, too just to try it out. The skull is Plasti-Dipped though. :D
  18. Dec 2, 2010 at 1:22 PM
    #258
    Snocoma
    Snocoma Active Member
    Peter
    Edwards, CO
    2020 TRD Off road, 4D, LB
    Anyone try it with the RustOleum truck bed coating spray yet? I think that might be the perfect application since it'll be taking a lot of abuse up front...
  19. Dec 2, 2010 at 2:07 PM
    #259
    crf69
    Ohio
    ummm yeah
    i just did my emblems.....what i did was hold my drivers liscense just parralell with the ebmlem and peeled the tape......worked like a charm.....now i gotta get the in betweeners out
  20. Dec 2, 2010 at 2:12 PM
    #260
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    Maby you went a little to heavy and it bridged between the body and the emblem.... i just did mine last weekend and didnt have any issues, but i only did 3 coats
