THE PLASTI-DIP MEGA THREAD!!!!!!
Discussion in 'Detailing' started by mmtaco06, Aug 10, 2010.
Plasti-Dip
  1. Good Idea
    69.1%
  2. Bad Idea
    6.7%
  3. Plasti-Derp
    18.2%
  4. I'm jelly...
    6.3%
  5. You jelly???
    8.1%
  1. May 31, 2012 at 6:24 PM
    #2581
    Tacoma333
    Tacoma333 Active Member
    NV
    Tacoma doublecab 4wd SR5
    3" lift
    nope, it just pulls off
    I do pull close to the truck, instead of straight out....not sure if it makes a diff or not?
    digging out the letters, I used a tool I got from the Dentist Office (like a J shape but very thin)
  2. May 31, 2012 at 6:28 PM
    #2582
    Tacoma333
    NV
    3" lift
    I think it's crazy how it just breaks away like that:confused: I thought I was going to have to use dental floss, but it just breaks away, like its perforated:cool: must be just enough gap between the truck and badge.
  3. May 31, 2012 at 6:34 PM
    #2583
    Junebug55210
    Junebug55210 2011 TRD Sport 4x4
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    Cat back magnaflow, toolbox, camo seat covers
    Ok thanks guys. At first I was scared of hurting my paint but now I think I might try this maybe this weekend. Thanks again.
  4. May 31, 2012 at 6:47 PM
    #2584
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    plasti dip is the cats meow, i have it on my valance and scoop
    and it hasn't chipped in over a year
  5. Jun 1, 2012 at 3:59 AM
    #2585
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    when removing the masking tape, I had a dull razor blade that the plastidip fought pretty hard against. Then i got a new blade and that solved the problem. Point is that plastidip is pretty tough! I'm happy that i can peal it off and redo it if i ever wanted to. :D
  6. Jun 2, 2012 at 8:04 PM
    #2586
    Junebug55210
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    How long should I wait between coats if I'm doing my badges? I've searched this a few times but just can't find a actual detailed write up about it. I wanted to paint them but if all I have to do is clean the badges and spray them I'm all about that.
  7. Jun 2, 2012 at 9:07 PM
    #2587
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I just waited for it to not be tacky. I did some in the evening, about 55°. Took about 20 minutes each coat. Did others the next day, about 75°. Took only like 5 minutes each.
  8. Jun 3, 2012 at 12:50 AM
    #2588
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    plasti dipped my wheels, went through 4 days of wheeling in moab and they have stood up well, am pleased
  9. Jun 5, 2012 at 3:29 PM
    #2589
    hooflander
    hooflander Active Member
    07 DCSB TRD Sport
    so this stuff is matte black. How does one go about getting a semi gloss or gloss finish? clear coat over top? I am thinking about painting my rims but if i could get a semi gloss / gloss finish out of this i might do it. also my bugshield is peeling the outer clear layer. wonder if i could just plasticoat it? i was going to pull it paint and clear coat glossy but........:rolleyes:
  10. Jun 7, 2012 at 2:37 PM
    #2590
    hooflander
    07 DCSB TRD Sport
    i tried looking through the threads but its sooo stinking long i got cross eyed. has anyone tried the clear coat over the plasti-dip to get a nice glossy finish? pics if it worked out or advice if it didnt please? also if you sand and prep with some plastic adherence prep spray does it prolong the dip?
    I rattle canned my bug deflector with some Krylon plastic paint after the clear layer bubbled up and looked crappy but you can still see some of the lines where i couldnt get all the clear layer off. im thinking a little plasti dip would smooth it all out.
  11. Jun 7, 2012 at 9:54 PM
    #2591
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    bought a can today...
    :spy:
  12. Jun 8, 2012 at 5:57 PM
    #2592
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    Ive rattle canned clear coat over plastidip, didn't look like gloss paint, so I peeled it off. It is shinier but doesn't look that great in my opinion.
  13. Jun 8, 2012 at 7:43 PM
    #2593
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    I am thinking of doing my chrome grille surround but I am really worried about getting my grille off without busting tabs off. I know there are like two screws and two clips and then pull up straight. What's the key to getting the grille off without breaking anything?
  14. Jun 9, 2012 at 8:24 AM
    #2594
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    It's pretty easy to do. You shouldn't have to worry about breaking any thing
  15. Jun 9, 2012 at 8:28 AM
    #2595
    hooflander
    07 DCSB TRD Sport
    thanks i ended up painting it and clear coating it. its not bad but you can still see the edge and spots wear the dumb clear layer came of the shoeld but it looks better than it did!
  16. Jun 9, 2012 at 8:30 AM
    #2596
    jsauce8921
    jsauce8921 Well-Known Member
    SoCal
    DblCab sb 4x4 trd off road
    yeah getting the grill off was super easy and as long as you follow the instructions you shouldn't break anything
  17. Jun 9, 2012 at 9:45 AM
    #2597
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    wait about 5 minutes in between coats, sunny days are the best to paint (helps dip dry faster).
  18. Jun 9, 2012 at 2:38 PM
    #2598
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    Okay, I took the grill off with no issues but really did not like the look of it when I got finished. There were shadow looking marks at the top that had a bit of texture to it when finished. I just could not get it to blend. Took me about five minutes but it is now back to chrome. I was not impressed. I will leave the emblem but that may even get changed to another color.
  19. Jun 9, 2012 at 4:40 PM
    #2599
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Joined the plasti-dip nation today, God help me! I derp'd the front grille emblem
  20. Jun 10, 2012 at 9:28 PM
    #2600
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    Hey dudes,
    I just found out about this stuff and have a few questions. (I scrolled through about 20 pages of this thread, but could find answers)
    1) I assume there are different shades of this stuff? What best matches the "black sand pearl" black 2nd gens? I would like to do my rear bumper and chrome on my front grill.
    2) It look like some folks take their wheel off to plasti-dip them, while others leave them on and just cover the brake calipers. Is there any harm in the latter? Any issuess with spraying over the lugs nuts?
    Thank you in advance for the help!!
