THE PLASTI-DIP MEGA THREAD!!!!!!
Discussion in 'Detailing' started by mmtaco06, Aug 10, 2010.
Plasti-Dip
  1. Good Idea
    69.1%
  2. Bad Idea
    6.7%
  3. Plasti-Derp
    18.2%
  4. I'm jelly...
    6.3%
  5. You jelly???
    8.1%
  1. Aug 26, 2017 at 3:52 PM
    #5801
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    25 dollars worth of plasti dip on stock steel wheels
  2. Sep 8, 2017 at 9:18 AM
    #5802
    TheCount
    TheCount Member
    Trevor
    Orange County, CA
    2014 Tacoma TRD Off Road
    I am finally going to dip my stock wheels, did you guys remove the wheels or leave them on?
  3. Sep 8, 2017 at 9:54 AM
    #5803
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I had mine off for summer so I did them then.
    Also made it easy to stick index cards between wheel and tire to avoid tire clean up after.
    But you can dip them on truck too..
    You can carefully put some tire shine on tire itself then cover brakes with shop n save bags (or whatever) then wipe tires down after spray dries. Check out some youtube videos the dipyourcar guy has a few with tires on vehicle.
    Mine have lasted through several maine winters and still look great for this winter.
    Dipyourcar. Com has some cool tire & brake protection also.
    TheCount[QUOTED] likes this.
  4. Sep 8, 2017 at 11:15 AM
    #5804
    TheCount
    TheCount Member
    Trevor
    Orange County, CA
    Thanks man, I think I will just remove them. Should be legit.
    ChemDawg[QUOTED] likes this.
  5. Sep 8, 2017 at 12:54 PM
    #5805
    ChemDawg
    Maine
    2005 sr5 4x4
    Yea removing is the best way.
    Just remember the more you put on..... the better it will last and the better it will come off once you decide to.
    I put one thin coat on then just put thicker coats on after that.
    I'd say I ended up using almost of a full can on each wheel.
    Index cards work amazing.
    TheCount likes this.
  6. Sep 8, 2017 at 6:31 PM
    #5806
    TheCount
    TheCount Member
    Trevor
    Orange County, CA
    I think it turned out great
  7. Sep 10, 2017 at 7:19 PM
    #5807
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Did you end up taking them off or did you spray them on the truck?
  8. Sep 10, 2017 at 9:51 PM
    #5808
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Looks good with the white letters.
  9. Sep 24, 2017 at 4:11 PM
    #5809
    iamjustifyd
    iamjustifyd Well-Known Member
    Sherry
    new orleans
    2001 PreRunner SR5
    I'm gonna take the flares off and have them painted. Should I take the dip off or just let them sand it off?
  10. Sep 24, 2017 at 4:18 PM
    #5810
    ChemDawg
    Maine
    2005 sr5 4x4
    :rolleyes::eek:
    Sanding dip wouldn't work well.o_O
    Just peel the dip yourself.
    Easy enough to do.:thumbsup:
    iamjustifyd[QUOTED] likes this.
  11. Sep 24, 2017 at 4:35 PM
    #5811
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    Will get off as much as I can, it's not peeling off so easily
  12. Sep 24, 2017 at 7:25 PM
    #5812
    Austin09
    Austin09 Well-Known Member
    Austin tx
    2016 Barcelona Red TRD access can LB
    T-Rex grill with black bezel. Blacked out all the badges and added the Tacoma on the tail gate. The windows have been tinted to the darkest law will allow.
    WD-40
    robssol likes this.
  13. Sep 25, 2017 at 4:02 AM
    #5813
    ChemDawg
    Maine
    2005 sr5 4x4
    Wd40..plastidip remover ...or respray more coats of pd on in order to peel in one big sheet.
  14. Sep 28, 2017 at 9:56 AM
    #5814
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    I tried the respray, worked better than before but still...what a pain. God some adhesive remover from work and it worked pretty well. Thanks!
  15. Oct 8, 2017 at 7:55 PM
    #5815
    work765
    work765 Member
    What finish did you use? Flat or satin? It looks great!!
  16. Oct 29, 2017 at 1:58 PM
    #5816
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    My derp journey is over. It was amazing.:bananadance:
    DubfromGA and robssol like this.
  17. Oct 29, 2017 at 2:04 PM
    #5817
    SilverJack
    SilverJack no one
    I always wondered how my rims would look in a darker color. Now I know, and I like it. Thanks!
  18. Feb 23, 2018 at 4:49 PM
    #5818
    501taco
    501taco Active Member
    Black plasti dip accents on Mt’s. Small amount of overspray on tires. 245C6F71-F153-4EEA-B3F4-F3E9B72879AE.jpgDADF46DD-89E9-4E88-9549-DB02AF9C3DA9.jpg
    msnk2u2 likes this.
  19. Feb 23, 2018 at 6:10 PM
    #5819
    msnk2u2
    msnk2u2 Active Member
    Florida
    2019 TRD Off Road 4x4 DC
    Bad Ass!!! :headbang:
    Btw, some WD40 will get that over spray off
  20. Feb 23, 2018 at 7:11 PM
    #5820
    501taco
    Thank you sir
