The PRINSU How To Thread
Discussion in 'PrInSu Design Studio' started by zscott, Jan 26, 2016.
  1. Dec 20, 2020 at 10:39 PM
    #561
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    LOL you guys make great points. I was mostly curious but now see the disadvantages of having a box...
    w.adventures likes this.
  2. Dec 26, 2020 at 8:08 PM
    #562
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    I mounted permanently so didn't want to use tie downs, and drilling holes in the bottom of case also provided a little security since a thief would have to somehow open/get into the case to take the nylock nuts off to remove the case from the carriage bolts/rack.
  3. Dec 28, 2020 at 8:46 AM
    #563
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The Roam boxes are designed to accept Yeti cooler tie-down options. For example, there's a Yeti bracket that can be used with a locking cable. Like everything Yeti, these accessories are pricey.
  4. Dec 31, 2020 at 7:37 AM
    #564
    bloodyclownsuit
    bloodyclownsuit Well-Known Member
    Ezra
    Portland, OR
    2016 DCLB TRD-OR Inferno (The Fire Trd)
    Yes that’s exactly it; the Tacoma prinsu is 47” inside-inside.
    If you need longer for the Land Cruiser, Yakima bars come in 48”, 58”, 66”, and 72” (if I remember correctly) so just get one longer than you need and cut it down.
  5. Jan 4, 2021 at 5:17 AM
    #565
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    What the best way to attach a harness that crosses from the driver's side to the passenger side? Black zip ties around one crossbar, with the harness underneath? I think that will be problematic for sliding mounts from side to side, zip ties will get in the way. Maybe mounts are not moved around that much?
    My Baja S1 lights are at the rear of the Prinsu rack, on both sides. Harness comes up the driver's side windshield. The S1 lights are switched together.
  6. Jan 4, 2021 at 5:24 AM
    #566
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could use something like these. Slide 3-4 1/4" carriage bolts in the rail (facing down), route the wiring and bolt these on. Or if just some self tapping screws right into the bar instead of carriage bolts. Or even something like this. https://www.amazon.com/dp/B00TE30LUI
    https://www.zoro.com/zoro-select-clamp-wocushion-galv-dia-14-in-pk50-co0409z1/i/G3495965/
    mrCanoehead[QUOTED] likes this.
  7. Jan 4, 2021 at 10:02 PM
    #567
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Try these. They clip into the underside T slots and you can run a zip tie through the clip to go either sideways or front to rear
    https://www.tnutz.com/product/ac-010-a/
  8. Jan 5, 2021 at 4:30 AM
    #568
    mrCanoehead
    Ottawa
    I like that right up to the point where they want US$45 to ship ten of them to Canada! I am going to look in the McMaster Carr catalog and see what's there.
    EDIT: these look the same
    https://www.mcmaster.com/47065T268/
    Further EDIT: I located them for $2 each plus shipping at:
    www.ipecautomation.com
    IPEC Industrial Controls Ltd
    17-109 Fernstaff Court,
    Concord, Ontario
    L4K 3M1
    P: 905.738.6688
    F: 905.738.6251
    bloodyclownsuit likes this.
  9. Jan 7, 2021 at 3:04 AM
    #569
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Canoe specifically?
    Not kayak as they usually transport differently with mounts etc. Canoes have to be upside down
  10. Jan 9, 2021 at 9:27 PM
    #570
    thatarmygreentacoma
    thatarmygreentacoma New Member
    Alex
    2020 Army Green Tacoma TRD PRO
    Tried looking through but couldn’t find much. Any recommendations on axe/shovel mounts for the side of the rack? Don’t mind putting one on each side if need be
  11. Jan 12, 2021 at 8:08 AM
    #571
    Papadeucer
    Papadeucer Well-Known Member
    Jack
    SoCal
    2019 Cement Tacoma Off-Road
    Quickfist?
  12. Jan 12, 2021 at 8:39 AM
    #572
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    It looks like the standard military pioneer tool rack would fit on top of the Prinsu.
    cbouch001 and gilligoon like this.
  13. Mar 8, 2021 at 8:33 AM
    #573
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    I tried this, the end of the rack was shaking like crazy off road. Looked like. Would bend or snap the rack (the side bits not the extrusion). I moved it back on top
    gilligoon likes this.
  14. Mar 10, 2021 at 5:37 AM
    #574
    Smoketown
    Smoketown Well-Known Member
    Tyler
    Frederick, Md
    2013 Barcelona Red DCSB TRD Sport
    Dude. First. Awesome write up. Second I just ordered the punches because I love how clean yours turned out. I also bought my rack from a TW member. Im not sure it needs painted but I definitely plan on giving it a good clean up. I have ordered the wind deflector with a 40" cutout as well.
    Thanks so much for this write up!
    pc3coyote[QUOTED] likes this.
  15. Mar 10, 2021 at 6:50 AM
    #575
    Smoketown
    Tyler
    Frederick, Md
    Has anyone made or found a mount that would work for mounting fishing rods or more specifically surf fishing rods on their Prinsu?
  16. Mar 10, 2021 at 7:03 AM
    #576
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Thule ski racks
  17. Mar 13, 2021 at 7:54 AM
    #577
    CoBackCountry
    J
    Colorado
    ^ this man speaks the truth
    Smoketown[QUOTED] likes this.
  18. Mar 19, 2021 at 6:29 PM
    #578
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Anybody running this rack without the fairing? I love the rack but not a big fan of the big fairing on the front. I was thinking of moving the first crossbar as far to the front as possible and removing the fairing altogether. I'm sure the noise will pick up a little, but I can handle that as long as it's not a whistle.
  19. Mar 19, 2021 at 6:35 PM
    #579
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not a prinsu, but a similar design. I installed a different brand rack for a friend and had to leave the fairing off due to a missing piece. He said it was the loudest thing ever and absolutely horrible until he got the fairing back on. Wouldn’t recommend.
    Tacoma13_NC likes this.
  20. Mar 19, 2021 at 6:38 PM
    #580
    Tacoma13_NC
    That's what I was afraid of. I guess I'll stick with the fairing for now, or maybe it'll grow on me since it's such a drastic change in appearance from the slick top. I saw a picture of one on here awhile back of someone running it without the fairing and it looked pretty good.
