The Pros and cons of wheel spacers
Discussion in 'Wheels & Tires' started by mjm540ii, Feb 28, 2012.
  1. Sep 9, 2016 at 11:34 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Under or over tightening can cause a stud to sheer off. That's about it. Or really crappy studs.
  2. Sep 12, 2016 at 6:38 PM
    Yote488
    Yote488 Member
    2002 Tacoma
    6in fab tech suspension lift 3 in body 488 gears
    Can I ask what the hub centric deal is?
  3. Sep 12, 2016 at 7:27 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I just ordered the venum. They appear to be just as good as the name brands. 1.25". I hear BORA makes good stuff if you can wait, theirs go down as much as 3/4".
  4. Sep 12, 2016 at 7:41 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Physics. Just physics. :)
    You lengthen the lever the tire has to use to stretch the studs, which makes it easier to bend/stretch/snap them. In a normal setup, the hub centers the wheel, and the only force applied to the hub is the stretching caused by the wheel hitting objects and transferring that energy to the studs. If you offset, you increase the length of the lever the wheel has to apply the stretching effect. As an example, you can probably tighten the lug nuts as tightly as you can pull them with a standard 1/2" ratchet handle. But with a 24" breaker bar, I can pop a stud off pretty easily because going from a 12" level to a 24" lever doubles the torque you apply through that lever. This same force multiplication applies to the ball joints as well. I knew a young kid that ran with 12" offsets on a truck with homemade hydraulics. Looked pretty cool until he called me for a ride home. When I got there, the front two wheels were apparently bent upward. But in reality, they had just pulled the bottom ball joint apart and dropped the frame to the ground in the front.
  5. Sep 12, 2016 at 7:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Wheel spacers also put more strain on the bearing, acting as a fulcrum extension it puts more strain on the bearing in a negative manor. The further out the wheels are, backspacing or spacer the faster they wear. It's not a serious issue but another con that should be listed.
  6. Sep 15, 2016 at 2:23 AM
    tamer
    tamer hamerworx.com
    NorCal
    Anyone have experience with the 3/4" BORA spacers? The 1.25" spacers push my wheels out just a little further than I'd like. I think the 3/4" may be more what I'm looking for. It would be nice if I could find a hub centeric 1/4" spacer. I literally just need a little push to clear my calipers.
  7. Mar 10, 2017 at 8:30 PM
    AbunaiTaco
    AbunaiTaco #AlohaTheTaco
    Luke
    Jet City
    '14 Taco Off-Road 4dr 5'bed
    ARB Bull Bar Warn VR8k RADFLOW Suspension, Front- Strait 2.5" Strut, Heavy valving and 660lb Eibach Coils Rear- Remote Resi 2.5" Fully Adjustable Shocks, Valved Heavier at base setting EMU Dakar ELO96R Heavy Leaf Pack W/Poly Bushings Wheelers Off-Road U-Bolt Flip Kit Ride Rite Airbag Kit With Daystar Bag Cradles FabTec UCA RCI Full Alloy Skid Plate Set RCI Diff Skid Wheelers Off-Road Extended Stainless Brake Lines BoRA 1" Front Bolt On Spacers BoRA .6" Rear Custom Spacers, With Lexus Studs that are .68" longer than stock. Cab Mount Chop Pinch Weld Custom Modification, *See write up soon. 3rd Gen TRD OR Rims 285/75R16 Goodyear Wrangler MTR Kevlar Tires Leer Xl100 Cap Full Force Metal Works Weld-On Sliders *Custom Design Bushwacker Fender Flares WeatherTec Floor Liners AVS In Channel Vent Visors Thule Full Custom Rack, With roof sliders and guide wires Rhino Rack Tracks on the cab and Leer Yakima Box Autana Sky4 Rhino Rack BATWING Awning Fab4 Rear Bumper, *Can't get rid of it soon enough Bunch of other custom home built bits
    Except, I believe a wheel that has less backspacing sends more force back to where the intended load was.....intended. This issue is exasperated with spacers that act like levers, like a pry bar, on the hub. Most quality wheels I've seen have stock backspacing or maybe 4" rather than 4.5". Mickey Thompson makes one with a 3.5" back spacing that I'm probably gonna get as I ran them on my XJ and they they were super tough. Currently I'm running 1/2" Baer Billet spacers with extended studs. If my theories are sound, I have little to worry about and shouldn't do any bearing damage. #justsayin
  8. Mar 13, 2017 at 10:52 AM
    djadonis206
    djadonis206 Well-Known Member
    2016 Black Tacoma SR5
    I put Bora 1" spacers on my 3rd gen about two weeks ago. On Bora's recommendation, I had them retorqued after some use. Then, on Friday I had them retorqued again to spec for my own peace of mind.
    I've put about 1000 miles on them over highway, country roads and mountain pass (with compacted snow and ice) conditions. Every time they were retorqued, there were no issues.
    Having said all that, I am planning to buy a set of SCS wheels once they come available.
    TLDR - I've 1" Boras on for about 1000 miles over various road conditions with no problems and regular maintenance.
    rudedog2008 likes this.
  9. Mar 13, 2017 at 11:46 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I had spidertrax 1.25" spacers for 3 years on stock sport wheels before switching to 4.5" backspaced aftermarket wheels. Both had the same leverage effect. Replaced my first set of wheel bearings after 120,000 miles. I'd venture a guess that with a stock setup, wheel bearings probably wouldn't last much past 150,000 miles anyway so it seems pretty negligible to me.
    Bishop84[QUOTED] likes this.
  10. Mar 13, 2017 at 1:14 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    You basically have 2 options when centering a wheel. It can be centered by the hub itself or by the lug nuts. In hub-centric, the inner bore of the center hole of the wheel is the same size as the ring on the wheel hub. The wheel then rides on this and is supported and centered by the hub.
  11. Jul 22, 2017 at 9:42 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Just want to make 100% clear in my feeble brain. Running a 4.5 bs wheel with a .75" spacer for example only, would be same amount of stress on ball joints ect. as a 3.75 bs wheel?
  12. Jul 22, 2017 at 10:40 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Yes, with additional mechanical joints and weight.
    Slvr14tacoma[QUOTED] likes this.
  13. Jan 4, 2020 at 5:02 PM
    Fredfifty
    Fredfifty Back in a Mini
    Dave
    Big Island - SF Bay Area
    99 5 Lug V6
    DJM 3/4 DJM UCA BJ FLIP CALMAX SHOCKS POLYURETHANE SWAY BAR BUSHINGS POLYURETHANE UCA BUMPSTOPS ROLLED FENDERS DJM 4 INCH ANGLED BLOCKS (STEEL) MINI C-NOTCH FROM ROHDE FABRICATIONS MJBTACO LOWPRO BUMPSTOPS CALMAX SHOCKS ROLLED FENDERS
    just threw on some 1.25” wheel spacers however i did not catch the brand. i went 31x10.5-15 and the rim was touching the brake caliper..so these spacers really helped.
