The RECTIFIED PreRunner Build
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRON, May 4, 2011.
  1. Apr 1, 2015 at 6:40 AM
    #3041
    XPOTRON
    XPOTRON [OP] Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Hell yea thanks man :thumbsup:
    Thanks brutha, for sure coulda been worse. And it would have happened on a dirt road at a much higher rate of speed in the middle of no where. Definitely lucked out big time, and I didn't really have to time to reflect on it since we left for camping hours after I got the newer ones back on
  2. Apr 2, 2015 at 8:18 AM
    #3042
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Pretty sure i'm subbd but I had to stop by cuz the rig is lookn badddd rigged up man!
    I've had similar issues with the expos... I dont think age has as much to do with it as we think.
    That failure you had is one of the main reasons I went to new beef lowers!!
    Also, :jellydance: of those clickdified ADS coilovers! If an when my shafts start pitting on my kings i'll be moving away from the bro-blue to ads :cool:
  3. Apr 3, 2015 at 12:54 AM
    #3043
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Thanks man! Yea I just have a lot of things I wanted to do and goin full SUA was way out of budget at the moment, but getting new expos would feel like a step backwards. I suppose I could get a Frankenstein mod done to em to gain more lift in the mean time....Andrew where you at?!:D
    Haha "clickdified" nice I like it! Do it man! ADS makes some superb quality shocks! If I could get a second job, Id be in there shop everyday :cool:
  4. Apr 3, 2015 at 7:56 AM
    #3044
    SconnieHailer
    Marc
    Yea, SUA and reworking the shock location again is too much work/$ for me and currently the Pelfrey kit is performing awesome. I may try Dakar's with the extra leaf when these are totally clapped out. Roughly the same leafpack thickness so my bumps should still bump me out at the right time. Plus the expos have never flexed well for me :notsure: They are limiting my droop by a bunch. If you can spring it a DMZ kit would be bitchn on you rig!
  5. Apr 6, 2015 at 5:34 AM
    #3045
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    I've been checking out a few builds that utilize the pelfreybilt shock hoop and paired with shackle flip kits they flex like crazy! Still need to do more research....and now save for LCAs and new Tires.................:eek:
  6. Apr 6, 2015 at 5:34 AM
    #3046
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    I really can't thank Andrew enough for all the hard work put into this tiregate! It performed flawlessly out on our Turkey Creek Campout last weekend:cool: It took me a week to recover from that tip! Still need to repaint everything, but here's the updated pics
    New Y-Bar installed and swingout action
    Side Shot
    As you can see it needs to be touched up, but from the bottom of the gate under the tire, you can see there are 2 mounting points/studs for the Y-Bar to screw into. The other mount point is for when the tire is inside the bed/opposite direction from where it's shown
    Only thing that may be necessary is to add some sport of spacer for the top heim joint. The tabs were welded wider than than the bottom ones to allow the gate to swing through them when the tire is flipped and mounted inside the bed. Also need to cut down the pins and find some orange plastic dip :D
  7. Apr 6, 2015 at 5:37 AM
    #3047
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Here's some more pics of the RTT Lighting Andrew hooked up for me! Absolutely love the output from these little LED bars from Amazon!:eek:
    First off is this little box he made entirely from scratch! Drilled the holes for the switches (Ambers of course;)) and wires coming out of it, then worked some magic inside.
    From that box, 1 wire goes along the tent to the center. Then the wire is ziptied to the center pole for the interior LED bar
    Let there be LIGHT!:cool:
    Zooming out shows the wire that is drilled through the bottom and silicone for the Ladder/Annex LED
    And a pic from below
    MOAR Light!
    Going back inside the RTT, this is a 12V accessory outlet that I originally bought from amazon. Again Andrew worked magic, so the red 12V power cord that extends from my blue sea 12v sockets in my bed is wired directly into it. This keeps both accessory outlets free :) It also has the original power wire running over to the first box with the switches, transferring the power once the main red wire is plugged in!
    Heres the main red 12V power wire running to the outside and into my bed sockets
  8. Apr 6, 2015 at 5:49 AM
    #3048
    Sefferston
    Sefferston I like Tacos.
    Seth
    Germany
    ZOMG B-RED!
    I've got that one thing, and that other one thing, oh yeah and that other other one thing.
    That's pretty genius. Gonna have to remember that later on...
  9. Apr 6, 2015 at 6:24 AM
    #3049
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    that's slick as shit..time to make that into a kit and sell that shit!
  10. Apr 6, 2015 at 6:34 AM
    #3050
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Hell yea! Andrew is pretty genius, I saw the setup in his RTT and had to have it :cool: Only difference with mine was he modified the 12V accessory box into the tent as well. Now I can plug in my 12V vacuum and clean up the interior, at night, while charging my phone, and keeping warm inside my 12v electric blanket haha:D
  11. Apr 6, 2015 at 6:52 AM
    #3051
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Yeah that will be nice. I often find it difficult to vacuum when my phone isn't charging and my blanket is cold :laugh:
  12. Apr 6, 2015 at 7:05 AM
    #3052
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    you have a vacuum for your tent that you bring with you?! oh man... :laugh:
  13. Apr 6, 2015 at 7:10 AM
    #3053
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Just bought it, black and decker pecker wrecker!:) haven't taken it out yet but I did use it to clean out all the sand in my tent haha. I don't know how it all got in there but a few AZ members had to get my drunk ass up into my rtt the first night so who knows:eek:
  14. Apr 6, 2015 at 7:12 AM
    #3054
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Dude and I forgot, theres 2 usb ports...so I can charge my ipod or play my Bluetooth speakers as well:D
  15. Apr 6, 2015 at 11:26 AM
    #3055
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Did you install the super bumps yet?
  16. Apr 6, 2015 at 11:53 AM
    #3056
    JeepAndrew
    JeepAndrew Nah bitch Jeep guy
    Andrew
    Tucson, AZ
    Offroad beast YJ/2015 Taco
    Lots-o-mods
    Currently working on that :)
  17. Apr 6, 2015 at 6:59 PM
    #3057
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Sure did!! Thanks buddy, I'm glad I installed before the camp trip too, all the weight in back was causing me to bottom out alot :eek: way better than those bricks all pro sells with the flip kit
  18. Apr 6, 2015 at 7:18 PM
    #3058
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Setup looks epic. :cool:
    You get your goodies in the mail yet?
  19. Apr 6, 2015 at 7:39 PM
    #3059
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Just woke up and gunna check right meow! :) Thanks tho buddy, love the hybrid on your truck now too!
  20. Apr 6, 2015 at 7:53 PM
    #3060
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm digging it too! I always liked the Brute Force Hybrid & this one kinda fell into my lap. :D
