THE RETROFIT SOURCE FX-R / Mini GROUP BUY (only need 10) ROUND 3
Discussion in 'Group Buys' started by ambiguous, Jan 28, 2013.
Thread Status:
Not open for further replies.
  1. Jan 30, 2013 at 10:47 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner and 2004 Lexus IS300 Sport Design
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
  2. Jan 30, 2013 at 11:31 AM
    AggiePilot12
    AggiePilot12 Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    Sub'd.. If this is still around in Mid Feb, I'm in. (rims/tires/leafs this weekend..$$$ haha)
    Would you like me to put my name down anyway and back out if I have to?
    -OR-
    Would you like me to wait until Mid Feb when I can buy, and THEN add my name to the list?
    Thank you for organizing this, ambiguous!
  3. Jan 30, 2013 at 11:37 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    1.ChamYota(Cam)BI-XENON MORIMOTO MINI STAGE III KIT (H1) XB35 4300K,Mini Gatling gun,H4/9003 Relay
    2.Ornithology (Aaron): Bi-Xenon FX-R 3.0 Stage III Kit (2.5" LHD), Morimoto 3Five bulb (D2S) and ballast: 5000K, E-55R shroud, 9007 Relay, Resealing glue.
    3. CdnKid - Bi-Xenon Morimoto Mini Stage III Kit (H1), Morimoto 3Five (35W), H1 XB35 6000K , Halos: No, Projectors: LHD, Glue: Yes, mini Gatling gun, H4/9003
    4. dually - Morimoto Mini Stage III (H1), 3Five 35w, 3fFive 5000k, YES CCFLs, lhd, YES GLUE, Gatling Gun (not mini), H11
    5.
  4. Jan 30, 2013 at 11:56 AM
    ornithology
    ornithology Active Member
    Haha...funny guy.
    It may be to the OP's best interest to just PM him so as not to clutter the original group buy thread with questions. Lots of good DIY articles available on here as well. But to answer your question, google sylvania product catalogue and they will tell you what type of bulb goes behind the dash. Then you can go to pep boys or eBay and buy the needed bulb and install.
  5. Jan 30, 2013 at 12:39 PM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    I think it's high time to buck up and do this mod! Although, I have a few questions... rather than PM'ing you I'm asking them here to help bump the thread and get some more interest.
    Questions
    1. what's the difference between 3Five and 5Five Ballasts? Do most people need the standard kit or the long cord kit?
    2. when I pick the bulbs do they have to match the ballasts? I'm assuming they do.
    3. As for the lens, do you have photos of 2.5" or 3" lenses? What is more common for the Tacoma
    4. Do you have pics of all the different shrouds on the Tacoma? is Apollo the most common?
    5. How do I know what relay I need?
    6. Whats the difference between the FX-R III, Mini H1 III, and Mini D2S III?
    I know the FX-R is supposedly better and also more difficult to install. what else?
  6. Jan 30, 2013 at 1:58 PM
    dually
    dually Low and slow
  7. Jan 30, 2013 at 2:08 PM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    5. DLee -Morimoto Mini Stage III (D2S), Morimoto (35W) 5000k D2S, no halo, LHD, GLUE: YES, SHROUDS: Apollo 2.0 (Full Circular), H4/9003 Relay
    6.
    5 more!
  8. Jan 30, 2013 at 2:15 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Answers in red.
  9. Jan 30, 2013 at 3:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  10. Jan 30, 2013 at 3:48 PM
    ChamYota
    Cam
    :drool:
    Which projectors did you opt for and any output night pics?
  11. Jan 30, 2013 at 3:57 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    D2S, 3Five ballast, upgraded to the Philip's burner (which is one of the 4300k the OEM's use).
    Cutoff and how it looks on the road shining on the back of another car....
  12. Jan 30, 2013 at 3:58 PM
    ChamYota
    Cam
    looks pretty dang good, im opting for the H1's with the upgraded XB35 4300k bulbs. Hopefully it works out well :D
  13. Jan 30, 2013 at 3:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    H1 has a bit more of a "hot spot" in the center of the pattern.
    Some prefer it, as they feel it sends more light down the road.
    I prefer a more even illumination.
    Careful on the H1 though... they are known for not lining up horizontally.
    Make sure you look through the lens and sight the edge of the cutoff shield and rotate the projector to make it horizontal and match up with the horizontal facets in the headlight's reflector.
    The mounting ring will likely need some trimming to get enough rotation.
    Then test mounted on the truck before sealing them up.
  14. Jan 30, 2013 at 4:02 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    If anyone wants QUALITY, bright headlights, I'd jump on this. I love my minis! Id go with the FX-R's if I had the money but my minis are the brightest lights on the road still :)
  15. Jan 30, 2013 at 11:35 PM
    #35
    ornithology
  16. Jan 31, 2013 at 3:14 AM
    #36
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Are you selling the blazer kit? If so, do you have a link to the kit?
  17. Jan 31, 2013 at 9:07 AM
    #37
    Slesse
    Kyle
    Port Coquitlam
    08 Tacoma
    Thanks for the answers ambiguous. Some follow up questions
    2. when I pick the bulbs do they have to match the ballasts? I'm assuming they do. No they do not need to match. So, whats the difference between bulb types? I get the colour thing, but whats the difference between the 3five, 5five type bulbs, Osram and Phillips?
    3. As for the lens, do you have photos of 2.5" or 3" lenses? What is more common for the Tacoma Go 3 if you don't want the chrome ring shown. Otherwise 2.5". What chrome ring are you talking about? What do most people get?
    Read up on TRS
    I know the FX-R is supposedly better and also more difficult to install. what else? FXR = wider, brighter, harder to install, requires cutting of the headlight bowl So the FX-R has a better beam patter, but requires some cutting of the bowl and the Mini's don't require any cutting?
    Thanks for your help.
  18. Jan 31, 2013 at 9:18 AM
    #38
    ambiguous
    Burt
    2012 DCLB TRD
    Sorry no blazer kits.
  19. Jan 31, 2013 at 9:27 AM
    #39
    ambiguous
    Burt
    2012 DCLB TRD
    Answers in red again.
  20. Jan 31, 2013 at 11:18 AM
    #40
    ambiguous
    Burt
    2012 DCLB TRD
    6. meidaros - Morimoto Mini Stage III (D2S), Morimoto (35W) 4300k D2S, no halo, LHD, no glue, SHROUDS: Gatling Gun, H4/9003 Relay
    4 more.
Thread Status:
