The Rotary Engine is Back
Discussion in 'Technical Chat' started by SigSense, Jun 28, 2014.
  1. Jun 28, 2014 at 6:23 PM
    SigSense
    SigSense [OP] Well-Known Member
    13 TRD Sport DCLB 4X4
    Did not know where else to post this, so here it goes. A California company has reinvented the Rotary engine. I used to have an old school RX-7 in the 80s, and that thing was FAST. But is ate oil and the mileage sucked. Evidently they have worked out the past problems..... would be great to have one in a Tacoma.
    http://www.foxnews.com/leisure/2014...pany-reinvents-rotary-engine/?intcmp=features
    California company reinvents the rotary engine
    The rotary engine could be on the verge of a revolution.
    California startup GoTek Energy has received a patent for a new type of motor – one that addresses some of the shortcomings of past rotaries, while promising better power and efficiency than traditional piston engines.
    I say traditional, because this rotary uses something called pivot pistons.
    Unlike the Wankel rotary engine made famous and famously killed by Mazda, with its pinched-oval housing and triangular rotor, GoTek’s DynaKinetic engine features a circular housing and a rotor that looks like a twisted ninja throwing star, creating four combustion chambers each fitted with a gear-driven piston resembling a flap that moves in and out to suck in and compress the fuel/air mixture as the rotor spins.
    There are still no camshafts or valves, the intake and exhaust ports are simply opened and closed by the passage of the rotor. GoTek CEO Steve Herbruck tells FoxNews.com it can be optimized to run on just about any fuel, with either spark or compression ignition.
    Another advantage of the circular design is that it does away with the offset rotor crank required in a Wankel, improving torque to a level that’s even better than a reciprocating piston engine. GoTek also claims to have solved the sealing issues inherent in the Wankel design that led to high oil consumption and poor emissions performance.
    The prototype is equivalent to a 1.5-liter four-cylinder, but is just 6 inches wide and 12 inches in diameter. The unit can be sized up and down, and several can be stacked together to meet different power requirements.
    Along with use as a vehicle’s primary motivator, the compact size and smooth operation of the DynaKinetic engine makes it appealing as an electricity generator, either on its own or as part of a plug-in hybrid powertrain. Mazda is considering resurrecting its rotary for a similar purpose.
    Herbruck says GoTek has had discussions with several major manufacturers about adopting the engine, but can’t reveal which ones just yet. And while it doesn’t plan to start building them until it has a customer lined up, he says its relatively simple design -- there are just 13 moving parts -- and use of non-exotic materials in its construction means GoTek can get a production line up and running in less than a year.
    The engine of the future? You might be able to take it for a spin soon.
  2. Jun 28, 2014 at 6:38 PM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Cool! Thanks for sharing
  3. Jun 28, 2014 at 6:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting.
  4. Jun 28, 2014 at 7:00 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    In fairness to Mazda, they didn't completely kill the Wankel until the end of the RX-8 run at the end of 2011 model year.
    Had it not been for European emissions standards, it would still be made.
  5. Jun 28, 2014 at 7:32 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  6. Jun 28, 2014 at 7:48 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I want to see one in a motorcycle! :D
    I love rotary engines, and would love to have a triple rotor in the taco.
    Aw9d likes this.
  7. Jun 28, 2014 at 8:14 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I had a 1989 Mazda RX-7 when I was a young adult. Lots of fun and close calls in that little sports car. I loved the fact that you could rev the engine to 9k RPM's without the worry of shooting a valve rod or piston thru the block! Working on the engine, I always wondered how difficult could it be to add one more rotary or to pair two of those engines together. I know Mazda did paired two engines once for a LeMans race. I which they could have done more or some one could have replicate it and put it on the market.
  8. Jun 28, 2014 at 8:21 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    They did make a 3 rotor (20B) engine from the factory, but it wasn't released in the US. Some half cuts made it in though.
    http://www.rotaryengine.com/services/34kits.htm
    http://youtu.be/tfOWmt7-zWg
  9. Jun 28, 2014 at 8:38 PM
    hladun
    hladun Well-Known Member
    Alberta
    Tacoma
    Yes, the answer....but what was the question?
  10. Jun 28, 2014 at 8:41 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Light weight it is. Go fast you will.
  11. Jun 28, 2014 at 9:05 PM
    hladun
    Alberta
    Tacoma
  12. Jun 28, 2014 at 9:40 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Ya and we had turbo and nitrous in WW1, but that doesn't mean it was attainable for the common dude. Do you think if we could get a compact triple rotor 650 HP motor capable of cranking out 14,000 rpm's reliably that was light enough for one guy to pick up that it wouldn't turn the automotive world on it's head? Now if it was mass produced and affordable... Sheee it man now we'd have something. ;)
  13. Jun 28, 2014 at 9:42 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    F1 is running a 1.6L V6 turbo hybrid making 800 HP
    not rotary though
    nevermind me
  14. Jun 28, 2014 at 11:30 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    This season of F1 is crazy, lots of new tech. The hybrid system coupled with a turbo 6 is insane, and insanely complex. You've got KERS harvesting power, and is an intragal part of the braking system, charging a battery that powers a motor that gives an additional 150? HP.
    Good to see Williams at the front again. Need better pit strategy.
  15. Jun 28, 2014 at 11:33 PM
    OZ-T
    Peter North
    British Columbia
    Not KERS anymore , now it's ERS , with 2 motor generator units ( MGU ) powering the battery . The MGU-K harvests kinetic energy under braking , the MGU-H harvests heat energy from the turbo charger , the electric energy accounts for approx 160hp of the 800hp the power units produce
  16. Jun 28, 2014 at 11:37 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    So... more power, but other restrictions keel lowering top speeds.
    The things are already pulling in excess of 5g.
  17. Jun 28, 2014 at 11:39 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I got this far...............
  18. Jun 28, 2014 at 11:41 PM
    OZ-T
    Peter North
    British Columbia
    If you are talking about F1 , the cars are faster this year
  19. Jun 29, 2014 at 12:12 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They can't allow that to continue.
    Look for new regs for 2016 that will pull them back down.
  20. Jun 29, 2014 at 12:17 AM
    OZ-T
    Peter North
    British Columbia
    Doubt it
    At this stage of the inaugural season with the V6 hybrids, they are slower by about 1-2 seconds in over all lap time when comparing 2013 laps to 2014 , but by reducing aero , the cars are slower in cornering but subsequently faster in a straight line
    oh , and they are also using 30% less fuel than 2013
