*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Apr 6, 2020 at 12:24 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I didnt.. but I have started using 303. I heard some people say that the latches break/get brittle..
  2. Apr 6, 2020 at 1:08 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    SR-71A likes this.
  3. Apr 6, 2020 at 1:42 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    fatfurious2[QUOTED] likes this.
  4. Apr 7, 2020 at 4:50 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not a ton you can do for frost unfortunately. As others said, you can pull the rain fly off if the weather is looking good, and crack open two or more windows to really get the air flowing. But at the end of the day you would need a diesel air heater to be totally dry. Its the only thing I have found that really works, because its always bringing fresh air into the tent. And that air is heated.
    I tired a Buddy heater - once. Then returned it. I knew I was going to end up kicking my sleeping bag up against it in the middle of the night which would probably set it on fire. The idea of a truck fire in the middle of the northern Maine woods in the dead of winter scared the shit out of me.. Also, worth noting that combustion necessarily gives off lots of water vapor. So its a bit of a gamble with a Buddy heater as to how much you'd gain from running it. It'll be warmer, but also much more humid.
    Edit: not to say Buddy heaters are a bad solution, just not for me and my scenarios. If you have an annex then I think they're pretty cool. You can leave it down on the ground below and not have to worry about kicking them
  5. Apr 7, 2020 at 5:18 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    I've always been afraid of using a heater in the tent. Fears of CO poisoning just seem too validated to me. In January I slept in my tent and the temps went down to 8 below zero and I was okay in my zero degree bag plus the blankets and comforter I use with the wife in the summer months. Maybe I'm too old school, but a heater puts you into the glamping category.
    Yetimetchkangmi likes this.
  6. Apr 7, 2020 at 5:41 AM
    SR-71A
    Zack
    Southern Maine
    Those Buddy heaters do have a low oxygen cutoff which is nice. As well as a really sensitive tip-over safety cutoff. But at the end of the day, its still glowing orange hot haha
    Armyhater458 likes this.
  7. Apr 7, 2020 at 6:44 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I just button things up and run mine for 10 minutes and shut it off. May have to do that again in the wee hours, but it's pretty dang hot after 10 minutes.
    uploadadventure likes this.
  8. Apr 7, 2020 at 6:48 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    I keep mine down in the annex on a table with a cookie sheet under it. My annex windows don't seal at the bottom so they let in enough fresh air, the heater pushes hot air out the top which heats the upper part of the tent nicely, and I keep a CO detector in my gear box which has a battery life of 7 years. I only run the heater if I absolutely need it and so far only needed it to heat up the tent before changing in the morning or at night. Layered blankets have help the best while hunting for a good set of sleeping bags.
    uploadadventure and YF_Ryan like this.
  9. Apr 7, 2020 at 7:28 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    We only run the Buddy for a few minutes while we get ready to hop into bed. Also turn it on for a while before we get outta our sleeping bags. The rest of the time we rely on our 0 degree and -15 sleeping bags. I sometimes use a liner in my 0 degree bag that is a huge help, and my wife actually uses a 12v heated blanket inside her bag.
    Edit: Here's the liner. Supposed to add up to 32 degrees F to your bag rating. Definitely adds a lot of comfort.
    https://www.amazon.com/Sea-Summit-R...ite+reactor+extreme+liner,aps,214&sr=8-2&th=1
  10. Apr 7, 2020 at 10:28 AM
    fatfurious2
    David
    Ashburn, VA
    thats what I was planning on doing. Getting a USB heated blanket, and running it off of a power bank
  11. Apr 7, 2020 at 10:33 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  12. Apr 7, 2020 at 10:54 AM
    jhmw815
    jhmw815 Well-Known Member
    Los Angeles, CA
    2018 Tacoma Trd Pro
    Freespirit Recreation 55" High Country Tri-layer sitting on top of Victory4x4 bed rack
    SummitBound and E-Paz 732NJ like this.
  13. Apr 7, 2020 at 11:17 AM
    YF_Ryan
    Kent, WA
    They make USB ones? that must be super low amperage. Ours is for a 12v socket. We have a 12v port that plugs into our Gooloo jump pack that she used to use. It would only run for about 15 minutes though, then shut off (some kinda internal thing in the Gooloo, cause it was to the second). But you could press the power button again and it would run for that period again. Normally that was fine, if she woke up cold, she'd press the button and go back to sleep. The sleeping bag keeping in the heat pretty well. Now though, we just plug it into our house batteries. We have two group 27 batteries in the truck bed. They'll run the blanket all night easily.
  14. Apr 7, 2020 at 11:26 AM
    fatfurious2
    David
    Ashburn, VA
    I was thinking about a 12v one, but the way I have my truck set up now, I only have 1 12v for my fridge. I know I could easily add more, but I wanted to try running things off of USB rather than 12v. I have a group 24m battery in my bed, that runs my fridge and future bed lighting.
    this one has been in my list for a while, but I havent dug into the specs..
    https://www.amazon.com/dp/B07GGWR9T...olid=2L5LSV7JABSIO&psc=1&ref_=lv_ov_lig_dp_it
  15. Apr 7, 2020 at 11:29 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    Picked up the duel boot bag and I almost wish I got 2 single ones. The single ones could slide into the channel of the bed frame where as the duel one attached to the ladder. Gonna play with it a bit more and find the sweet spot but here's come pics.
    MVIMG_20200404_124053.jpg MVIMG_20200404_124047.jpg MVIMG_20200404_124103.jpg MVIMG_20200404_124326.jpg
    Phessor likes this.
  16. Apr 7, 2020 at 11:47 AM
    YF_Ryan
    Kent, WA
    Here's a couple types of 12v adapters for jump packs. The first one is what we use, but with our Gooloo we do have the issue mentioned above about it shutting off. I'll also add it only shuts off with the higher draw of the blanket. My goal zero lights plugged into it ran for hours without turning off.
    https://www.amazon.com/GOOLOO-Cigar...oo+12v&qid=1586285083&s=sporting-goods&sr=8-1
    This style seems common, but apparently the Gooloo brand had a propriety size connector so I didn't try one of these.
    https://www.amazon.com/angel3292-Cl...p+pack&qid=1586284967&s=sporting-goods&sr=1-4
    And if you don't already have a jump pack you should buy one! they are great for charging cell phones, powering lights, blankets, etc, and of course for jumping a rig. We always have two with us when we go camping.
  17. Apr 7, 2020 at 11:50 AM
    YF_Ryan
    Kent, WA
    That blanket actually sounds pretty decent when using a quick charge USB port. I'll look into it. Our Gooloo has one of those ports on it.
  18. Apr 7, 2020 at 11:51 AM
    fatfurious2
    David
    Ashburn, VA
    I have a NoCo one. I should get another. I think it held its charge for a year. Then jumped the neighbors F250
  19. Apr 7, 2020 at 12:49 PM
    fatfurious2
    David
    Ashburn, VA
    I ordered some Kydex.. we will see how things go. Planning on cutting the sheets in half, so I'll have four 8x6 pieces
  20. Apr 7, 2020 at 4:45 PM
    Subway4X4
    Lloyd
    NY/NJ
    YF_Ryan[QUOTED] likes this.
