*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Apr 12, 2020 at 10:31 AM
    SummitBound
    SummitBound Well-Known Member
    Greenville, SC
    2019 T4R OR
    Thank you!
    jubei[QUOTED] likes this.
  2. Apr 12, 2020 at 10:47 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :thumbsup:
    SummitBound[QUOTED] likes this.
  3. Apr 12, 2020 at 11:24 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    It's definitely possible. What I was surprised at, and you likely will be too, is how thick and heavy the annex material is. It's really heavy and hard to work with. So while I think those clamps will work, it won't be easy or prefect.
    Like you, we wanted the annex for our dog that is too big to carry up the ladder. We quickly got tired of the annex getting full of rain and mud, and now if there is any rain in the forecast the dog sleeps in the cab. All this, plus doubling our storage space, is why I ultimately sprung for a cap.
  4. Apr 12, 2020 at 11:29 AM
    Mitch65
    Mitch65 Well-Known Member
    maybe I’ll just get a full height bed rack. The RCI 18” looks pretty solid so I may just get something like that. This way I’ll be at 74” which should work well with the annex
  5. Apr 12, 2020 at 11:42 AM
    littlefish
    Hudson Valley NY
    There's a lot to lose when you go that high. I know the price different is major, but if you're going to put the tent that high and and be above the height of the cab, you're better off spending for a cap. Otherwise your tent is just as high, but the contents of your bed are exposed and you lose a lot of valuable space.
  6. Apr 12, 2020 at 2:13 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Check out BAMF or Bruteforcefab. With Bruteforcefab, the rack bolts to the bed bolts. Also you can pay half down, and then half plus shipping when its done.
    This is the BAMF before I modified it
  7. Apr 12, 2020 at 3:00 PM
    Mitch65
    I think im g
    I have decided im going to mid height. Either the Yakima Outpost HD with the side bars its 13" or the RCI 12". Hmmmmm decisions decisions.
  8. Apr 12, 2020 at 4:57 PM
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    is that the 18in height rack or 12?
  9. Apr 12, 2020 at 5:12 PM
    fatfurious2
    David
    Ashburn, VA
    Looks like a 12. My rack a few posts back is 13" above bedsides
  10. Apr 12, 2020 at 5:13 PM
    littlefish
    Hudson Valley NY
    This is where I am with the lowest KbVooDoo rack. Why the annex? Just the dog? The only time I use the annex is if the dog is with us and I try to find any other way. Either leave him with the in-laws or let him sleep in the back seat. Took out the rear seats and built him a platform anyway:
    f
    BattlecryTaco likes this.
  11. Apr 12, 2020 at 5:24 PM
    moser633
    do you have a picture looking into the bed from the rear? im torn between full height rack and mid. dog likes to hop back and forth thru the window but also limited on garage clearance.
  12. Apr 12, 2020 at 10:43 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Ok I have that exact Harken Holster set and its been sitting in my garage for 5 months.
    Any tips/tricks?
  13. Apr 13, 2020 at 6:55 AM
    jubei
    NoCo
    Stuff. Also things.
    Measure, then measure again and then measure again after that :) It really wasn’t that bad of an install, but you do need to really game plan well before you starting drilling into the trusses.
    The big issue is how far you have from the organizer pulleys that collect the four drop lines to the side of the block and tackle where the drop lines connect. That dimension dictates how much vertical lifting range you can get out of the hoist. It’s kinda hard to describe in words, but it makes sense once you lay it all out and start measuring. Good luck!
  14. Apr 13, 2020 at 7:51 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I wrote up my install; used the same hoist... Make sure you get the 200lbs one - the others won't be enough. You can sometimes find cheaper on eBay.
    Garage Hoist - Winter Weight Loss for AdventureTaco
  15. Apr 13, 2020 at 7:51 AM
    turbodb
    Dan
    PNW
    AdventureTaco
  16. Apr 13, 2020 at 10:59 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Had a friend with a rack that had very similar height. We took one of the rainfly rods and bent it creatively to curve around the cab just right without touching it but still extend out that corner of the side awning. It was a funky looking piece but it did the job and even in the wind it didn't touch the paint on the cab. Those rods are pretty cheap to replace a set so I'd say bend away and make it work for you. Or go to your local hardware store and get some steel stock rod in the same diameter and make a custom one so you don't bend up one of the ones that came with the tent. Or, just leave that awning closed with the grommets and toggles and just use the other 3 which will provide plenty of airflow.
  17. Apr 17, 2020 at 9:04 AM
    Lygrin
    Lygrin Well-Known Member
    Mark
    Tacoma, WA
    2019 Cement Tacoma TRD Off Road 4x4
    Apologies ahead of time if this has been asked! I scoured through ~100 pages and searched, but couldn't find anything.
    I recently put in an order with CVT for one of their co-branded Bush Company Alpha series RTTs. The mounting tracks on the tent run width-wise/left to right/horizontally which would be parallel to my prinsu rack load bars. Does anyone have any idea how it would be best to mount the tent? Would I be OK to buy a set of the 1" tent mounting feet from Prinsu? They seem to be designed for tracks running the traditional direction.
  18. Apr 17, 2020 at 9:18 AM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    They sell a couple different brackets on their website. Link, Link
  19. Apr 17, 2020 at 9:21 AM
    fatfurious2
    David
    Ashburn, VA
    Kydex comes today. Im boycotting Amazon until the covid blows over. I could have had so many things on prime, and projects done sooner, but they set their shipping bar so low.
    if anyone is ordering things, check ebay or an actual online store first. So many of the similar things available elsewhere.
    I just ordered an "amazon awning" on ebay, and saved a few $ too. Should be shipping soon. Or at least ebay told me guaranteed delivery by 4/23.. so we shall see.
  20. Apr 17, 2020 at 9:24 AM
    Lygrin
    Mark
    Tacoma, WA
    Now I feel dumb. I looked at the extensions and couldn't originally process that it would work for my application.
    Thanks!
    NukedTaco[QUOTED] likes this.
