*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. May 22, 2020 at 6:36 PM
    Rawdoggy
    Rawdoggy Well-Known Member
    ahh, oh well. Thanks!
  2. May 22, 2020 at 8:03 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    What’s the verdict?
  3. May 23, 2020 at 12:49 AM
    HarrisonHopper
    HarrisonHopper Well-Known Member
    Trev
    British Columbia
    2014 Tacoma Trd Sport
    OME 886, Dakar HD leaf, SPC upper control arms, Sport Nitrochargers, full coverage skid plates, Westcan Overcanopy Rack, RTT, Total Choas Bed Stiffners, Durabumps Bump Stops, 275/70/17 KO2, Arb awning.
    Picked up our Tupei Autana XL ruggedized about 2-1/2 years ago. We have used it for tons of road, fishing, hunting and offroad adventuring trips. Spent about 90+ nights in it. 3 adults up top is a little cozy but it works.
  4. May 23, 2020 at 5:24 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Tupei Antenna XL :rofl:
    HarrisonHopper likes this.
  5. May 23, 2020 at 5:27 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    My first night was awesome. So comfortable!
    Armyhater458 likes this.
  6. May 23, 2020 at 5:38 AM
    Lygrin
    Lygrin Well-Known Member
    Mark
    Tacoma, WA
    2019 Cement Tacoma TRD Off Road 4x4
    I'm making the switch this summer. We had a CVT Mt Shasta, but after a long trip and being on the move almost daily we decided to go for simplicity of setup and teardown. I've pre-ordered the CVT branded Busch Company Alpha tent which should be coming in next month.
    H3llRid3r[QUOTED] likes this.
  7. May 23, 2020 at 6:18 AM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    I had a similar situation with my RTT when I replaced the bed rack with a KB Voodoo Taco Max. I have the mounting rails running parallel with the cross bars. Fortunately, the rails lined up perfectly with the slots on the cross bars. I ditched the steel mounting plates and used thick fender washers instead to distribute the RTT’s weight more evenly. The mounting bolts are about 12” apart from each other on each side. The RTT has not budged one bit.
    FreshPots[QUOTED] likes this.
  8. May 23, 2020 at 7:35 AM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Thanks for the reply! I got the specs from 23Zero and the mounting rails for the tent will fit just fine with the pre drilled slots on the rack.
    Can't wait for it to get here. Just 2 months lead time :annoyed:
  9. May 23, 2020 at 10:26 AM
    HarrisonHopper
    Trev
    British Columbia
    Ahhh the wonders of spell check I didn't even catch that. That being said we always get great phone receiption in there. Corrected :thumbsup:
    fatfurious2[QUOTED] likes this.
  10. May 23, 2020 at 11:28 AM
    Daddy_Firebird
    Colorado
    Better late than never.
  11. May 23, 2020 at 12:12 PM
    fatfurious2
    David
    Ashburn, VA
    Since I couldn't meet up with @disconnected , had to open the tent up in the driveway..
    uurx, disconnected, H3llRid3r and 4 others like this.
  12. May 23, 2020 at 6:01 PM
    H3llRid3r
    SLcUT
    Nice! That is the one I have my eye on. What rack are you going with?
  13. May 23, 2020 at 8:39 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Cap cage is 90% done. Tomorrow I’ll weld the feet on and then decide if I’m bolting to through the bed I also need to set the angle for the back legs. Im also going to put 4 1” pieces of unistrut across the legs to mount my hi lift, shovel and axe that’s just been sliding around the bed and not the bed mat for the feet.
  14. May 24, 2020 at 12:18 AM
    HarrisonHopper
    Trev
    British Columbia
    Something I just discovered was that the bushings between the truck bed and the frame are kaput! Flattened to dust and making noise. Thinking of going with the tougher polyurethane bushings. Never even entered my mind that would be an issue down the line. You all might want to check yours.
    Newlife likes this.
  15. May 24, 2020 at 7:23 AM
    Lygrin
    Mark
    Tacoma, WA
    I have a prinsu rack over both my cab and my canopy topper. I ordered the little 1" tent feet just in case I have clearance issues.
  16. May 24, 2020 at 11:54 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Was just under mine removing my air bags and installing Dakars. Yep. Mine are done too.
  17. May 24, 2020 at 11:54 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I need to order them as well just incase.
  18. May 24, 2020 at 8:50 PM
    DreaminOfTacos
    DreaminOfTacos Member
    Hey where did you find them for $550 in Canada? Cheapest i can find them online is $650 through overlandoutfitters.ca
  19. May 25, 2020 at 12:56 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Decided at the last minute to order a bigger rtt. We have a travel trailer and measured the bed in it. 56x 82 inches. So if we’re spending the money might as well get a little bigger and be comfortable. Upgraded to a 3+ at 72x96 extended. Same time frame on availability and same color as what we originally bought.
    WoodsGhost and disconnected like this.
  20. May 25, 2020 at 1:16 PM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    I catch on quick,
