*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Oct 19, 2021 at 2:53 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I'm embarassed to say I never even considered tying off that last window with paracord...maybe it's time for me to get a roof rack
    sounds like some great customer service as well
  2. Oct 20, 2021 at 6:05 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I use a bungie cord. They have some give, and they already have hooks on both ends. I just keep it in the rear door pocket on the driver's side.
    Pyrotech[QUOTED] likes this.
  3. Oct 20, 2021 at 9:49 AM
    psychic_legume
    psychic_legume Well-Known Member
    2002 White Tacoma TRD
    Call me dense, but does the bug mesh not unzip on the front window? Or you could stand on the tire and lean over the roof rack?
  4. Oct 20, 2021 at 9:51 AM
    TacoTyusday
    Zac
    San Diego
    both work, the issue i have is that the base of my tent is lower than the cab, so I can't get that second tension rod into the hole to keep the overhang pushed out on one side lol.
    Pyrotech likes this.
  5. Oct 20, 2021 at 9:52 AM
    psychic_legume
    Oh, yeah I see. the pole hits the cab. duh, sorry
    TacoTyusday likes this.
  6. Oct 20, 2021 at 5:19 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    OVS does have good customer service.
    Looking at your pictures, your ladder should be more vertical to take the stress off from the middle joint. With a shorter bed rack, you need to drill additional holes into the ladder for that to happen. The OVS instructions does leave a bit to be desired but the Smittybilt one(same tent) lays this out.
  7. Oct 21, 2021 at 6:53 AM
    Pyrotech
    Pyrotech Well-Known Member
    Thank you for the info.
  8. Oct 21, 2021 at 9:19 AM
    MaineFarmer
    MaineFarmer Well-Known Member
    Maine
    2018 TRD Off-Road
    Added a bunch of stuff. Cut to fit 285 AT3’s
    I’m gonna have to look for some toggles to build up some cords to keep my truck side open.
    Anyone have a good solution to the side that I have my awning on? So far I have yet to figure out how to get the forward stay to tension the rain fly.
  9. Oct 21, 2021 at 1:38 PM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    lmao have fun replacing that floor panel.
    Hopefully its the whole half piece and not that thin aluminum sheet. its a pain in the ass.
    Makes me want to buy the versions with diamond plate. The thin aluminum is soooo thin
    H3llRid3r likes this.
  10. Oct 21, 2021 at 1:42 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Sub'd.
    Ed
    dpele likes this.
  11. Oct 21, 2021 at 1:44 PM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Yeah good point. I set mine up pretty vertical like this
  12. Oct 21, 2021 at 1:46 PM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    cut a hole in the awning? ;)
  13. Oct 21, 2021 at 2:03 PM
    Nessal
    Texas/Bay Area
    Per smittybilt it should be no more than 20 degrees. Additional 3/8" holes needs to be drilled into the ladder.
    I have a mid height bed rack like yours and I had to drill my ladder. In fact, I actually drilled 3 additional sets so there is more flexibility. I believe the ladder is actually essential to spreading the load so that it's not all on the center joint where it fans apart.
    Pyrotech and sdshack like this.
  14. Oct 21, 2021 at 3:40 PM
    MaineFarmer
    Maine
    2018 TRD Off-Road
    I’ve been tempted a few times… seems like it kinda defeats the purpose though.
    dpele[QUOTED] likes this.
  15. Oct 22, 2021 at 11:11 AM
    MaineFarmer
    Maine
    2018 TRD Off-Road
    Anyone own a OVS nomadic 3 and find it a complete PITA to remove the hoop that supports the entry area every time you break down the tent?
    Maybe I’m missing something but when I called them to try to figure it out they also didn’t have a better idea
  16. Oct 22, 2021 at 1:19 PM
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    I've searched and I'm having no luck.
    Is anybody running a Roofnest Sparrow XL on their bedrack? I can only find this setup. but it's the older x model and not sure the dimensions.
    https://www.tacomaworld.com/threads/roofnest-sparrow-x-hard-shell-roof-top-tent-sold.601100/
    I'm contemplating replacing my current Yakima Skyrise 2 with this one, but have a batwing and curious to know how the setup is. Im thinking I'd have to order these mounts as the XL is 61" long with my loadbars being ~55"
    https://www.uptopoverland.com/products/straight-up-side-mount?variant=37668098408613
    Thanks!
  17. Oct 22, 2021 at 1:31 PM
    sdshack
    sdshack Well-Known Member
    TN
    ‘18 Tacoma OR 6MT (SOLD) - ‘99 4Runner Limited - ‘10 Cayenne TSSY - too many BMWs
    The post you linked says the Roofnest X model was replaced with the Sandpiper — Google says the Sandpiper is slimmer than the X, but nothing about other measurements.
    Sandpiper dimensions are reported between 47-50”W x 82-85”L depending on the source I looked at. Hope that helps.
  18. Oct 22, 2021 at 3:29 PM
    Nito
    Portland, OR
    Thank you for that @sdshack . With that help I dug deeper and found the older Roofnest Eagle is closer to size (58") to the XL (61"). I guess I never realized how many discontinued models Roofnest has.
    Would still like to see some pics of the Eagle or the Sparrow XL mounted with an awning.
  19. Oct 23, 2021 at 8:58 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Went from this ⬇️
    To this
    When we decided to get a roof top tent, I new I wanted it to be fast deploy and able to hold the bedding and as light-ish and low as possible, but able to carry the kayaks if needed too, as the wife loves kayaking. So we settled on the two channel CVT Mt Hood medium.
    But when I ordered it, I knew I was gonna pull my Front Runner roof racks and just use two 48” 1020 8020 extruded aluminum slats and low profile (1/2”) feet from prinsu. Apparently I had it in my head that they came in sets of 4 or something so the week of our Moab adventure
    the shit arrived and I didn’t have enough feet. I needed 2 pairs of feet from the load bars to the tent and 2 pairs of feet from the tracks on my camper shell to the load bars. Since I didn’t order enough, I had to use feet from my front runner roof rack.
    As such the tent was about 4 1/2” above the cab. Which was ridiculous. Those feet were 2 7/8”. The new ones are 1/2” so the tent is now a bit lower which I love. The tent is 1 1/2” over the shortened shark fin antenna and 2 1/2” over the cab.
    But from personal experience hard wheeling I know that bed only flexes about an inch independently from the cab.
    So I may ending up fabbing an even lower profile solution. Although now I can fit my arm under there to check bolts and I may not be able to do that logically with a lower profile set up.
  20. Oct 25, 2021 at 8:52 PM
    KingZee
    KingZee Well-Known Member
    Z
    Los Angeles
    2018 TRD OR
    Bootleg Pro Grill / 16” SCS Ray 10 Black / 265/75/16 KO2s / Voodoo 10” Rack / DA Warrior XL
    It was cool, a bit crowded the weekend we were there but that’s what happens when most of the rest of SoCal is on fire lol
    BattlecryTaco[QUOTED] likes this.
