*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Feb 10, 2022 at 9:27 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    No zipper on the cover? SOLD!
  2. Feb 10, 2022 at 9:55 AM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Last summer I bought the CVT Mt Shasta Hybrid. I got a significant discount because it was an older generation design. The top of the tent when stored has the matte black diamond plaiting with two rails mounted to it. The cover itself wraps around only the sides of the tent, leaving the top exposed. Near the top, there is a Velcro strip with a zipper underneath, this runs on all four sides. The tolerances on this are very tight and its a pain to unzip and zip under the Velcro strip. The bottom of the tent cover has elastic band with adjustable ties and clips at all 4 corners and in the middle on each side. It also sucks I cant keep the ladder attached with this design.
    I found a mom and pop automotive shop near my house. I took them the tent and am planning to try an new custom cover that wraps the whole tent (top and sides).
    Here is what we discussed...
    The tent would be made out of black marine grade fabric. It would be the size for the tent when closed with 3" extra on all 4 sides. The ladder will be permanently attached under the top part of the cover. Two ratchet straps would be used on both sides of the ladder to hold the ladder down and to keep the cover from blowing when traveling. The bottom of the cover will have an adjustable string sowed within the cover to tighten the bottom portion. We would utilize the 8 clips on the bottom (4 corners and 4 sides) just as the existing design did. The cover will be made sometime here within the next month or so. I will update with some photos and share my experience. Hopefully I have thought this out enough and it will work well.
  3. Feb 10, 2022 at 11:07 AM
    E.J.
    Josh
    NWA
    I don't think that zipper is intended to be used for opening the tent, isn't that what the buckles underneath are for?
  4. Feb 10, 2022 at 11:30 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Wow, and now we have come full circle -- making a cover for a design that eliminated the cover. Wondering if they changed this on the newer generation. Good feedback. The cover doesn't bother me that much and I've got plenty of life left on my tent, but I would consider a hybrid just for more convenience when the time comes. Not sure about some of the trade-offs, though.
  5. Feb 10, 2022 at 11:54 AM
    themcnertney
    Dan
    Akron, OH
    This is basically a bit of a trial and error. Before purchasing from CVT, I was warned that the tolerance was very tight and it was difficult to remove the cover to open and close the tent. We shall see if this experiment works, if not I can always go back to what I have.
    You're correct. I don't believe it was originally designed to have the zipper completely removed, rather just pull up all four sides and let it hang. This however is near impossible without removing the zipper, at least it is on mine.
    The majority of the tents I have seen, have the zipper on the bottom and the Velcro overlap covers that, right? Then two straps wrap around the whole cover one both sides of the ladder? This is my intention with the new design only replacing the zipper with an elastic rope at the bottom and using the straps to hold it in.
    I'll try to get some photos when I get around to it.
  6. Feb 10, 2022 at 12:12 PM
    E.J.
    Josh
    NWA
    Yes that's how most of them work. Sometimes it's a major PIA to zip them up, especially if you've got a lot of bedding stowed in the tent, though if the sides were a little taller it would help a lot.
    themcnertney[QUOTED] likes this.
  7. Feb 10, 2022 at 12:46 PM
    E.J.
    Josh
    NWA
    I think if I do go for a hybrid I'd skip the extended fly this time around, it's been two years since I zipped the annex on my current tent. Seems like the standard fly would pack away easier because of less material.
    Edit: well once in the last two years, but yeah.
  8. Feb 10, 2022 at 1:17 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Yes no zipper lol. Some buckles that I never use. I just slip cover over and boom done
  9. Feb 10, 2022 at 4:04 PM
    themcnertney
    Dan
    Akron, OH
    The tent is hoisted up in the garage so it’s tough to get some good photos.
    6BA93335-B61B-48C8-9F09-4D9EF8C4B94A.jpg B3CCE6DD-E1C3-4778-A0C4-C94880FE147A.jpg 424A4161-55E8-4216-BFA5-587BCC1ECA15.jpg A7BD3614-6345-4D83-9C66-42E90073C3EB.jpg 9A0EE9E9-2EF6-4304-8A1A-2B6E39273DED.jpg
  10. Feb 10, 2022 at 9:40 PM
    dyorge71
    dyorge71 Member
    dyorge
    Winnipeg, Manitoba
    silver tacoma 2017
  11. Feb 10, 2022 at 10:40 PM
    Relyk711
    Relyk711 Well-Known Member
    Kyler
    Santa Cruz
    2018 TRD Pro Black - 1999 Pre-Runner Black
    Alucab Canopy Camper BAMF HC Dual Swingout Rear bumper BAMF Sliders Westcott 1.5" TRD pro lift Icon RXT option3 leaf pack Rago HD Shackles & Hangars BFG KO2 285/75/16 CBI T3 Aluminum front bumper Warn EVO 10S Total Chaos Bed stiffeners Home built Aluminum HDPE bed platform.
  12. Feb 10, 2022 at 11:38 PM
    Relyk711
    Kyler
    Santa Cruz
    It's been a while since I've lurked this thread but I have found it useful at different times so I figured I'd give my unwarranted .02 back ;). I'll try and list the maybe not as obvious or maybe obvious pros and cons of my experiences
    Probably an unusual situation but my typical trips include either myself and 2 dogs or my significant other and 3 dogs. The dogs pose a particular challenge as really they take up more room than tiny humans, or at least we permit them more room in my DCSB. I am 6'1~6'2" my lady is 5'6" and our dogs are 50, 55 and 85lbs.
    Softshell life. Back in late 2019 I purchased a Tepui Kukenem ruggedized 3 and it had a lot to love. Coming from a Coleman 4 person tent or sleeping in the back of my old 3rd gen 4runner the treefort experience of a RTT was novel and fun.
    Pros:
    1. Dimensions: HUGE footprint when unpacked. Definitely would have no problems with 2 adults and a child or even 3 cozy adults, 2 adults and a dog. My lady wasn't too thrilled with the mattress as she's mostly a side sleeper, an early hack we found was a 1" memory foam topper from Amazon for $30 was more than acceptable.
    2. The folded over diamond plate is super clutch! I was able to stick magnet lights to the truck and reflect them off the bottom creating abundant and diffuse light. Combined with a small 5ft awning off the cab, the covered area was roughly 4ft x 9ft. This was an epic cabana in the high sun or in many cases the light to mid rain.
    3. The folded footprint also offers more versatility with a bedrack than my later setups. I was able to mound rotopax on the side, outside the rack and canvas topper as well as a DIY roadshower off the back. This was all supported by the stout bedrack and not reliant on tent mounting. While pretty heavy, even without bedding, my girlfriend and I were able to muscle it off the rack a few times when we knew we didn't have trips for over a month.
    Being 55" by 48"ish gives full access to run larger roof boxes length wise which matches generally how their latches work.
    With the awning poles and many windows, soft shell tents do breath much better. In high heat or cold, condensation was never an issue, nor getting ventilation of heat. We had one trip with 95 degree nights which a battery powered fan and having all of the windows open and rainfly off made... almost pleasant. Almost...
    With a hard topper over the bed, you lose some functionality, windoors don't open all the way, generally not as many ways to mount more stuff to the cap etc.
    Cons (Less original issues here)
    1. MPG and driving feeling. 3-4 mpg hit having it above cab height and it definitely feels like a sail up there. Switching from Thule roof crossbars to a 80/20 roof rack and Plano boxes gave me back almost a whole 1mpg back and felt better at highway speeds. For me it's not so much the idea of worse gas mileage as the feeling of fighting the square sack on the roof at 70 MPH. Can I drive slower? Yes... Sometimes... Sometimes in California or Nevada 70 is pretty much as slow as you can go safely.
    2. Setup/teardown time.... In the heat... In the rain... In the cold. Full disclosure, we are notorious for arriving at camp in the dark. This amplifies this issue considerably, as it's much less fun folding fabric or fiddling with tent poles in the dark.
    3a. Major one for me. I am a very light sleeper. Soft shell tents flap in the tiniest amount of wind. On occasion I tried to be lazy after arriving to camp late and not pu the poles out for the rainfly. Generally they will flap like a mofo in the even 5-10mph winds. It is much much better with the poles all out but that definitely adds to the setup and teardown inconvenience.
    4. Weight
    The 3 person ruggedized with bedding, ladder, etc was probably pushing 180lbs and it felt like it on the roof.
    I suppose I'll break this up in 2 posts as it's getting long... To be continued, spoiler alert. I went hardshell.
    dpele, Brownie_Man and themcnertney like this.
  13. Feb 11, 2022 at 6:17 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was also looking for a budget friendly solution to an anti condensation mat so I didn't have to shell out the cost of the one designed for a tent and the consensus between forums was just buy the actual anto condensation mat designed for your tent. It's a perfect fit, works great and folds up nicely in the tent, assuming you have a soft shell. I would try something like you linked if I had a wedge since the floor doesn't move at all, but anything that folds I would opt for the manufacturers mat.
    Wishbone Runner likes this.
  14. Feb 11, 2022 at 6:22 AM
    themcnertney
    Dan
    Akron, OH
    I came across this product that I am thinking about trying.
    https://www.mattressinsider.com/mattress-condensation-prevention.html
  15. Feb 11, 2022 at 6:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The kicker there is it's only 39" wide, so you would need two strips of it. Softshell tents are roughly 8' long so you're looking at 16 linear feet, or $160+shipping. At that point may as well buy the manufacturers mat. I paid $158 shipped for mine off of Amazon a year ago but I don't know what they're going for now.
  16. Feb 13, 2022 at 1:33 PM
    JarrettaBerretta
    JarrettaBerretta Member
    2021 Army Green Tacoma TRD Sport
    Technically an owner..
    Just threw down on a 14" kb voodoo rack, 58" with bakflip mounting brackets (adds 2 1/2") and a 50" CVT MT Hood. Hoping my math and research is all going to work out. Any body out there have a similar set up? Will be posting pics on set up and everything, for now the shipping waiting game begins.
    being mounted to a dclb
  17. Feb 15, 2022 at 8:18 PM
    CherokeeCajun
    CherokeeCajun Well-Known Member
    KJ
    Oklahoma City
    2017 - MGM - Sport - 4x4
    CVT having a sale I didn't know about??
    Finally got my UpTop mid height bad rack ordered and now need the RTT before camping season. After endless thread searching it seems like hardshell is the way to go. Mainly because it's just my wife and I sleeping in it and it's just a place to crash (don't need head room or space for card games or anything.
    The only negative thing I can find on hardshells (other than being more expensive) is the weight. How heavy is too heavy for two semi-strong people to put it on and off a bed rack? Looks like there are some soft shells that can weigh just as much but I'd rather not have to use some kind of pully design. TIA!
  18. Feb 16, 2022 at 5:08 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Getting it on and installed once is not the problem. You can always muster up enough manpower to get it up there and installed. Weight and install difficulty only really matter if you want to remove it whenever you're not using it. That's where the pulley system really shines because your friends will help you once, but they won't want to do it at the end of every weekend.
  19. Feb 16, 2022 at 5:12 AM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    I'm anxious to see if I'll need to make one when I mount the ovs mamba 3. If the mpg isn't terrible I may not bother
  20. Feb 16, 2022 at 5:16 AM
    littlefish
    Hudson Valley NY
    It depends how you use your truck. I don't daily mine, so it really only sees use on the weekends. And a lot of the time I'm camping or at least hope to have time to camp. I used to take the tent off a lot more than I do now. Even with a pulley system it just became more trouble than it was worth. Now if I drove the truck everyday or lived/worked in a rough area my story might be different.
    codyjphoto[QUOTED] likes this.
