*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Feb 2, 2015 at 9:16 PM
    #2841
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I haven't either but I want to, next time I have the tent on the truck I will
  2. Feb 2, 2015 at 9:18 PM
    #2842
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Those fiberglass bedsides will hold up well with that weight on top?
  3. Feb 2, 2015 at 9:23 PM
    #2843
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    The weight is being distributed onto the rack and then onto the bed itself, we looked it over a couple times but yea it should be fine
  4. Feb 2, 2015 at 9:28 PM
    #2844
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    That's awesome! You got a sick looking setup there dude! Your truck is awesome!
  5. Feb 2, 2015 at 9:39 PM
    #2845
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Thanks brutha! Likewise! :thumbsup:
  6. Feb 3, 2015 at 2:02 AM
    #2846
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    i made another video of it going up, this time in the daylight.
    http://www.youtube.com/watch?v=dVpq62c9FEU
    I didnt take a single picture of the fabrication process. It's probably the most complicated thing i've made, and I spent a lot of time on the lathe.
  7. Feb 3, 2015 at 3:27 AM
    #2847
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Nice!
  8. Feb 3, 2015 at 7:51 AM
    #2848
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    We seriously need some kind of write up. That thing is sick!!
  9. Feb 4, 2015 at 1:23 AM
    #2849
    WillRunner05
    WillRunner05 Well-Known Member
    WIll
    Houston, TX
    TRD Off Road
    ICON Suspension, LR UCA's
  10. Feb 4, 2015 at 3:14 AM
    #2850
    2008taco
    chris
    san diego
    Well in principle its fairly easy. The biggest hurdle are the lifting cylinders. Most the cylinders on the market have a small rod (about 1/2") that does the lifting. This wont handle the lateral forces of the tent and 2 people inside of it. By the time you get to a cylinder with a rod capable of handling the lateral forces the body of the cylinder is 6" in diameter, and a price tag around $600 dollars each. This leaves us needing to make our own.
    Starting at the bottom, the base is just a simple bed rack. All the tubes are placed to give as much support to the uprights as possible. Now you attach 4 uprights. These need to handle the weight of the tent, it's platform, and it's occupant's weight both vertically and laterally. I used 1 1/2 .188 wall dom tubing for this. These need to be as parallel as possible, i managed to get mine within 0.01 of eachother. On top of these we put a piston. These have 2 o-ring grooves, and a catch for a spring pin to hold the tent at the top. The outer walls of the cylinders is 1 3/4 .090 chromoly with a cap welded on the end. Connect the 4 corners together with a platform, and bolt the tent to the platform. Pump air into the 4 cylinders, and up you go.
    All that said there are a few downsides to this setup. The 1st is the cylinders make it more difficult to unzip and rezip the cover. The second is the big one. You will almost never park perfectly level, and the weight is not 100% equally distributed in the tent. This means that the tent will almost always bind using gravity to lower it down. I solved this using cables, pulleys, and a lever. This is not ideal, but it more than works. Eventually I will make another rack with a lift mechanism I have in mind which should address both these issues, but for now it works and I need to move on to my other projects (awning, chuck box, roof rack, etc)
  11. Feb 4, 2015 at 11:33 AM
    #2851
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Thanks for sharing 2008taco / Chris...
    I went a different route to raise/lower my tent, and used gas-charged struts to assist with the process. And rather than going straight up and down, mine goes up and back...
    What were your inspirations to taking this approach?
    I sure wouldn't mind brainstorming with you - or at least getting an opportunity to see yours in person. I just live in Oceanside...
    Rick
  12. Feb 4, 2015 at 11:45 AM
    #2852
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Nice job! Question, is there a locking mechanism when raised? Or, are you relying on air?
    Not knowing, you may consider drilling holes and adding safety pins to slide in while up.
    Just a thought :).
  13. Feb 4, 2015 at 12:23 PM
    #2853
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    He says theres a catch pin 2 posts up :)
  14. Feb 4, 2015 at 5:16 PM
    #2854
    ALBtacoma
    ALBtacoma Well-Known Member
    Pete
    Red deer AB, Canada
    07 trail limo trd sport
    Picked up a used tepui gran sabana today. Can't wait for the rack and spring to get here
  15. Feb 4, 2015 at 5:23 PM
    #2855
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Congrats!
  16. Feb 4, 2015 at 7:52 PM
    #2856
    ChamYota
    ChamYota [OP] Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This thread has evolved into something beautiful..
  17. Feb 4, 2015 at 10:23 PM
    #2857
    Idaholandho
    Ah, I should of read more closely. :woot:
  18. Feb 5, 2015 at 7:23 AM
    #2858
    MTgirl
    Weesa
    Bob's secret mod lair
    yeah, now if we could just get the damn OP to update the first page list :rolleyes:
    did you ever get one Chris? Or still shopping around?
  19. Feb 5, 2015 at 7:28 AM
    #2859
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    +1 Hahaha ...I wanna be on the elite RTT list.
  20. Feb 5, 2015 at 10:11 AM
    #2860
    Idaholandho
    :wave:
    I am ready now. Truck seems to be complete and Winter is on the downswing so, I along with my rabid ocd have meticulously studied pie charts, graphs, and statistical information that my team has prepared and have finally made a calculated decision between CVT and Tepui.
