*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Feb 12, 2014 at 9:51 PM
    #461
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Thanks for the info. Would it be too much trouble to ask you if you can take pics of the rack please? Really want to see how you did it so that I can get an idea of what needs to be done. Thanks again.
  2. Feb 12, 2014 at 10:05 PM
    #462
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Good points here! I'm planning on using 0.083" wall tube which is pretty light. I'm using that many crossbars for overall rigidity as well as flexibility for other uses down the road (i.e. snowboards, bikes, pelican cases, etc.).
    Would you suggest thicker wall tubing than 0.083"?
    No offense taken! I did think about using HREW tubing, but I'm treading the edge of my and my roommate's skills and tools with this rack as-is (and I want to tackle this project so I can say I did!), so I don't want to complicate things too much by adding the need for a pipe bender and/or notcher...
    Love it! That's essentially how I hope mine turns out. What thickness material did you go with?
  3. Feb 12, 2014 at 10:19 PM
    #463
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    That's why you should head up to Bellingham!
    I've got all that!
    Heading to the Bering Sea on Sunday, though.
    I'd advise you to use .125
  4. Feb 12, 2014 at 11:54 PM
    #464
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Hey man, welcome to the thread. Good to hear there are more options now. Does my old telescoping ladder have any trade-in value towards one of those newer/better versions? :D
  5. Feb 13, 2014 at 7:29 AM
    #465
    MTgirl
    Weesa
    Bob's secret mod lair
    didn't you already get a free ladder? :rolleyes:
  6. Feb 13, 2014 at 8:12 AM
    #466
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    FALSE.
    Not all tents are made in China. The CVT and Tepui tents in the current group buys are, but there are lots of tents made in South Africa, Australia and even some US made ones now.
  7. Feb 13, 2014 at 8:21 AM
    #467
    Box Rocket
    Adam
    Syracuse, Utah
    This makes me chuckle. You start out talking about saving weight with less cross pieces and then recommend Sch40 pipe for the rack? a Sch40 rack could easily be MUCH heavier than one made from sq tube.
    Round tube will work and some definitely prefer the look of round tube. That's cool. Build it the way you want, but as someone who build racks from sq tube, I find it much nicer to have a flat surface to mount to with greater surface area for the things that are mounted to it. With round tube, you only have a very small surface area at the top of the tube as a contact point. Not a huge deal, but having had both kinds or racks I prefer the sq tube on something like a bedrack or roofrack (at least for the rack part itself). The legs can be whatever you want.
  8. Feb 13, 2014 at 8:27 AM
    #468
    MTgirl
    Weesa
    :rant: no more rack jokes Homie!
    Here are the drawings on mine.
  9. Feb 13, 2014 at 8:28 AM
    #469
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    hey adam, what wall thickness would you recommend for a bed rack that will hold an RTT? 0.083"? 0.125"?
  10. Feb 13, 2014 at 8:34 AM
    #470
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :D
  11. Feb 13, 2014 at 8:42 AM
    #471
    Box Rocket
    Adam
    Syracuse, Utah
    Depends on your goals for weight. If you plan to carry a lot of extra stuff and a heavy rear bumper etc, it might be worth your while to go lighter on the bedrack if you want to keep weight down. But my opinion is its better to overbuild than underbuild and have something fail on you in the middle of nowhere. So if it were me I'd go with 0.125" or 1/8" wall. I also recommend something a little bigger for the legs since the legs really supporting it all more than the rack itself. Not necessarily thicker wall (although that isn't bad) but I don't think 1" sq tube is adequate for the legs. I'm using 1x2" tube (1/8" wall) for the legs on the racks I'm building.
    That's just my opinion on it. There are lots of good racks out there that people have built that may not follow that.
  12. Feb 13, 2014 at 8:42 AM
    #472
    MTgirl
    Weesa
    I believe mine is 1/8 - plenty sturdy
    :p
  13. Feb 13, 2014 at 8:47 AM
    #473
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    adam how far out are you on your bed racks?
  14. Feb 13, 2014 at 8:50 AM
    #474
    Box Rocket
    Adam
    Syracuse, Utah
    Probably summertime. Although, there are some discussions going on with another fabricator to possibly take over the construction of the racks for me which could make them available much sooner if the details can get worked out and I'm feeling good about the quality etc.
  15. Feb 13, 2014 at 8:52 AM
    #475
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    oh sweet man, is he also located in utah?
  16. Feb 13, 2014 at 8:52 AM
    #476
    Box Rocket
    Adam
    Syracuse, Utah
    no.
  17. Feb 13, 2014 at 8:56 AM
    #477
    Cascadia Tents
    Cascadia Tents Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    I also disagree. Cheapest is not best just as most expensive I'd not always best. Different companies in the US that buy from china are different. We take a lot of pride in setting ourselves apart by giving more quality , you can see this even from photos and compare. Yes most tents are made in china as a lot of Australian tents are also. Ones that are made in Australia are much more expensive. Making a tent such as these in America are going to be the price range of the Australian tents. Also to set the record straight there are more than 3 factories in china. There are over 20. They do not have a stock pile of these on one place waiting to badge them. I do not mind people saying things about china or other companies. I just like the record to be straight about what it really is and not about what we think it is.
    Best regards,
    Bobby
  18. Feb 13, 2014 at 8:58 AM
    #478
    Box Rocket
    Adam
    Syracuse, Utah
    Even though I own a competitors tent, Thanks for chiming in! :thumbsup:
  19. Feb 13, 2014 at 9:15 AM
    #479
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Hey Bobby do you guys design all your tents in house? The mechanical engineer in me is interested :)
  20. Feb 13, 2014 at 9:19 AM
    #480
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    All of the changes we do. The tent itself has been around awhile. We are designing in the process for our new tents we will be making
