*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Dec 27, 2015 at 8:28 PM
    #5661
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
  2. Dec 27, 2015 at 9:19 PM
    #5662
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Agreed. Down sleeping bag for me
  3. Dec 27, 2015 at 9:40 PM
    #5663
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I had a mattress pad heater at home and boy, was that luxurious! Which is why I could see the heating pad as long as you have something that will keep you warm without it.
  4. Dec 28, 2015 at 8:47 AM
    #5664
    CascadesTacoma
    CascadesTacoma Well-Known Member
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    The heated mattress pad is great and doesn't use much power. We place it under a fitted sheet on our pad and it works like a charm, doesn't get dirty, and takes no room when you close the tent.
    bayareataco likes this.
  5. Dec 28, 2015 at 8:55 AM
    #5665
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
  6. Dec 28, 2015 at 10:09 AM
    #5666
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    Where did you find a fitted sheet for your RTT mattress? I have been looking everywhere and cannot seem to find one that even closely matches the dimensions.
  7. Dec 28, 2015 at 11:36 AM
    #5667
    RubiconTX
    RubiconTX Member
    Austin TX
    14 Tacoma 4x4
    I ordered my tent on December 14th and received it on the 21st just in time for Christmas.
    Tepui Autana in haze gray
    I had an off-road trailer i had built when I had my jeep. I decided to update the simple racks on the trailer to make it adjustable.
    Trailer before the updates:
    I started by removing the two metal racks on top of the trailer lid. I then added some 1.5x1.5 square tubing brackets to the sides of the trailer. Inside these I added some 1x1 square tubing that will be used to lift the tent up. I reused the two rack pieces that i took off the top of the trailer lid.
    I added some linear actuators to each bracket to assist in raising the tent.
    In this picture you can see the added brackets with the tent mounted on the rack. The rack is in the low position.
    Here the rack is at the high position.
    I setup the tent in the back yard to see how it would set up. The orange straps are to add some diagonal bracing. The lid for the trailer is removed in these pictures, but it was put back on after these pictures were taken.
    d7305ec2-9f2f-45d2-9340-6faca8921d4b_zps_6f6b9e728674fbec9ae0f3529f5bd0ffa8ed17a1.jpg
    My future plans are to make an adjustable rack for the back of the Tacoma. I will be reusing most of the components that were used in the trailer.
  8. Dec 29, 2015 at 7:07 AM
    #5668
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That's awesome. Good job
  9. Dec 29, 2015 at 7:14 AM
    #5669
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    ^^^^ this. I couldn't find anything to fit the bachelor closely
  10. Dec 29, 2015 at 7:33 AM
    #5670
    MTgirl
    Weesa
    Bob's secret mod lair
    I made one for my tent...found some 60" wide material and just sewed the sides shut so its like a big pillowcase
    Flhighby likes this.
  11. Dec 29, 2015 at 8:14 AM
    #5671
    Spoon93
    Rogue valley
    06 DCSB SR5
    I was thinking about attaching Velcro to a non fitted sheet and strapping it around...hmmm might have to look into that and respomd with my findings. In the interim you could probably find a little market on the forums for a custom fitted sheet for RTT... Weesa becomes a vendor!
  12. Dec 29, 2015 at 11:04 AM
    #5672
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What did you do for the velcro that attaches the mattress to the base?
  13. Dec 29, 2015 at 11:54 AM
    #5673
    JLink
    Josh
    Ocean, NJ
    Probably nothing. I don't use it anyway.
  14. Dec 29, 2015 at 5:04 PM
    #5674
    MTgirl
    Weesa
    Nothing. With the condensation mat the velcro is worthless. I fold the mattress over and put the mat on top before closing the tent
  15. Dec 29, 2015 at 6:29 PM
    #5675
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    ****Warning***** Die hard Tepui and CVT fan boys should look away.
    Tepui Autana - Shasta Mod (Storage)
    Ever since I had put in my new sleeping bag (queen size -20° rated, duck cloth) it has been a challenge to zipper close the Autana tent.
    With the wear and tear over the past few months it has stretched the cover and now the zipper is above the floor line causing leaks, and mildew after sitting without noticing.
    After some research, CVT's tents are the same comparable size but 3" taller due to their 2pc slide ladder while Tepui uses the telescoping and therefore flatter design.
    Here are few pics of before and after.
    Tepui zipped on too tight.
    Zipper at max and above floor.
    New CVT Mt. Shasta cover and zipper.
    New cover mounted.
    New zipper below the floor, thus preventing leaks.
    Top view of the cover, still has about an 1.5" more room without being pulled tight.
    Rocking the new sticker.
    @Cascadia Tents , thanks again Bobby.
    Cascadia Tents and Spencer like this.
  16. Dec 30, 2015 at 8:14 PM
    #5676
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Finally tent on the truck with the new bed bars that are actually 2 months old... still levelish with the cab sorry for the potatoe quality... I always seem to be mounting this thing in the dark
    scott96929 and malburg114 like this.
  17. Jan 2, 2016 at 2:50 PM
    #5677
    CascadesTacoma
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    To answer the question about the bottom sheet, I have an XL Ruggedized so I just use a king size bottom sheet and it works well.
    Oh yeah, we stayed in the Mojave Desert Preserve on the way home from Colorado. We stayed in the northern half this time and found the terrain much different. Many more cacti and the rock formations were varied. Amazing place.
    On the way out, south side:
    On the way back, north side:
    scott96929, ian408 and malburg114 like this.
  18. Jan 2, 2016 at 11:13 PM
    #5678
    TYetti
    Mat
    Well it was cold as balls but made it through the the weekend with an avg temp of -14. Had sOme frost building up inside the tent before we got inside, also there was ice buildup under the foam and mat, two of the side clips broke when packing up Friday so I had my gf sit on the tent so I could zip up the cover. Other than that it was a good trip
    I think I'm going to invest in a heater buddy just for warming up the tent before going to bed and after I wake up
    Box Rocket, 1MK, scott96929 and 3 others like this.
  19. Jan 3, 2016 at 7:26 PM
    #5679
    1MK
    1MK Desert Explorer
    Southern California
    Ended up in the Sierra Nevada's over the weekend and explored the area. Few blankets with the addition of a electric blanket made it surprisingly comfortable to sleep in even though it was 7*. Waking up in the morning and moving around you could hear ice breaking under the condensation mat. lol.
  20. Jan 3, 2016 at 8:18 PM
    #5680
    CascadesTacoma
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    Great pictures, I really like that camping spot, 1MK. I checked your instagram gallery, that Havasupai picture is awesome. We were turned back my mud a few weeks ago. Past the reservation ranger office and only a few minutes away. We were a one truck trip and wouldn't have been able to self recover if we became too stuck. Oh well, next time. At least the Kaibab National Forest was a great alternate camping location.
    1MK likes this.
