*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Feb 1, 2016 at 5:07 PM
    #5821
    aaol1
    aaol1 Well-Known Member
    sam
    victoria BC
    10' TRD sport DCLB
    Rear diff breather Plasti dip emblems and rims Garmin glo GPS receiver + ram mount with tablet Toytec BOSS lift with rear AAL Custom steel bolt-on sliders with kickout Custom aluminum bed rack Wild Coast Tents Sundog RTT mounted to rack 2 x Treds PRO Lime green mounted to rack Shovel + Hi-lift mounted to rack Cheap bush bar 2 x CREE LED light pods with hood mounts 265/75R16 Hercules Terra Trac ATII
    yea exactly it all depends on your lift, and how tall you are as a person. Ive got a 2 inch in back ish, and im 5'11...im guessing i will need cab height
  2. Feb 1, 2016 at 6:05 PM
    #5822
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    I can't mount an awning at that height, but you can still use an annex, however it bunches at the bottom. When I stand by the ladder I'm not eye level to the opening of the tent so it's still up there.
  3. Feb 1, 2016 at 6:07 PM
    #5823
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    ditto. It's called a ROOF top tent for a reason, right?
    malburg114 likes this.
  4. Feb 1, 2016 at 6:10 PM
    #5824
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Mine is called a bed rack tent :stirthepot:
    rob1208 likes this.
  5. Feb 1, 2016 at 6:12 PM
    #5825
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    For me, I wanted my daughter to climb in and out safely with no worries, but eventually after kids get older I'll go the bed cap + roof rack route.
  6. Feb 1, 2016 at 6:28 PM
    #5826
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Prinsu Design Studios bed rack, Tepui Ruggerized XL RTT, Smittybilt awning and ARB screen in room setup. Airing everything out. Getting ready for the camping season.... Awning height is just over 6 feet, I have about 2 inches of ceiling above my head. ARB screen room is great for mosquito infested areas and provides access to the front and back door to the truck as well.
  7. Feb 1, 2016 at 6:53 PM
    #5827
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    You're in Arizona, when did camping season ever end? :confused:
  8. Feb 1, 2016 at 6:58 PM
    #5828
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    am i allowed to hang out with the cool kids now?
  9. Feb 1, 2016 at 7:11 PM
    #5829
    ramonortiz55
    Ramon
    Texas
    stock
    How are you guys securing your RTTs against theft?
  10. Feb 1, 2016 at 7:19 PM
    #5830
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    ^^^ Hate having it on when im out running errands. Been running a cable lock through the mounting bracket to "deter" people but if they had the tools and man power....
  11. Feb 1, 2016 at 7:22 PM
    #5831
    malburg114
    Las Vegas, NV
    How do you like the smittybuilt awning?
  12. Feb 1, 2016 at 7:28 PM
    #5832
    ramonortiz55
    Ramon
    Texas
    stock
    that sounds like a legit idea.
  13. Feb 1, 2016 at 7:31 PM
    #5833
    malburg114
    Las Vegas, NV
    There was someone a while ago who used two eyelet bolts with a lock through it... Let me see if I can find it again.
  14. Feb 1, 2016 at 7:32 PM
    #5834
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    How so? I was debating the keyed padlocks with eye bolts, but cutting at max 4 padlocks seems easier than having to cut 8 bolts or spend the time taking off all the hardware.
  15. Feb 1, 2016 at 7:33 PM
    #5835
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I saved the picture
  16. Feb 1, 2016 at 7:36 PM
    #5836
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Doesn't help unless your bedrack is locked too
  17. Feb 1, 2016 at 7:37 PM
    #5837
    malburg114
    Las Vegas, NV
    Yeah thats it. I know its an exhaust clamp just dont know how its connected to the tent. Was debating drilling a hole on the mounting rail and running a lock through that with a cable attatched to it. Interested to see other setups.
  18. Feb 1, 2016 at 7:38 PM
    #5838
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Thats true too. Never ending
  19. Feb 1, 2016 at 7:40 PM
    #5839
    malburg114
    Las Vegas, NV
    It takes me about 5 minutes to undo all the 13 mm bolts and another 5 to get the tent off with help. I was thinking with atleast one or two locks will create a more of a delay or stop someone from trying.
  20. Feb 1, 2016 at 7:42 PM
    #5840
    malburg114
    Las Vegas, NV
    My bed rack is a pain to take on and off... Have only done it once and took me close to an hour. The plastic bed liner makes it super hard to get a wrench on the bolts and with 8 bolts total in the rack makes it really hard to do anything fast. Others may be different.
