*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Mar 23, 2016 at 4:27 PM
    #6261
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Bobbles and trinkets
    I have a newbie question. What’s the consensus on hard shell RTTs? I don’t see many on here. Was wondering if the soft shells are just better all around or if there was a real downside to the hard shell versions. Thanks
  2. Mar 23, 2016 at 5:12 PM
    #6262
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    They each have their pros and cons. Hard shells are typically a bit more aerodynamic and sometime lighter weight, but most are quite a bit more expensive than soft sided RTTs. The main drawback to hardshell tents IMO is that because of the vertical opening or "clamshell" design they do not have the same amount of space you can get from a softsided tent the essentially doubles the size of it's footprint when open. The footprint of a hardshell is the same open or closed. That means most will fit 2-3 people at most. There are several softsided tents that will fit 4+ and with the addition of an annex can have even more room.
    Many hardshell tents use a crank handle to open the tent. It's not uncommon for people to lose the crank. It's not necessarily a bad design, just one more piece to keep track of.
    I think cost is one of the primary reasons you don't see more of them. That, and the limited space.
    Not everyone needs the space provided by a softshell tent, so a hardshell might be a good option if you typically travel solo or with one other person and can afford the price tag. As with soft sided tents, no two tents are created equal and quality can vary quite a bit from one brand to the next. Whether you choose a hard shell or soft sided tent, it makes good sense to buy the best quality you can afford so that it will last and be durable and comfortable for years.
  3. Mar 23, 2016 at 5:16 PM
    #6263
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I'm Ben Bacher, and I endorse this statement^, well said Adam.
    Box Rocket likes this.
  4. Mar 23, 2016 at 5:25 PM
    #6264
    SoTexTacoma
    SoTexTacoma Well-Known Member
    AllOver, TX
    '14 TRDOffroad
    BP-51 w/Dakars MobTown Hybrid Bumper All-Pro skids Redline Hood Struts AllPro bed bars
    Alright, hope I don't get flamed for a stupid question but, here goes...
    I've never been in a RTT so all I have to go by is pics. Can someone explain how the folded out side of a set up tent is supported? Browsing thru the pics and it doesn't seem like the ladder supports the weight. Am I wrong? Seems like there should be some supports on the outside corners that would do this. It just seems like too much weight on the "floating" side could damage the structure. Looking to get one of these but wonder about weight limits and such.
  5. Mar 23, 2016 at 5:33 PM
    #6265
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Thanks @Box Rocket . Yeah, some of the basic ones I looked at from James Baroud started at $3k. Had thought I had seen some left overs or a refurbished CVT version for $2200 at one point. Just looking for a 2 man and the simplicity of the hard shell seemed appealing.
  6. Mar 23, 2016 at 5:52 PM
    #6266
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    The ladder supports that side of the tent. Some people have "side supports" that go from the corner to the ladder to support the edges a bit more.
  7. Mar 23, 2016 at 6:15 PM
    #6267
    MTgirl
    Weesa
    Bob's secret mod lair
    cost, not a lot of variety in sizes. I've heard complaints that the fiberglass shells of even the best brands can develop stress fractures if not properly cared for.
    I would take a hard shell in a minute if it wasn't for the cost.
    combination of ladder, hinge, tension. My CVT has nylon webbing that runs from one side to the other to create a tension frame that ties into the metal frame. Black webbing seen in the edges of the pic
    scottalot and RickS[QUOTED] like this.
  8. Mar 23, 2016 at 8:31 PM
    #6268
    benbacher
    Anchorage, AK
    The inherent design will hold itself up, much like a suspension bridge, but the ladder adds quite a bit of support.
  9. Mar 24, 2016 at 7:10 AM
    #6269
    Parabellum
    Parabellum Well-Known Member
    North Central PA
    2009 Dcab Man. 6spd v6 Tacoma TRD Offroad elocker
    ARB Series III Simpson Rooftop Tent is it any better than the other RTT or just high priced for the name?
  10. Mar 24, 2016 at 9:51 AM
    #6270
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    Difference in pricing usually indicates a difference in the material and finishes of the tent. There is a great article on expo portal that had a breakdown of all the tent companies. Research is a key component before you purchase - just because it's cheaper/more expensive doesn't mean it's the same product.
  11. Mar 24, 2016 at 3:50 PM
    #6271
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Can someone give me the measurements for how far apart the rails are on a tepui Kukanam? Need ASAP.
  12. Mar 24, 2016 at 4:48 PM
    #6272
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Just measured: 32"
    ebbs15 likes this.
  13. Mar 24, 2016 at 6:18 PM
    #6273
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Thanks!
  14. Mar 24, 2016 at 6:24 PM
    #6274
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    @SilverGhost was finalizing my rack... and we wanted to make sure the cross bars were going to work.
    IMG_20160324_172556.jpg IMG_20160324_172316.jpg IMG_20160324_172350.jpg IMG_20160324_172458.jpg IMG_20160324_172546.jpg IMG_20160324_172645.jpg IMG_20160324_172705.jpg
    Box Rocket, PS78, C_Ratt and 2 others like this.
  15. Mar 24, 2016 at 6:29 PM
    #6275
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Keeping the soft topper?!?
  16. Mar 24, 2016 at 6:44 PM
    #6276
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    already sold. kinda wished I'd kept it... but honestly... I don't think I'll be removing this rack very often
  17. Mar 24, 2016 at 7:04 PM
    #6277
    malburg114
    Las Vegas, NV
    Was hoping to see you run the soft topper with the tent on top. Always thought those looked so clean. I thought Id take mine off when i wasnt using my tent... Only time its come off is it to get powder coated then went right back on. Think it looks better with it on anyways.
  18. Mar 24, 2016 at 7:05 PM
    #6278
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Can somebody snap a picture of how a tent mounts to a bed rack please? I'm going to order one soon and I am running ideas through my head for the rack.
  19. Mar 24, 2016 at 7:08 PM
    #6279
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    I loved the look of the soft topper, but wanted the tent to sit lower. I'll still have a little visibility below the tent with my rear view, not much, but at least a little. The rear hoop my 4' ARB awning will be mounted to it, and extend over my tailgate for cooking and what not.
    phillstill likes this.
  20. Mar 24, 2016 at 7:09 PM
    #6280
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    there's plenty of picture if you look through the thread... probably in the first couple pages
