*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jul 14, 2016 at 8:28 AM
    #7701
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    FIFY :D
    The Hunter and chris4x4[QUOTED] like this.
  2. Jul 14, 2016 at 10:15 AM
    #7702
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I carry 4-6 pre-cut 2x4's which has always been enough. Last place I went had nothing close to level, so the left front was on a huge rock and then used the 2x4s in the rear to get it as close as possible.
    Also, I heard somewhere if you do have to sleep on a slope, always sleep head high or you'll wake up with a headache. Don't know if it's true, but I don't want to test it either.
  3. Jul 14, 2016 at 10:40 AM
    #7703
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Yes, this. Always head high. You will feel like shit in the am if your head is low!
  4. Jul 14, 2016 at 8:33 PM
    #7704
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have several 2x6s I bring plus a small level. My buddies just laugh at me when the level comes out. :anonymous:
    MTgirl likes this.
  5. Jul 14, 2016 at 8:36 PM
    #7705
    MTgirl
    Weesa
    Bob's secret mod lair
    I have a carpentry level too.:fistbump: I need to get a couple of the small bubble levels like you see on RVs and attach them to the tent base, preferably above the drivers door.
    Digiratus[QUOTED] likes this.
  6. Jul 14, 2016 at 8:41 PM
    #7706
    Digiratus
    Roaming the PNW
    The RedHead
    Needz the level to get it right, right?
  7. Jul 14, 2016 at 8:44 PM
    #7707
    MTgirl
    Weesa
    Right. Most of the time I can feel if I'm parked level or not, checking is just for peace of mind or when I know I'm out of whack and need to decide where I need blocks.
  8. Jul 14, 2016 at 8:46 PM
    #7708
    MTgirl
    Weesa
    I also have a clinometer app on my phone that I can check for level by holding my phone against the base of the tent, screen out
  9. Jul 14, 2016 at 8:47 PM
    #7709
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Usually I just make sure my head isn't lying downhill when I sleep. Never really bothered getting it perfectly level before :notsure:
    phx13 and BYJOSHCOOK like this.
  10. Jul 14, 2016 at 8:50 PM
    #7710
    MTgirl
    Weesa
    I gotta get close to level, prefer my head to be just a little uphill, or I slide off of my sleeping pad really easy. Got lazy one night and didn't bother to level out...woke up with foot cramps because my feet were pressed up against the wall of the tent. I had slowly slipped off my mat and against the walls
    The Hunter likes this.
  11. Jul 14, 2016 at 8:52 PM
    #7711
    PcBuilder14
    Brent
    Nor Cal
    Understandable.
    There was one night where I thought it was pretty level until my wife and I went to bed that night. The truck was slightly lower at the nose and I ended up being stuck between the wall of the tent and her the whole night haha
  12. Jul 14, 2016 at 10:33 PM
    #7712
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Sleeping pad in a RTT? Guess your fancy rtt doesn't have a 3" memory foam mattress like my Autohome airtop?
  13. Jul 15, 2016 at 3:43 AM
    #7713
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Has to be level, nothing worse than being stuck between the wall and someone else and have to pee.
  14. Jul 15, 2016 at 4:11 AM
    #7714
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I'm not always level, but never been to the point where I'm sliding.
  15. Jul 15, 2016 at 5:05 AM
    #7715
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    x2 I try to get as level as possible but as long as my head is up and I'm not sliding it's good. Usually too intoxicated to care :drunk:
  16. Jul 15, 2016 at 5:13 AM
    #7716
    MTgirl
    Weesa
    It has a decent mattress but I'm a side sleeper, all memory foam compresses too much. The air pad doesn't compress and I don't wake up with sore shoulders and hips.
  17. Jul 15, 2016 at 6:08 AM
    #7717
    POOLGUY
    JEFF
    ALABAMA
  18. Jul 15, 2016 at 6:11 AM
    #7718
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I think the pad that comes with it is pretty good. I sleep just as good in my tent as I do at home.
  19. Jul 15, 2016 at 8:32 AM
    #7719
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    5?! :eek:
  20. Jul 15, 2016 at 8:48 AM
    #7720
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    That's what I was thinking. That's a ton. How does it shut?
