*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jul 28, 2016 at 2:35 PM
    #7881
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is your ARB mattress 56" wide like the CVTs
    Amazon lists the queen as 58" x 78". Is that fairly accurate?
  2. Jul 28, 2016 at 2:47 PM
    #7882
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    I can't remember my exact mattress dimensions in the tent but I got a cali-king mattress topper and cut off part of it off to fit onto the end to make up the missing difference in length (which I think was 96 inches). This way the entire tent mattress is covered with a topper.
    Digiratus[QUOTED] likes this.
  3. Jul 28, 2016 at 2:49 PM
    #7883
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, I see. Thanks.
  4. Jul 28, 2016 at 2:56 PM
    #7884
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, the Mt Shasta mattress size is 96"x56". I am guessing yours is similar if not the same. Thanks for the info. I'm gonna have to pick up one of these 2" pads I think.
    Jim Bob likes this.
  5. Jul 28, 2016 at 3:23 PM
    #7885
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Seems that one of the biggest complaints with any rtt is trying to close the thing with a bunch of extra material stuffed inside. Seems like it may be worthwhile for the mfgs to consider developing a center hinge that works like channel locks.
  6. Jul 28, 2016 at 3:28 PM
    #7886
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    I think the main issue with that idea is going to be the inelasticity of the canvas material itself.
  7. Jul 28, 2016 at 3:32 PM
    #7887
    Digiratus
    Roaming the PNW
    The RedHead
    That approach wont help if you can't zip up the outer cover.
  8. Jul 28, 2016 at 3:35 PM
    #7888
    Denk
    PNW
    Good point. Im sure at some level, adding these enhancements becomes cost prohibitive. But as for having extra material to cover the gap, you could have an expandable section closed by zipper, like some suitcases (since that is essentially what the rtt is being turned in to).
  9. Jul 28, 2016 at 3:40 PM
    #7889
    Denk
    PNW
    Wow. Tuff crowd. :D
    Maybe an rv would be better for some? Although it would be pretty cool to see some clever engineer come up with a solution.
  10. Jul 28, 2016 at 3:41 PM
    #7890
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I have never had an issue with space to stuff my bedding into my tent, but I rarely do anymore. If you use down sleeping bags or a comforter, having them in there and compressed for long periods of time breaks down the loft of the down and you start to loose warmth. Even on synthetic bags it can happen although not as bad. I only but the bags in there for short trips and try to make a habit of hanging them up when we aren't out so they have a longer lifespan.
    That being said I can fit 4 pillows and 3 sleeping bags in my Eezi Awn 1600 no problem.
  11. Jul 28, 2016 at 3:54 PM
    #7891
    kitsym
    Portland, OR
    I see what you're getting at, and it IS a good idea but you'll reduce the rigidity of the soft-shell RTT system. The hardshell tents are basically that "zipper" idea, but they are built to be rigid when fully expanded.
  12. Jul 28, 2016 at 5:08 PM
    #7892
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Its really easy with a second person... Put the cover on and have them sit or stand (if you have diamond plate) on the tent and itll squish it down more...
  13. Jul 28, 2016 at 5:29 PM
    #7893
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    My solution... still needs some tweaking...
    kashtyaatsi and The Hunter like this.
  14. Jul 28, 2016 at 5:31 PM
    #7894
    cmack
    cmack Well-Known Member
    18 Burrito
    I just sit on the edge of mine until I can strap it down. That Teton sleeping bag stays fluffy
    The Hunter likes this.
  15. Jul 28, 2016 at 5:39 PM
    #7895
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    That's actually a really smart solution. I might do this to my Tepui.
  16. Jul 28, 2016 at 5:41 PM
    #7896
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Just stay away from a brand called ProGrip... piece of shit buckles.
  17. Jul 28, 2016 at 5:44 PM
    #7897
    cbechtold
    Cory
    Pleasanton, CA
    Thanks for the heads up! :thumbsup:
  18. Jul 28, 2016 at 5:57 PM
    #7898
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Eezi-Awn and Tepui Ruggedized tents are a bit like comparing apples to pears. They are both roof top tents, just like apples and pears are both fruit and similar but pretty different. But apples and pears are both tasty and satisfying, and both tents perform similarly. The main differences are in the materials. The Eezi-Awn will use a wood floor and a canvas material for the canopy rather than the ripstop poly/cotton used on Tepui tents. The wood is durable but can be heavy and can deteriorate over time (although that would take a while and some extreme conditions) where the aluminum base on the Tepui is slightly lighter (actually pretty close in weight when looking at a Ruggedized floor) and it also won't be susceptible to moisture etc like the wood will. The waterproofing methods are different as well. EA uses a process similar to waxing the canvas to waterproof the material. It's effective and the canvas is probably the most durable on the market. The EA canvas again is on the heavy side and the tents can be very dark inside. One downside for those that camp in cold/wet conditions, the EA canvas with the waxed finish is made in a way that when it becomes damp and if it's below freezing, the canvas can freeze and become stiff making it difficult to close the tent. Make no question about it the EA is a very nice tent and that is reflected in the price.
    The Tepui Ruggedized tents are also one of the most durable tents on the market with some extra benefits like the Anti-condensation mats, durable fabric that is still breathable and won't feel like a cave inside. I have always felt that the Ruggedized tents are on a similar level to the EA tents in most aspects, but at a fraction of the cost. Again, kinda like apples and pears. Or for you car guys, kinda the difference between buying a BMW 335i vs an M3. Very similar in many ways with a few small things the make the M3 special. The EA is like the M3. It becomes up to the customer to decide I the small differences are worth the definite extra cost.
    GeoTaco likes this.
  19. Jul 28, 2016 at 5:59 PM
    #7899
    Box Rocket
    Adam
    Syracuse, Utah
    Tepui Ruggedized with a weather hood. I use mine in the winter wit the weather hood and it does great, but the weather hood is very nice.
  20. Jul 28, 2016 at 6:14 PM
    #7900
    Box Rocket
    Adam
    Syracuse, Utah
    I spent last week at FJ Summit in CO as a Tepui vendor. There was a vendor there with a CVT Summit series as well. I thought it was great because potential buyers were able to do some comparison side by side. I was able to get a closer look at the Summit series too. It's a nice tent. Still some differences that are noteworthy. I won't comment further since it will come across as biased since I sell Tepui, and I have no intention of badmouthing the CVT. But for what it's worth, as a regular tent user I still prefer the Ruggedized. If you know anyone that was at FJ Summit and looked at tents, it might be worth asking them what they thought between the two.
    GeoTaco and jubei like this.
