*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Aug 15, 2016 at 7:06 PM
    #8081
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Now I realize this is a loaded question but I'll ask it anyway. Was the debate ever solved on weather it's warmer in a RTT or on the ground? Thanks as always
  2. Aug 15, 2016 at 7:08 PM
    #8082
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    lots of variables based on tent
    but
    ground is cold
  3. Aug 15, 2016 at 7:25 PM
    #8083
    Wolftaco0503
    Adam
    Chicago
    As a staunch ground camper & sometime a hammock sleeper I've always consider the ground to be a Insulator. Now that being said, a RTT at least most of them are set up so the part that has the ladder is on a maybe a 5 or 10 degree angle. Is that the way the are? or could this be fixed? Another question now while your in the tent is someone always sleeping with their feet in the breeze or do RTT's have a insulator over the inlet to the tent. Thanks
  4. Aug 15, 2016 at 7:31 PM
    #8084
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The door zips up completely just like a normal ground tent, no issues with feet dangling in the cold. You also have a 2" thick foam mattress insulating you from the base of the tent which is another inch or so thick. The tent opens flat across both halves when set up.
  5. Aug 15, 2016 at 7:41 PM
    #8085
    Wolftaco0503
    Adam
    Chicago
    ok That is the extent of my questions for now. I'm sure I'll come up with more thanks.
  6. Aug 16, 2016 at 3:51 PM
    #8086
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Anything you can do about a broken handle, maybe a credit towards a power lock? Little over a year my handle broke off of mine, thankfully it wasn't locked
  7. Aug 16, 2016 at 4:44 PM
    #8087
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Mine broke after 14 months. I reached out to P&L anyways and their customer service rep sent me a replacement for free. Unfortunately its still the same plastic design that hits the metal strike plate but now I just make sure to clean and re-lube the plastic piece every few months.
    ChandlerDOOM[QUOTED] likes this.
  8. Aug 16, 2016 at 4:47 PM
    #8088
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Hmm I may try that route. I think the handle is just a poor design, too much lifting pressure for too little plastic. I wish it were based on the factory handle more
  9. Aug 16, 2016 at 4:49 PM
    #8089
    rob1208
    Rob
    SF Bay Area
    Agreed. If I get real motivated one day, I may try to tweak that plastic piece but reinforcing it with some metal or something. Haven't really thought about it in detail but it seems like making it a bit stronger would help it handle the repeated pressure on the metal plate.
  10. Aug 16, 2016 at 4:53 PM
    #8090
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Maybe an epoxied metal L bracket on the back side of the handle would do the trick since mine broke where the corner meets. But besides the handle itself the key cylinder could use some work as well, it was always tricky getting the cylinder to move one way or another
    rob1208[QUOTED] likes this.
  11. Aug 16, 2016 at 5:06 PM
    #8091
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Finally got to use my RTT this last weekend. I'm a fan! It worked great with me and the dog (60ish lb Lab/husky mix) inside once he circled it for about 20 minutes sniffing. My only gripe the first night was I didn't level the truck, so I kept rolling towards one side of the tent. The second night I parked on some firewood and it was almost level, and @DannyBFresco gave me his old 1" (I think?) memory foam pad to put down and it helped alot more! I still think I'll be getting a 2"-3" pad for my next trip.
    Also, I learned the hard way to do a complete and final check before folding it up. I was had just got done throwing the final straps over and was walking away when I tried to look at something across camp and realized I'd left my glasses in one of the pouches on the inside. :facepalm: Needless to say I got alot of practice in putting up and tearing down the tent last weekend!
    rob1208, jubei, scott96929 and 2 others like this.
  12. Aug 16, 2016 at 5:08 PM
    #8092
    Wolftaco0503
    Adam
    Chicago
    Question: Do you lift the dogs up into the tent? or Teach them to climb a ladder? Thinking the second might be easier.
  13. Aug 16, 2016 at 5:08 PM
    #8093
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Ah you'll forget many things in the tent and not realize it until its already put up. I forgot my keys once....once
    MTgirl, AZ2013 and DannyBFresco like this.
  14. Aug 16, 2016 at 5:09 PM
    #8094
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I lift mine. He's only about 55 pounds and he helps me by trying to push up the ladder lol
  15. Aug 16, 2016 at 5:09 PM
    #8095
    DannyBFresco
    Danny
    I lmao'd from my RTT when he told me
    rob1208 likes this.
  16. Aug 16, 2016 at 5:10 PM
    #8096
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I lift mine up. Tent is only about four feet to the base and he's a beagle so it's not too difficult.
  17. Aug 16, 2016 at 5:11 PM
    #8097
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    I lift mine as well, <50lb aussie.
  18. Aug 16, 2016 at 5:13 PM
    #8098
    Wolftaco0503
    Adam
    Chicago
    While your on the ladder?
  19. Aug 16, 2016 at 5:14 PM
    #8099
    DannyBFresco
    Danny
    From the ground for me
  20. Aug 16, 2016 at 5:32 PM
    #8100
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Been there...just once! Lol
