*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Oct 29, 2016 at 7:23 PM
    #9121
    JediScout
    JediScout Well-Known Member
    David
    Georgia
    2013 Tacoma 4x4 TRD Off Road
    Filters: K&N Air Filter Engine, Cabin Air Filters Uni Filter Mod 4.88 re-gear front and rear Yukon Gears Suspension: Rago Fabrication Leafpack Hangers Ironman 4x4 FOAM CELL PRO SUSPENSION LIFT KIT FOR TOYOTA TACOMA 2005-2023 Stage 2 Upper Control arms 2.5" Heavy Load Front springs and shocks Heavy load leaf pack Wheels: 17" RRW RR5-S x5 BFG K03 285/70/17 Brakes: Power Stop KC 137-36 Z36 Front Calipers/Rotors/Pads Power Stop KOE15389DK Rear Drum Brakes Electrical System and Accessories: Genesis Dual battery Kit: 201-TT2DBK x2 Full Throttle Group 34 Batteries: FT825-34 SPOD w/Bluetooth w/Custom OTRATTW Rocker Switch Panel Cali Raised Front Pillar Lights Cali Raised 42" Light Bar Auxbeam Rear Ditch Lights Procomp RGB Rock Lights (Bluetooth Enabled) CSI 52qt Fridge ~hardwired w/Anderson Plug Connections to main battery. CSI Fridge Sliding Tray 15 amp circuit breaker on CSI Smittybuilt Air compressor 2781 (Anderson Plug connector Mod) 50 amp circuit breaker w/Anderson Plug Connector Prinsu Roof Rack Plano case with all recovery gear CVT RTT Mt. Shasta w/Awning 23Zero 180* Awning Rago Fabrication bed bars Interior Mods: Installed quad USB charging ports in Dash Exterior Mods: ATH High Clearance Rear Bumper w/Swing Out Tire Carrier Installed Separate Dual Waterproof USB Charging Ports in Truck Bed Rago Fabrication Bed Stiffeners Communications: Midland MXT275 GMRS Radio Midland FRS handhelds BaoFeng UV5R HAM Radio Recovery Gear: Maxtrax (Red) Bunker Industry Mini Traction Boards (Great for Leveling, Red) Bubba Rope 20,000lbs Bubba Rope Soft shackles
    I mounted my CVT today, finally, and I was worried about it being low. But in all reality the annex is just that, and annex. Put some storage stuff in there if you don't want to brave the elements. You could even sleep 3 people in there. I have mine mounted on some Relentless fab bars and its low. The Velcro in the annex allow you to shorten it though. Suites my needs just fine.
  2. Oct 29, 2016 at 7:29 PM
    #9122
    pixelsailor
    pixelsailor TTC #33
    Ben
    San Antonio
    Devourer of wallets
    things
    @JediScout Thanks. That's the same setup I plan on doing: the tall Relentless bars
  3. Oct 30, 2016 at 3:46 AM
    #9123
    JediScout
    David
    Georgia
    I'll get some photos up soon, maybe by tonight. The relentless bars (2 w/quickfist tabs, powdercoated) took approx. 5-6 weeks to receive. When I called for an update or emailed, I was met with a friendly response. So if you don't have them plan accordingly. I literally received them the week before we needed them.
  4. Oct 30, 2016 at 4:40 PM
    #9124
    wat0023
    wat0023 Well-Known Member
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    I'm sure this has been discussed somewhere but there's far too many pages...
    About how long does it take to set the tent up? Is it fairly easy?
    Also, I'm assuming keeping them below the top of the cab (so mid height bed rack) still decreases the MPG but not as much as on the roof?
    Thanks!
  5. Oct 30, 2016 at 5:12 PM
    #9125
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    So let me get this straight, you are too lazy to look for the info you want but expect someone to answer your questions when you have already stated "I'm sure this has been discussed before"
    0uTkAsT and Jim Bob like this.
  6. Oct 30, 2016 at 5:33 PM
    #9126
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Because 3rd gen.
    FishTacoTruck and phx13 like this.
  7. Oct 30, 2016 at 6:31 PM
    #9127
    wat0023
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    I tried to find the information. I've looked through several pages (beginning, middle, and end), but it's mostly just people talking about their tents. I've also been on several websites. None of them have said how long it takes to set the tent up. It was just a simple question.
  8. Oct 30, 2016 at 6:35 PM
    #9128
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    To set up new tent which included mounting rails to bottom and ladder maybe 30 min. I did it Friday with a friends help. Btw it was my first RTT.
  9. Oct 30, 2016 at 6:36 PM
    #9129
    wat0023
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    Thanks! That doesn't sound too bad! I'm definitely being swayed by these... They seem pretty cool!
  10. Oct 30, 2016 at 6:41 PM
    #9130
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I think he was asking about first install setting everything up, but you are right about different times. It takes me 10 min to set up my CVT on my bedbars.
  11. Oct 30, 2016 at 7:24 PM
    #9131
    JediScout
    David
    Georgia
    Setup would really be dependent on hardware, and specifics of your ride. I went with the Relentless Fab bars (Awesome by the way), and the CVT Mt. Shasta I mentioned before. Here she is. Took me an hour the other night to mount. The wife helped me lift the tent on the rack. I used the previous ideas in this thread to secure it. Basically the loop bolts with a pad lock on it, and the muffler clamps. It's rock solid thus far. Opened her up yesterday, and sprayed the tent down real good as instructed to allow the seams to swell up. Total 1st time setup with annex took about 30 min. Washed the mattress and put our beddings in it. In this photo we have two sheets, a thick comforter, an afghan (the blanket, not a person, for those that would wonder), 3 pillows, the tent stakes, and other hardware inside the tent all folded up. I used the rug stop vinyl material as a buffer for condensation. If that sucks I'll just buy the stupid anticondensation after this trip. Planning on posting in the trips in a few weeks, and doing a gear review.
  12. Oct 30, 2016 at 7:36 PM
    #9132
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Takes about 10 minutes to set up the RTT.
    About 30 minutes if the wife ventures along.......
  13. Oct 30, 2016 at 7:41 PM
    #9133
    SCHALICKE
    SCHALICKE Utahrd
    S. Champ
    Clearfield UT
    2015 Tacoma TRD OFF Road
    Never Enough
    I hope this helps...
  14. Oct 30, 2016 at 8:31 PM
    #9134
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    have a side shot of the awning and RTT both opened? Trying to see how far back I can mount mine
  15. Oct 30, 2016 at 8:48 PM
    #9135
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    side shot with awning room..... Hope this helps out.
  16. Oct 31, 2016 at 8:22 AM
    #9136
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    When I got mine, I practiced setup and take down a few times and used a stopwatch to track it since I was curious. CVT Mt. Shasta. 7-1/2 minutes set up, 10 minutes take down. With a little more practice could knock a minute off of both. That is without setting up the annex.
    Jamart5 likes this.
  17. Oct 31, 2016 at 8:32 AM
    #9137
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Boom! Thanks for the order!! hope you enjoy it.
  18. Oct 31, 2016 at 10:43 AM
    #9138
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    You bet! Thanks for the quick responses and shipping, I know I will enjoy it for years to come
  19. Oct 31, 2016 at 3:23 PM
    #9139
    IkemanTx
    IkemanTx Well-Known Member
    Isaac
    2017 4X4 SR5 Tacoma
    With the Mt. Denali Summit Series being 87" long, do you know of any issues with trying to mount it to a standard bed rack for a DCSB? I haven't seen any other mention of the Denali on the forums except your post, and I am not very familiar with CVT's mounting dimensions. I can find overall size for closed and open tent, but I cant find specs for where they require support bars.
    EDIT, I just re-read and you said summit series Renier.... never mind.
  20. Nov 1, 2016 at 7:57 AM
    #9140
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    I have the Denali on my trailer. Here are some pictures. Keep in mind that the trailer lid is 6'x6' square.
