*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Dec 28, 2016 at 5:50 AM
    #9761
    HighonFirewood
    HighonFirewood All hail the Riff...
    Stage Left. Colorado.
    5.7 V8 Tundra
    +1. Telescope or just get a rope like high school gym class and scale it!
    tacorgidor likes this.
  2. Dec 28, 2016 at 6:04 AM
    #9762
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    All right ill have to replace my ladder with another telescoping one then. Doesn't do me any good if it collapses when I climb up
    Box Rocket likes this.
  3. Dec 28, 2016 at 7:38 AM
    #9763
    MTgirl
    Weesa
    Bob's secret mod lair
    the dimensions on the site include the ladder
    you can screw them to the base - but it makes cleaning the tent tougher as the mat is not as easily removable. i leave my loose and when its time to close up the tent I fold the mattress up, place the mat on top, then close the tent. when its time to set up again the mat and mattress will stay on the bottom side and not slide out
  4. Dec 28, 2016 at 7:59 AM
    #9764
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    All y'all who use bungee cords / shock cords inside your RTT to pull the sides in when folding it:
    What length are y'all using (unstretched)? Don't want to put something that will pull the sides in too tight
  5. Dec 28, 2016 at 10:04 AM
    #9765
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    We just took my ladder and threw it in the Mill before installing. Drilled holes the entire length. Can adjust it to whatever we need. works perfectly and was free-99.
    Drainbung likes this.
  6. Dec 28, 2016 at 12:19 PM
    #9766
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Soft Shell!
  7. Dec 28, 2016 at 12:44 PM
    #9767
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Did you reinforce your shell at all to distribute weight? Mine is pretty solid up there but I keep kicking around the idea of adding more support somehow.
  8. Dec 28, 2016 at 12:51 PM
    #9768
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  9. Dec 28, 2016 at 1:03 PM
    #9769
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    looks about a foot at most
  10. Dec 28, 2016 at 1:31 PM
    #9770
    Techoma
    Alta Mesa, AZ
    Not at all. I have the front and rear @PrinSu racks which I think distribute it pretty well. 2 of us were up in it moving around and it felt good and solid... no noticeable crreeeeks.
    AZ2013[QUOTED] likes this.
  11. Dec 28, 2016 at 2:37 PM
    #9771
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Thanks. What's the height of the non-ladder part? That's what I really want to make sure is aligned with the top of my cab, as I build a bed rack. My guess is that it's something like 14".
  12. Dec 28, 2016 at 9:03 PM
    #9772
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Just a reminder that I can get you 10% off on any of the Tepui tents if you're looking to upgrade.
  13. Dec 29, 2016 at 4:51 AM
    #9773
    cglasco
    cglasco Well-Known Member
    Chad
    Amarillo,Tx
    2012 Toyota Tacoma Texas Edition
    king coilovers,arb bumper,winch,hard shell,RTT
  14. Dec 29, 2016 at 7:39 AM
    #9774
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    That's why I tagged you :anonymous:
    Box Rocket[QUOTED] likes this.
  15. Dec 29, 2016 at 7:57 AM
    #9775
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I like that! nice work :thumbsup:
  16. Dec 29, 2016 at 9:03 AM
    #9776
    Cascadia Tents
    Cascadia Tents Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    The tent is 12" The rails under it are an 1" and the rest is the ladder on top.
  17. Dec 29, 2016 at 9:04 AM
    #9777
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    We can save you 15% off your purchase.
  18. Dec 29, 2016 at 9:08 AM
    #9778
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    He did order the less expensive one. It is a 2 piece depending on the size. It will need to screw the self tappers into the joists in the floor. We normally just put the screws at the ladder side for the mat.
    The 1st one shows the mat. We screwed it down in the beginning with longer straps. The 2nd one is the floor underneath the aluminum sheet.
    mbmack1 likes this.
  19. Dec 29, 2016 at 9:12 AM
    #9779
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    Just a heads up as we are having a blowout discontinue sale on our manual Mt. Thielsen tents.
    They have no warranty at these prices.
    ****This one is $650.00 plus shipping
    Floor
    210D Polyoxford P/U
    Mattress
    3″ thick high-density foam with removable/washable cover
    Weight (Empty)
    120 lbs.
    Travel Cover
    450g PVC
    Ladder
    Telescoping ladder
    Tent Size
    Large
    Fabric
    Inner walls: 190g poly/cotton rip-stop P/U
    Lift Gate Delivery
    If a lift gate is needed to unload your new tent there is a $65.00 surcharge. Please select this option when checking out.
    Shipping
    USA only, excludes Hawaii and Alaska. Free local pickup. Please call 541-312-8368 for a quote on shipping outside the US.
    Size (Closed)
    Standard tent: 90″ wide x 55″ long x 12″ high
    ****This one is $750.00 plus shipping
    Floor
    210D Polyoxford P/U
    Mattress
    Weight (Empty)
    125 lbs.
    Travel Cover
    450g PVC
    Ladder
    Telescoping ladder
    Tent Size
    Extra Large
    Fabric
    Lift Gate Delivery
    Shipping
    Size (Closed)
    Large tent: 90″ wide x 63″ long x 12″ high
    CVT_Mt. Thielsen_RTT_Roof_Top_Tents_Wireless_Remote_Best_Cascadia_Vehicle_Tents,7.jpg
    CVT_Mt. Thielsen_RTT_Roof_Top_Tents_Wireless_Remote_Best_Cascadia_Vehicle_Tents,6.jpg
    CVT_Mt. Thielsen_RTT_Roof_Top_Tents_Wireless_Remote_Best_Cascadia_Vehicle_Tents,9.jpg
  20. Dec 29, 2016 at 9:20 AM
    #9780
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    god dammit
    dan0mite and Acerwin like this.
