*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jan 1, 2017 at 9:49 PM
    #9821
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    @VolcomTacoma
    Have you seen instances of a roof collapsing from a RTT and people being on it? Not trying to be a dick. Genuinely curious. Because if you go to CVT's Instagram page they have pictures of Tacomas to Outbacks with RTT's mounted on the roof and I feel like this would have been brought up already if it was an issue.
    Cascadia Tents likes this.
  2. Jan 1, 2017 at 9:52 PM
    #9822
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    No, but I also havent seen anyone strap a full size RTT on the stock roof rack and throw 2 people and gear in it. If anyone else can speak up to have done that, hey NBD. But weight limits are there for a reason lol
    LTDSC and Gramps like this.
  3. Jan 1, 2017 at 9:59 PM
    #9823
    BenTheMan
    Ben
    Portland
    Truck Nutz
    Go on CVT or Tepui's Instagram and you'll see hundreds of examples of exactly that.
  4. Jan 1, 2017 at 10:00 PM
    #9824
    BenTheMan
    Ben
    Portland
    Truck Nutz
    I mean they are called ROOF Top Tents...
  5. Jan 1, 2017 at 10:12 PM
    #9825
    VolcomTacoma
    Jeff
    NorCal
  6. Jan 2, 2017 at 5:01 AM
    #9826
    MTgirl
    Weesa
    Bob's secret mod lair
    :wave:
  7. Jan 2, 2017 at 5:42 AM
    #9827
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I would be curious to know what Toyota says the weight limit is on a 4r roof. On DC Tacomas the weight limit is 250lbs. Even the instructions on my Frontrunner Roof rack say "do not exceed the factory roof rack weight limits". But we all know the Frontrunner or the Prinsu rack can handle a lot more weight. My guess is that maybe not immediately, but over time you will see the roof start to sink in at the mounting points due to the weight on each individual mounting point. The mounting point is the limiting factor I bet.
  8. Jan 2, 2017 at 5:42 AM
    #9828
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I forget the damn thing is up there myself...
  9. Jan 2, 2017 at 9:42 AM
    #9829
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I use a memory foam mattress topper. I think it's 2" thick. Makes a huge difference
    Cascadia Tents and Gramps like this.
  10. Jan 2, 2017 at 4:41 PM
    #9830
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    What size foam mattresses do we need? I assume it needed to be cut to fit. Thinking about taking the stock pad out and putting in a 4".
  11. Jan 2, 2017 at 4:43 PM
    #9831
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Well I have a Mt. Ranier. I bought a king size foam topper which is the right width but is not quite long enough to cover the whole mattress. It's big up there.
    LTDSC likes this.
  12. Jan 2, 2017 at 5:21 PM
    #9832
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Looking at measurements, looks like I'd have to get a king and to a bit of chop-chop to it. It could work.
  13. Jan 2, 2017 at 8:51 PM
    #9833
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    Mt. Rainier FTW! Good to know for mine!
  14. Jan 3, 2017 at 10:08 AM
    #9834
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Manual on mine says 130lbs on the stock bars. 300lbs on the side mounted bars.
    Thule crossbars state 165lbs each bar. but that can quickly total out the stock weight capacity. Tent itself weighs 130ish pounds. add two people two it...over the cap quickly.
    I've been researching it as im looking to add a RTT on my 4runner, but i plan to get a Prinsu rack. Just because you have slept on top of factory rack, doesnt really mean its meant for it or can really handle the capacity.
    VolcomTacoma and Gramps[QUOTED] like this.
  15. Jan 4, 2017 at 9:26 AM
    #9835
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im just waiting for Fedex to call me when they are 1 hour away. To accept delivery of my tent!
  16. Jan 4, 2017 at 9:50 AM
    #9836
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Does anyone make a filler piece to fit between two ARB awning windbreaks? Basically to fill the triangular space left over. If not, does anyone know a source for a similar material? Seems fairly straightforward to create a piece that fits using velcrostrips to attach to the sides.
    Not my photo, just one I grabbed off google that illustrates what I'm talking about.
  17. Jan 4, 2017 at 9:53 AM
    #9837
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    tarp and bungies
    tacot0wn and Cascadia Tents like this.
  18. Jan 4, 2017 at 10:05 AM
    #9838
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    Testing out the new tent this weekend?
    fatfurious2[QUOTED] likes this.
  19. Jan 4, 2017 at 10:06 AM
    #9839
    fatfurious2
    David
    Ashburn, VA
    yes sir! i will probably open it for the first time on Friday. Sucks that I am working now
    FIRE74[QUOTED] likes this.
  20. Jan 4, 2017 at 2:13 PM
    #9840
    Cascadia Tents
    Cascadia Tents Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    How dare you post it up on here...:duel:
    LTDSC, Thelgord, Spansfelder and 2 others like this.
