*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jan 8, 2017 at 7:57 AM
    #9901
    HighonFirewood
    HighonFirewood All hail the Riff...
    Stage Left. Colorado.
    5.7 V8 Tundra
    PS. I'm grabbing bed rails on the 21st. Gonna cut em down and I'll PM ya when they are done. I'll be in Denver a couple times in February
    kashtyaatsi[QUOTED] likes this.
  2. Jan 8, 2017 at 8:20 AM
    #9902
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Parked at 13 degrees, woke up at 6 degrees. I am always under prepared. I need more gear!
  3. Jan 8, 2017 at 8:30 AM
    #9903
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    In temps like that is a bad time to figure out you are under prepared. :eek:
    Hope ya stayed warm at least
  4. Jan 8, 2017 at 9:12 AM
    #9904
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Love my iguana tents one. Decided to give them a try since they're localish
    LTDSC[QUOTED] and fatfurious2 like this.
  5. Jan 8, 2017 at 9:19 AM
    #9905
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  6. Jan 8, 2017 at 9:31 AM
    #9906
    92se-r
    92se-r Well-Known Member
    Been trying to do some research on RTT's on roof racks on the cabin. I keep seeing weight ratings for the factory mounting points being way too low for a RTT with occupants. How are people doing the RTT over the cab? Any issues? This would be for a 3rd gen.
  7. Jan 8, 2017 at 9:40 AM
    #9907
    VolcomTacoma
    Jeff
    NorCal
    Its totally fine. People do it all the time. Don't worry about "weight ratings" and such.
    LTDSC likes this.
  8. Jan 8, 2017 at 9:42 AM
    #9908
    92se-r
    Custom mounts or factory rack?
  9. Jan 8, 2017 at 9:43 AM
    #9909
    VolcomTacoma
    Jeff
    NorCal
    Doesn't matter.
  10. Jan 8, 2017 at 9:54 AM
    #9910
    HighonFirewood
    5.7 V8 Tundra
    I think they set weight ratings so low to cover any sort of issues. So if it actually holds 1000lbs they set the rating at 300lbs, this isn't factual but I know in most industries it's better to play the low safe angle then spec it at actual...because if it fails.
    Drainbung likes this.
  11. Jan 8, 2017 at 11:08 AM
    #9911
    Backcountry chef
    Backcountry chef Well-Known Member
    Justin
    2008 DCSB TRD offroad
    Thanks for the camping with kiddos advice!! This is the year we return to the backcountry....
  12. Jan 8, 2017 at 11:09 AM
    #9912
    Backcountry chef
    Justin
    Pulled the trigger today on a Mt Rainer extended summit series tent!! The Tnation discount code saved us $600 bucks!! We are so excited
  13. Jan 8, 2017 at 11:12 AM
    #9913
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    i went this route.
    https://www.tacomaworld.com/threads/rhino-rack-has-arrived-at-rack-attack-ditch-mount.418798/
    i take the tent off with the bars attached via the quick release mechanism.
  14. Jan 8, 2017 at 3:36 PM
    #9914
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Just curious... Did you replace the entire foam mattress with this or did you just get rid of a foam topper? I'd imagine that since this self inflates, you could deflate it and keep it in the tent whole making it easier to fold up the tent? I'm currently using a foam topper which has been comfy but makes folding up the tent a little trickier. Curious to hear how this has worked out for you.
  15. Jan 8, 2017 at 5:00 PM
    #9915
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Lawyers....
  16. Jan 8, 2017 at 7:56 PM
    #9916
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I took the foam mattress out completely, and put the air mattress in its place. When I deflate the air mattress, I have enough room left to close the tent with the sleeping bag and pillows still inside without any issues getting it closed. Not to mention the air mattress is comfy and has way more support then the foam mattress!
    kashtyaatsi and Gramps like this.
  17. Jan 8, 2017 at 8:09 PM
    #9917
    HighonFirewood
    5.7 V8 Tundra
    I'm tempted to use both...
  18. Jan 8, 2017 at 8:12 PM
    #9918
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I would if I could get the tent closed with everything inside, but it's too thick.
  19. Jan 8, 2017 at 8:17 PM
    #9919
    HighonFirewood
    5.7 V8 Tundra
    Yeah. I figured as much. Could you leave your bag in with the foam prior? Or just now that you have the air mattress
  20. Jan 8, 2017 at 8:19 PM
    #9920
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I can leave my queen size sleeping bag in with my foam mattress and close the tent pretty easy. Next time I have it out I plan to try leaving pillows as well and see how that goes.
    LTDSC likes this.
