*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Apr 9, 2017 at 10:08 AM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Got my kukenam mounted and opened yesterda, but what are the straps on the hinge side for, under the cover?
  2. Apr 9, 2017 at 10:44 AM
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Roll up your cover and tie with straps to keep the weight of the cover from hanging off the zipper itself.
  3. Apr 9, 2017 at 10:59 AM
    hobiecat111629
    Ah, I just stuffed the cover into the Plano bin in the bed while we were messing around and didn't even think about rolling the cover up
    scott96929[QUOTED] likes this.
  4. Apr 9, 2017 at 2:00 PM
    Andrew_v949
    Andrew_v949 Well-Known Member
    I like this setup how the tent opens up over the back. I was thinking of getting a camper shell, mounting an RTT on top of it where it opens this way and seeing if I rig the annex so it could encompass the back of the open campershell. anyone seen this done or think its feasible?
    kashtyaatsi and HighonFirewood like this.
  5. Apr 9, 2017 at 2:02 PM
    Robb_D
    Robb_D Well-Known Member
    Robb
    FoCo
    2016 BBP Tacoma DCSB TRDOR
    285/70 17 BFG AT KO2
    Should be doable. As long as the annex has the back door for vehicle usage. I don't think it'd be tight, you might have to rig up a method a nice fit.
  6. Apr 9, 2017 at 2:06 PM
    Andrew_v949
    Yeah..or I could just cut an opening in the annex just big enough to encompass the tailgate/campershell area and create a velcrow system or something to create a tight fit
  7. Apr 9, 2017 at 2:10 PM
    Andrew_v949
    In all honesty I want a Habitat....but damn, that price tag is mighty hefty if I could rig something up that is of similar concept and save 4-5k
  8. Apr 9, 2017 at 3:15 PM
    HighonFirewood
    HighonFirewood All hail the Riff...
    Stage Left. Colorado.
    5.7 V8 Tundra
    When I put my RTT back on , I plan to have this setup this way...block the rain or whatever when I'm dealing with stuff in the bed of the truck..and have my awning shoot to the driver side. Then I can stay relatively under a room while out camping under the stars...haha. But really i wanna try it off the back. i think Ill end up preferring it that way
    kashtyaatsi likes this.
  9. Apr 9, 2017 at 8:06 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Now that the snow is melting and temperatures are remaining above zero I started getting my truck set back up for summer. I needed to relocate my TREDs from the roof rack where they spent the winter in order to make room for the canoe once all the ice melts sometime next month. It turns out the mounting tracks under my ARB tent are the right width to hang the TREDs from. I'm not sure I'm sold on the idea yet but it keeps them from banging around the bed in the meantime.
    scott96929 and KRAMERICA like this.
  10. Apr 9, 2017 at 8:19 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    This is how I currently have mine setup. For the most part, I like it. When I want to use the tailgate I prop the ladder up so I can stand under the tent. The tailgate is where I usually do the cooking. Also when closed up the ladder is in line with the truck and has less wind drag that way. But now I'm considering getting a 270° awning. If that happens I'll have to rotate it to open over the side, and the awning will cover the other side and over the tailgate.
  11. Apr 10, 2017 at 6:28 AM
    Andrew_v949
    what model tent do you have? can you post up pics
  12. Apr 10, 2017 at 6:34 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    That is a nice dual jerry can holder you have attached to the bed rail. Where did you get that? I am a ways from getting a rear bumper with a tire carrier and jerry can holder, and this would be perfect for what I need.
    scott96929 likes this.
  13. Apr 10, 2017 at 7:12 AM
    Backcountry chef
    Backcountry chef Well-Known Member
    Justin
    2008 DCSB TRD offroad
    So I did a thing this weekend!!
    jubei, Whitecloud, Blackout14 and 2 others like this.
  14. Apr 10, 2017 at 8:03 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    For rolling up the cover when the tent is open. Use the short Velcro straps for the cover straps with those so you don't have to leave the cover hanging down against the truck.
    JDR07[QUOTED], Gabex35 and scott96929 like this.
  15. Apr 10, 2017 at 11:13 AM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    Looking to put some kind of cover of the foam pad in my RTT. What do you guys recommend for something waterproof, and suitable to protect from the elements.
  16. Apr 10, 2017 at 12:11 PM
    TuckGraham
    Tg
    Montana
    Thank you for the info!
    Blackout14 likes this.
  17. Apr 10, 2017 at 12:46 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Its a simple homemade one using slotted angle iron and short cap screws. Nothing fancy but it works.
  18. Apr 10, 2017 at 12:53 PM
    riz_atx
    Sohail
    Spicewood Texas
    That is awesome! Thanks for the close up pic. Its got my mind racing a little on what I can do thats similar
  19. Apr 10, 2017 at 5:16 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Hahaha. Holy shit! was wondering what those were for. Awesome!
  20. Apr 10, 2017 at 7:56 PM
    KernelxSanders
    KernelxSanders New Member
    Hunter
    2005 Silver Toyota Tacoma
    Just starting out! Leveling kit was the first step
    Evening guys,
    First time posting here and I'm just getting into taking care of/working on my own rig so bare with me!
    I'm looking for an appropriate roof rack for my double cab '05 Tacoma. One that will be ideal for the Mt. Shasta CVT.
    Ideally I could mount the rack and tent on my canopy, but I'm a little gun shy of having to drill into the canopy if necessary and not opposed to just mounting it on the cab.
    Any and all suggestions/advice would be greatly appreciated!
