*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Aug 21, 2017 at 1:30 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Generally speaking, many RV's and/or trailers have an adjustable leveling prop on each corner. The blocks mentioned above are usually for keeping a solid platform to prop onto (like a high jack base) and/or to compensate for a little tilt. It's not entirely safe for an RV to be resting on a large block. If you need to level your truck more than 6", you should really be looking for a flatter area. If all else fails, find a couple LARGE rocks at your site.
    I personally carry a few small sections of 2x4's if i need a little lift. I try to keep it under 3 boards high as anymore than that and you can risk them slipping on themselves.
  2. Aug 21, 2017 at 6:00 PM
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    When getting my tent tight to my rack the rails bend a good 1/8" or so, is this common. I'm not sure how much I trust this lol
  3. Aug 21, 2017 at 6:23 PM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Hey now looking to pinch a few pennies. What are the feels on the number of bed bars to go with? Seeing a lot of racks with 3 but couldn't pass up on a sweet deal for 2 relentless bed bars. Is anyone feeling a difference using just 2 vs 3?
  4. Aug 21, 2017 at 6:35 PM
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    I've seen plenty of people run two bars. But for me, I want to better distribute the load so three bars made sense.
    bski22[QUOTED] likes this.
  5. Aug 21, 2017 at 6:43 PM
    bski22
    Rob
    Toyota
    That's my thought process also but vendor can't guaruntee 3rd single will match height of the other 2. Whatever I'm assuming if I go ruggudized tepui it should be a non issue due to the diamond plate base
  6. Aug 21, 2017 at 6:46 PM
    SnowyCactus
    SnowyCactus Well-Known Member
    Cole
    Arizona
    17' DCSB TRD OR
    Stock
    Yeah, i've been using 2x6 blocks but i've split them so many times I was looking for a better option. Some of the best spots with a view tend to be on a grade so I invariably end up building improvised wood/rock ramps. This was one of the sketchier setups.
    cglasco likes this.
  7. Aug 21, 2017 at 6:49 PM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I'm honestly so surprised on how many people need these leveling blocks. 25+ nights in the tent and I've yet to need some. This is camping in the rockies so not exactly flat either.
    smw62891, YamaDirtrider and tacot0wn like this.
  8. Aug 21, 2017 at 7:02 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    I've run my ruggedized Autanna with two bars and wouldn't recommend it still flexed too much for my taste. Now that I run 3plus bars it's solid...
  9. Aug 21, 2017 at 7:18 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    (Was not actually as crazy not level as it looks)
    BYJOSHCOOK likes this.
  10. Aug 21, 2017 at 7:21 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I like to be level or actually head higher than feet and just use rocks and/or small dig out.
    kashtyaatsi and MonkeyProof like this.
  11. Aug 21, 2017 at 8:00 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I stack rocks or sometimes little children or whatnot..
  12. Aug 22, 2017 at 3:13 AM
    5678ta
    Hogan
    Henderson, NV
    My tent almost came off during a desert run. Rail bolts on one side came out. Other two were snug tight when i removed them. Luckily I deployed for a picture and found it lifting. I probably would have lost the tent it I didnt.
    Here is my setup now with 3/8" grade 8 with nyloc nuts:
  13. Aug 22, 2017 at 7:07 AM
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    It amazes me how cheap these things are put together for almost $3k. They need to make an off-road version with better hardware.
  14. Aug 22, 2017 at 7:10 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    That'll be $4k
    jubei, Drainbung and utroda[QUOTED] like this.
  15. Aug 22, 2017 at 8:03 AM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Thats doesn't look level at all. o_O
    Maybe it's the angle of the pic:notsure:.
  16. Aug 22, 2017 at 8:04 AM
    tacomgee
    Blake
    NorCal - Ukiah
    Uh huh.....
    DannyBFresco[QUOTED] likes this.
  17. Aug 22, 2017 at 8:26 AM
    DannyBFresco
    Danny
    :luvya:
    tacomgee[QUOTED] likes this.
  18. Aug 22, 2017 at 8:33 AM
    UTBoatFanatic
    UTBoatFanatic Well-Known Member
    Don
    Midvale, UT
    2017 Dark Grey Tacoma Double Cab Off-Road - Manual Transmission
    Leer Shell
    Speaking of unlevel camping. We camped up near South Pass on our way to the Lander, Wyoming area to get into the zone of "totality" for the Eclipse. Great spot despite a bit of a tilt.
  19. Aug 22, 2017 at 8:34 AM
    5678ta
    Hogan
    Henderson, NV
    I went with Smittybilt. $800 brand new. Hahaha. The problem is the universal rail. The slots are tiny so real hardware just doesn't fit.
    utroda[QUOTED] likes this.
  20. Aug 22, 2017 at 9:13 PM
    SnowyCactus
    Cole
    Arizona
    17' DCSB TRD OR
    Stock
    It wasn't level. The front needed the same 8" +\- of lift as the rear. The front had maybe 5". The photo isn't level either which doesn't help. For all intents and purposes it was camping on a hill.
