*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Nov 21, 2017 at 7:33 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Having the ladder 'outside' has both pluses and minuses... The one thing I hate about it, moisture tends to collect in a pool on the rain fly and has a tendency to douse you with water when you exit the tent. And if wet and rainy outside, there's no way to enter/exit the tent without getting wet. I do prefer a full 360 degree view from the tent. I tend to get a bit claustrophobic without the view out the doorway.
    Like Brian, my annex (and RTT) are an older 'Camping Lab' model with three walls, no floor. Generally used for gear storage, clothes changing and potty area. It does store under the travel cover without disengaging from the RTT.
    Noles11, Drainbung and LTDSC[QUOTED] like this.
  2. Nov 21, 2017 at 7:58 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    perfect, we plan to just use it as a bathroom/storage and possible changing room.
    Box Rocket likes this.
  3. Nov 23, 2017 at 2:29 PM
    Dustink91
    Dustink91 Member
    Dustin
    TX
    2017 TRD OR, Manual Inferno
    Pelfrybilt skids (IFS, Mid, Transfer case), Leitner ACS.
    What size tent do y'all think it would take to sleep 3 adults? Not 3 large adults but still 3 normal size folks. Would it take a 72" wide like the 23zero Byron?
  4. Nov 23, 2017 at 5:26 PM
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    That depends if it's 2 women and 1 man or 1 woman and 2 men......
    LTDSC likes this.
  5. Nov 23, 2017 at 6:10 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Just picked up some sticky 4 ft USB LED's at Bestbuy for $14. Can change the color and the brightness up and down on them. Should work great in the tent!
    KRAMERICA likes this.
  6. Nov 23, 2017 at 9:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have a 56" wide model RTT and 3 (any 3) would be too many. 2 would be the max for comfort. 2 is a bit crowded in a 48" wide model.
    LTDSC likes this.
  7. Nov 23, 2017 at 9:42 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ^^^ This.
    72" should be OK for 3 normal sized folks. It'd still be tight for 3 larger people.
  8. Nov 24, 2017 at 8:50 AM
    Dustink91
    Dustink91 Member
    Dustin
    TX
    Thanks. Still trying to decide if I'm just gonna go with a standard 2 person or go bigger. It's just me but most of the big wheeling and camping trips I go on are with two others and everyone it one tent makes things easier for setup and planning.
    dustin19d likes this.
  9. Nov 24, 2017 at 10:03 AM
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    I wouldn't even consider the 48" wide ones an option unless you are by yourself 100% of the time... My significant other and myself are fairly small and we were cramped when we tried a 2 person tent.
    56" wide models could be possible if you're both on the smaller side. Even then it's gonna be uncomfortably tight for anything more than 2 average sized adults. Ours is comfortable for the two of us but I couldn't imagine trying to squeeze another person in there.
    72" wide is really the only option IMO to comfortably sleep 3 people but they come with a pretty large weight/size penalty.
    In your situation, I'd do a 56" wide with an annex--two people in the tent, one in the annex with a cot.
    LTDSC and TWENTYCO like this.
  10. Nov 24, 2017 at 10:19 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    [​IMG]I need a little help anyone running RCI Bed rack and a BAMF rack? RCI 12" high and BAMF is 10" high so the BAMF gets the RTT down a little lower to cut drag. I like the looks of both and they both have good mounting options! So just need opinions on Quality and any issue's on either. Thanks RCI BAMF.jpg BAMF
    LTDSC and alphabravo like this.
  11. Nov 24, 2017 at 12:13 PM
    MacAdoo
    MacAdoo Well-Known Member
    Dana
    2016 Tacoma Off Road DBL Cab
    RCI Skid, RCI bed rack, Tepui RTT, Pelfreybilt bumper - ordered
    @Dave2016trdsport4x4
    I have the RCI and it's great. I keep a notebook in the glove box and do manual MPG notes at each fill up. I never saw any difference once I put the rack and Tepui on top. Still getting about 19 MPG. Sometimes a little less, sometimes a little more.
    TWTaco likes this.
  12. Nov 24, 2017 at 12:14 PM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I don’t own either but i have several BAMF products and have seen their rack in person. Jerry and his crew do a great job and quality is spot on. I would highly recommend any BAMF products
    t.hornstra, LTDSC and TWTaco[QUOTED] like this.
  13. Nov 24, 2017 at 1:36 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    That BAMF rack looks sweet. I wonder if they could make a 12" rack. It looks like 12 inches is about right to have some kind of view out the rear window and also not have the full tent above the roof in the wind.
  14. Nov 24, 2017 at 6:54 PM
    rob1208
    Rob
    SF Bay Area
    I’m sure Jerry could, it would just be a custom rack but he can make it however you want.
    Actually @Dave2016trdsport4x4 that bamf pic you posted looks like the new expo bed BARS with side plates that BAMF is making (pic looks like @t.hornstra truck). This is the bed rack (you can see the cross bar connecting the two vertical bars are welded and not bolted together)
    http://www.bayareametalfab.com/Low-profile-RTT-bed-rack-2016-plus-Tacoma-_p_72.html
    I got to see those expo bed bars in person, if i decide to get rid of my shell, I’m going to either go with a full height bed rack that bolts to the bed bolts or the new expo bed bars. I like how you get the benefits of a bed rack but the expo bars can be disassembled and put away on a shelf in the garage
    alphabravo[QUOTED], LTDSC and TWTaco like this.
  15. Nov 24, 2017 at 8:30 PM
    TWTaco
    Dave
    Yeah i didnt see it until i had already got the RCI Bed rack. I would have gotten this new expo set up its really nice and its pretty dam cheap right now with the discount!
    rob1208[QUOTED] likes this.
  16. Nov 24, 2017 at 8:30 PM
    TWTaco
    Dave
    I think i will be plenty happy with RCI !
  17. Nov 24, 2017 at 10:08 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    You will be- I love mine! I may have dropped a bit of MPG's (Read:1-2) with the partially exposed tent, and the added weight with my truck loaded down could have played in too.
  18. Nov 25, 2017 at 3:32 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Compare tent size to mattress size. My CVT Shasta standard (56") is equivalent to a queen bed(60"). Cozy for 2 people.
    You could always get one with an annex and stick someone on the ground - 2 people up and 2 people down. Just adds a bit to your set up and teardown
    TWENTYCO likes this.
  19. Nov 25, 2017 at 3:35 PM
    MTgirl
    Weesa
    Wee bit frosty this morning. :cool:
    This officially the latest in the year I have ever camped. Surprisingly not the coldest though
  20. Nov 25, 2017 at 4:53 PM
    MacAdoo
    Dana
    The seam tape along the interior seams in my Tepui Autana is peeling off easily. I'll need multiple feet to redo it correctly, but I'm having a hard time finding long rolls of clear that are about 3/4"-1" wide, and designed for tents without ironing on. Do you feel the tape is truly needed? Will it actually keep water out? I really don't want to do the tube of seam sealer all over the inside, but I may have to. Thoughts?
