*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. May 1, 2018 at 3:08 PM
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    Gorgeous !
    BHill_teq[QUOTED] likes this.
  2. May 1, 2018 at 3:44 PM
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    Do you have any pictures of the inside where the tailgate folds down? Does it interfere with the ladder? and is the back opening big enough to where you can access the truck bed and close enough to prevent too big of an opening?
  3. May 2, 2018 at 6:41 AM
    MMoreno16
    MMoreno16 Cupcake Forest Ranger
    Los Angeles
    2018 TRD OR DCSB
  4. May 2, 2018 at 7:19 AM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    I'm curious to know your thoughts on the Yakima Skyrise... I either see people loving it or hating it.
  5. May 2, 2018 at 7:29 AM
    MMoreno16
    Los Angeles
    2018 TRD OR DCSB
    I'll share my thoughts after I get to really use it. Reviews I've read are more negative towards the smaller version. So far I really like it, super easy to set up. Very comfortable and super light at 115lbs. The material is not as thick as CVTs or other RTTs so well see how it holds up, but that is the reason I went with this one... Lightweight from a company known for their quality. :thumbsup:
    jeremy5000[QUOTED] likes this.
  6. May 2, 2018 at 8:31 AM
    ARDnc
    ARDnc Well-Known Member
    Charles
    2015 Toyota Tacoma
    Fab Fours Vengeance front bumper
    IMG_20180501_165111008_HDR.jpg Almost ready to ride. Waiting on my airbags and two clamps to be made. But it's up there. IMG_20180501_165132511_HDR.jpg
    spaculley, 90yota, honda50r and 3 others like this.
  7. May 2, 2018 at 8:32 AM
    MMoreno16
    Los Angeles
    2018 TRD OR DCSB
    That tent is huge! :eek:
  8. May 2, 2018 at 8:34 AM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Mt. Denali Extended, I got the Summit Awning also, tried to install it yesterday and had no hardware, CVT is sending to me now. Awesome tent by far.
    MMoreno16 likes this.
  9. May 2, 2018 at 8:40 AM
    MMoreno16
    Los Angeles
    2018 TRD OR DCSB
    Awesome! What color did you get?
  10. May 2, 2018 at 9:08 AM
    Murdoch33
    2018 Black TRD Pro
    Nice!
    What airbags and clamps are you getting?
  11. May 2, 2018 at 9:19 AM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Gray, and I ordered the Firestone rear air bags, I have a cooler/rod rack I put out the rear receiver also, so I need the extra spring for towing that thing. I have the Helwig overload springs now, but I don't think they will work with the tent on also.IMG_20170830_123130932.jpg
  12. May 2, 2018 at 9:39 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The Ride Rites are great, had them on my 2012. Ran the valves to either side of the license plate and used a bike pump (I have a fat tire bike pump that only goes to 30 psi, so it's accurate at the lower pressures). With your setup, you might want to make the valves more accessible from the side. Do NOT tie the bags together to a single inflation valve -- unless you like to feel like you are tipping over when cornering. Someone posted a good rule of thumb for determining the right pressure -- 1 psi for every 40 pounds of weight is a good starting point. With where you have the weight hanging of the back with more leverage, may need to add a little.
  13. May 2, 2018 at 9:43 AM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Thanks, I actually bought the union tee fitting, but I'll just skip that. Thanks for the info
  14. May 2, 2018 at 10:08 AM
    Murdoch33
    2018 Black TRD Pro
    Are you installing Daystar cradles for the bags? I’m going to get the same bags but not sure if cradles are necessary.
  15. May 2, 2018 at 10:27 AM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Not sure what they are, was going to install the kit as it came. What are these Daustar cradles your speaking of? I assume these are poly bushings of some sort
  16. May 2, 2018 at 10:30 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Allows the bottom of the airbag to "float".
    BravesRunner likes this.
  17. May 2, 2018 at 10:33 AM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Got ya. So instead of it being secured to the leaf spring it just floats over the cup. I'll have to check those out.
    Drainbung likes this.
  18. May 2, 2018 at 10:37 AM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Correct. I think they run around $70 for the pair. I also remember seeing a package deal with bags and cradles somewhere, maybe Amazon.
  19. May 2, 2018 at 11:11 AM
    Murdoch33
    2018 Black TRD Pro
    Necessary ?
    Do you like them?
  20. May 2, 2018 at 11:41 AM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    If you're going to run them I think it's a good idea to have them floating. I've had them on since 2012, no complaints.
    Murdoch33[QUOTED] likes this.
