*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jun 5, 2018 at 11:04 AM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Look around for tamper resistant mounting hardware. I've also seen people use cable locks to lock the tent to the rack. If somebody really wants your tent neither will stop them from taking it, but it'll slow them down a bit? :notsure:
    LTDSC and 0uTkAsT like this.
  2. Jun 5, 2018 at 11:17 AM
    bunk
    bunk Well-Known Member
    Looking at doing something similar, as I'm a side sleeper also. to @Backcountry chef, what type of foam did you put on top of your stock mattress? and to @GoGoGadget, do you find the memory foam is providing enough support? I will have to go with something other than memory foam is it's too cold up here in Canada and memory foam is known to become very stiff when cold. Thanks guys!
  3. Jun 5, 2018 at 1:18 PM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    Anyone running the hardshell RTT from Bigfoot Tents? I'm looking at the clamshell styles.
    Feedback?
  4. Jun 5, 2018 at 1:30 PM
    GoJo
    GoJo Well-Known Member
    Utah
    I used the 5/16 - 18 Spanner nuts from McMaster Carr to mount my tent to my rack. Spanner nut on to synch the bracket down, and then lock washer and nylon nut tight against the spanner to prevent from vibrating back out.
    https://www.mcmaster.com/#catalog/124/3302/=1d5msmd
    Then to mount my rack to the truck bed I used Torx Head Bolts with lock washer and nylon nut on the back in the J-Channel
    https://www.mcmaster.com/#catalog/124/3111/=1d5mtct
    xsf18cdf likes this.
  5. Jun 5, 2018 at 1:34 PM
    GoJo
    Utah
    If you go the Spanner nut route, note that the driver you have to buy along with it you will have to most likely modify as the "throat" of the bit isn't deep enough for the bolt. I cut mine off and drilled a 5/16" hole through it and then welded it to a deep 3/8" drive socket I wasn't ever going to use.
    Pickeledpigsfeet likes this.
  6. Jun 5, 2018 at 3:03 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    https://www.wheeleveryweekend.com/products/rtt-security-clamps
  7. Jun 5, 2018 at 4:11 PM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Yes, the combination of the softer memory foam on top of the OEM firm mattress worked well for me. Now I just need a king size sheet to cover it all as the memory foam has that rubbery feeling so as body parts slid out of the sleeping bag it annoyed me.
    this is the topper I used.
    https://smile.amazon.com/gp/product/B06XS1YNLM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Backcountry chef and realsystem like this.
  8. Jun 5, 2018 at 4:55 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    BYJOSHCOOK, E-Paz 732NJ and Drainbung like this.
  9. Jun 5, 2018 at 9:39 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    Ok so update, I hated my mattress so from foambymail.com I ordered 1 inche of mattress Lux foamhq and 2 inches of hd36 foam h. The hq foam is a little higher quality so it should last longer in a RTT. The 2 inch stuff is softer than the 1 so when combined they perform a good dampening system without bottoming our. I weigh aabout 210 and my wife about 140. OMG this is so much more comfortable than the original mattress and cost $160. Memory foam gets hard when it’s cold, and latex is $$$ so this is an excellent solution. HIGHLY recommended and it’s free shipping !
    BlueRidgeFly, Martyinco and Phessor like this.
  10. Jun 6, 2018 at 8:14 AM
    realsystem
    realsystem Well-Known Member
    Stanislav
    SF Bay Area, CA
    2017 MGM Tacoma TRD OR DCSB | 2021 Cement Tundra SR5
    LT,37s,5.29,Kings,Camper,Deavers,snorkel,winch,CVCtune
    Just curious how hard is that when cold? I understand it's not possible to explain in words. Is it like plywood? :)
  11. Jun 6, 2018 at 9:02 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    VERY hard- I have a sleeping platform in the back of my truck and I got a gel mattress topper. Camped in 36 degree weather and it was like sleeping on a board until you lay on it long enough- then it sinks in but the problem is the surrounding is still hard so you can't roll at all. You're stuck like Han Solo.
  12. Jun 6, 2018 at 9:45 AM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    I solved this issue with mr. heater. Let the tent warm up for 20 mins before bed and not only is the mattress soft, but the blankets/bag are nice and cozy too.
  13. Jun 6, 2018 at 10:15 AM
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    I’m in L.A. but I had my rack made by @DrWeld from SD. Excellent build!
    He built me the exact rack he has on his truck. Check him out if you need any fab work etc.
    DrWeld likes this.
  14. Jun 6, 2018 at 11:30 AM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    So do you use the softer material on top and the more firm one below to create a kind of progressive pack? (Sounds like we are talking about other truck parts now, haha)
  15. Jun 6, 2018 at 12:44 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Total of 5".
    realsystem[QUOTED] likes this.
  16. Jun 6, 2018 at 2:48 PM
    Murdoch33
    2018 Black TRD Pro
    REI Garage Sale is 6/9.
    Possible returned Tepui at steep discounts. As well as other gear.
    Do it!
    fatfurious2 likes this.
  17. Jun 6, 2018 at 2:58 PM
    Murdoch33
    2018 Black TRD Pro
    What products are you guys using to prevent mildew and clean tent after multiple rainy days? I’m airing out tent now and plan on cleaning this weekend.
  18. Jun 6, 2018 at 3:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Can you comment a little further on this 2 foam combo you are using. Why did you use that particular combo? Was it from a recommendation from them?
    I was looking at their website and couldn't find "hd36 foam h". I did see:
    HD36 Regular Foam
    HD36 High Quality Foam
    HD36-R Foam - Standard Mattress
    HD36-HQ Foam - Standard Mattress
    Do you remember which of these it is?
    Are you also using the original mattress too? What is the order of the various layers?
  19. Jun 6, 2018 at 3:21 PM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Will they still fold up with the extra pads/foam?
  20. Jun 6, 2018 at 3:25 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    have yet to use it on the tent but i like using Odo-Ban for all cleaning like that. Leaves a good scent, is cheap and a disinfectant.
