*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jun 21, 2018 at 6:24 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I asked sumosprings customer service the same question, and this was their response. I don't have personal experience with the 500lb springs, but the 1000lbs haven't seemed to harshen the ride when I'm unloaded.
    "Thank you for your entry.
    For most cases I would recommend the 47 as it will provide for more muscle without compromising current ride quality.
    If you don't believe you need the extra muscle because you are never loaded to much then the 500 is more than enough.
    The SumoSprings have a progressive nature, this being said they get stronger with more load and are soft to compress when not under load."
    DoorDing likes this.
  2. Jun 21, 2018 at 7:01 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Thank you, sir. Sounds like the 47 would be best for the typical RTT setup with gear. I did the Firestone Ride Rites on my 2012 and liked them, but they were a pain to install (not hard, but the nuts and bolts for the brackets almost require baby fingers) and require messing with air pressure for different loads. I've looked at these before, seem like a great option. A little pricey for what they are, but simple and look to be easy to install.
  3. Jun 21, 2018 at 3:47 PM
    WhiteBeltBatman
    WhiteBeltBatman Well-Known Member
    Bay Area, CA
    2017 Super White TRD Pro
    So I've seen people with shells on their truck with larger RTTs on that extended over to the cab rack (and either resting, or attached, to the cab rack) and/or hang pretty considerably over the rear of the camper.
    A setup similar to this: (not sure who owns this or if they're a member)
    I know the bed and cab aren't as one when wheeling, but has anyone seen or experienced any damage to the truck or RTT as a result?
    I'm considering getting an ARE shell and a CVT Mt Rainier or ikamper, so I'm wanting to know if it's something to just be careful/smart with or if it's typically a bad idea.
    BYJOSHCOOK likes this.
  4. Jun 21, 2018 at 7:17 PM
    Jclaa
    Jclaa Well-Known Member
    17 Tacoma 4x4 4door
    Vehicle Modifications:
    I have the rainier mounted on a leer shell. It hangs over the cab but is lifted about 1/2” above the shark fin. No problems with movement. I would not fix it to the cab though. Have you looked how much those move while off road!? I would think it would fatigue any thing aluminum, like the support rails for the tent, very quickly.
  5. Jun 22, 2018 at 4:43 PM
    Strand31p
    Strand31p Well-Known Member
    Steven
    Glendale AZ
    2017 TRD off-road
    Got some new mounting brackets for my tent. My rack is made from 1-3/4 tubing and did not like the mounts my tent came with so I picked these up from a local fab shop.
    R09ster, -40, WPNZ and 13 others like this.
  6. Jun 23, 2018 at 12:57 AM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Those are a great idea!!
    Strand31p[QUOTED] and LTDSC like this.
  7. Jun 23, 2018 at 5:02 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Mount the tent to the cap or the cab, but not both. They move quite a bit relative to each other. I'd leave an inch or so for flex.
  8. Jun 24, 2018 at 12:26 PM
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    ABSOLUTELY LOVE THIS TENT
  9. Jun 24, 2018 at 9:01 PM
    sfgiantsguy28
    sfgiantsguy28 Active Member
    2018 Tacoma TRD Pro
    Maiden Voyage with RTT.
    nofives, Arcticelf, Drainbung and 8 others like this.
  10. Jun 25, 2018 at 9:13 PM
    el taco pastor
    el taco pastor Well-Known Member
    Alan
    I represent the YAY AREA
    Plasti dip emblems Led interior lights Sema pro rims Nitto trail grapplers Bilstein 5100 all around with read AAL
    How’s this working for you? I just ordered me some of those clamps off summit racing.
  11. Jun 26, 2018 at 5:31 AM
    Strand31p
    Steven
    Glendale AZ
    2017 TRD off-road
    The clamps work great. Holds the tent down nice and sturdy. Would definitely recommend them. They just look nice and clean too not like the one that come with the tents. The only thing I did to mine was I grind down where the bolts go through on the nut side. I just wanted more threads on the bolt to be showing so the lock nut could do its job.
  12. Jun 26, 2018 at 9:16 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    You don't want it hanging over the rear? I would want to make full use of the rack. I have an access cab, so rack space is important to me.
    That is a badass truck though!
    Drainbung and Strand31p like this.
  13. Jun 27, 2018 at 8:40 AM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Set up my tent and my friends yesterday night, took about 1 hour each with 2 people working on each. CVT Mt Shasta’s. Super excited to use it, first night in it will be Friday!
    Has anyone sprayed a waterproofing spray on these tents? Like CampDry? Or should I just leave well enough alone?
    BHill_teq and Drainbung like this.
  14. Jun 27, 2018 at 9:20 AM
    shane310
    shane310 Well-Known Member
    Shane
    Los Angeles, CA
    2016 DCSB TRD OR SW
    That is a nice looking tent
  15. Jun 27, 2018 at 9:21 AM
    shane310
    Shane
    Los Angeles, CA
    2016 DCSB TRD OR SW
    Should be fine without it. I've been in a tepui before in heavy rain and thunderstorms and it was solid, absolutely no leaks or water.
    E-Paz 732NJ likes this.
  16. Jun 27, 2018 at 12:25 PM
    Rock-N-Roll
    Rock-N-Roll Well-Known Member
    James
    Westminster, CO
    2021 T4R TRD ORP
    One mod away from marriage counseling
    Pretty bummed. Brand new Tepui tent only used once and it has very thin spots on the rain fly. It looks like I have two options. Pay for it to go to Tepui to see if they would replace it OR return to REI and be out of a tent while they inspect, file a claim, ship the tent back and wait for a new one to be delivered. Anyone else go through this?
  17. Jun 27, 2018 at 12:46 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I had the exact same problem with mine last year. Luckily for me I realized the issue when the tent leaked on me at the NW overland rally where Tepui had a rep onsite. I talked to him and he gave me his contact info, I sent him an email when I got home and they sent me a brand new rain fly. I haven't had a chance to use it in the rain yet but this one looks much better than the original.
    Rock-N-Roll[QUOTED] likes this.
  18. Jun 27, 2018 at 12:48 PM
    Rock-N-Roll
    James
    Westminster, CO
    2021 T4R TRD ORP
    Thanks! Maybe it's worth a call to see if they can just swap the rain fly. Who wants to ship these things all over the place anyway? Doesn't make sense. REI already confirmed they have to take the whole thing back and follow the process.
  19. Jun 27, 2018 at 12:58 PM
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    I bet if you call them they can work with you. The rain fly can pack down pretty small when it's off. All they asked for from me was to email a receipt for proof and date of purchase.
    Does yours have the plastic snap buckles on the straps or does it have just the strap through the cinch slider to snug it down?
  20. Jun 27, 2018 at 1:01 PM
    Rock-N-Roll
    James
    Westminster, CO
    2021 T4R TRD ORP
    Yeah I just emailed them. My tent has buckles I do believe.
