*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Mar 12, 2019 at 10:05 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    So long as the ladder deploys off the end I think it would work since it usually gives you ~48 inches from the hinge and the angle of the ladder would probably give another 8-12 inches... If it's one of the tents designed for use with an annex it will definitely fall short.
  2. Mar 12, 2019 at 10:17 AM
    18CementTaco
    18CementTaco Well-Known Member
    2018 Tacoma TRD Off-Road double cab short bed
    If rear facing, the ladder could go into the bed, right? Or would that be too slippery?
  3. Mar 12, 2019 at 10:53 AM
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    This was what I was going to suggest. Pretty sure alot of ladders have rubber feet which shouldn't slide too much.
  4. Mar 12, 2019 at 11:26 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I made the assumption the typical reason for the cab-mounted would be so that there can be stuff in the bed too but if there's no reason it wouldn't work with an empty or cleaned-up bed. The pivot is as the top so it's not going to slide anywhere assuming it's locked out.
  5. Mar 12, 2019 at 11:51 AM
    18CementTaco
    Cool. Mounting it to a Prinsu. I like the cleaner look of a cab rack and security hard tonneau while driving - and while stopped. So considering my options.
  6. Mar 12, 2019 at 11:54 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Hey, I was there too! So much for a warm weather escape...
  7. Mar 12, 2019 at 12:40 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I think the tonneau makes it more of a PITA because while you'd barely need the ladder for the tent, you'd have to climb onto the tonneau to get into the tent.
    Gunshot-6A likes this.
  8. Mar 12, 2019 at 6:52 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    The ladder could rest between the bed and tailgate, or against the tailgate if you leave it closed. Then, you can just leave back part of the tonneau cover open. Most rtt have adjustable ladders. If you mount it this way post pictures. Thank you.
  9. Mar 13, 2019 at 7:05 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Anyone know a good way to dye the orange accents on this tent?
  10. Mar 13, 2019 at 7:12 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
  11. Mar 13, 2019 at 7:36 AM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Not cab, but here's the bed. Don't think you're gonna clear the bed with a cab mounted one
  12. Mar 13, 2019 at 7:38 AM
    MedlinAround
    Cody
    Kentucky
    Hence the sentence above the picture that says "Not Cab, but here's the bed"
  13. Mar 13, 2019 at 7:57 AM
    Gunshot-6A
    Conner
    Everett, WA
    Deploy it backwards over the bed, and have the ladder feet rest in the bed. If you have a telescoping ladder design, you'll be fine.
  14. Mar 13, 2019 at 8:01 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    hoping to buy a new ladder since my sliding ladder was near maxed out on top of the runner.
  15. Mar 13, 2019 at 9:18 AM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    I have a Bed Rack RTT mounting question.
    Are you all mounting it towards cab, middle of bed, closer to tailgate ?
  16. Mar 13, 2019 at 9:21 AM
    iK0NiK
    West
    Columbus, GA
    Middle of the bed. My CVT Mt. Shasta is the same width/length as the bed when closed so I just center it and the bed bars front/back/left/right.
  17. Mar 13, 2019 at 9:22 AM
    Gunshot-6A
    Conner
    Everett, WA
    Forward of middle for me. But that's to clear my mountain bike bars and stuff plus the nature of my bed rack.
    Old pic:
  18. Mar 13, 2019 at 9:31 AM
    JD45535
    Jeff
    I think I will mount up close to cab since I won't need to worry about ladder getting in way of doors. I can keep cooler in the shade of the tent in bed too. Thanks for the input all. I'm stoked to get everything setup and go out on some fun trips!
  19. Mar 13, 2019 at 12:56 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Cab height mounted front of bed center just over the cab for best balance (long bed). Best weight dispersion for your rear suspension by centering it over your back tires.
    Going with something bigger, you're going to need a cab height rack so you can go over the cab a bit but not hang off over the tailgate and improperly support the tent. Also makes it really easy to get to your gear from all around the bed so you don't have to take everything out to get to it (ie. cooler).
  20. Mar 13, 2019 at 1:27 PM
    JD45535
    Jeff
    Here is the rack I will be using.
    I do have a long bed on stock suspension too. If I do end up tossing on 5100s & OME springs is it better to do an AAL and keep overload spring, or replace entire leaf pack with like a Dakar??
    Granted I don't plan to run the tent/rack on the truck 24/7.
    I think rack weight is 70lbs & tent is 125lbs approx.
