*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. May 23, 2019 at 8:00 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I believe 22" over the bed rail will just clear if I remember my measurements correctly. Bed flex might give you an inch or so but because most flex is torsional and the antenna is centered (i.e. on the radius of that twist axis) you shouldn't need more than a couple inches above the antenna even on the safe side. Especially so with a cap which will absorb a lot of that flex.
    Also, if you're weary about hitting, I'm 95% certain the antenna from some Scion FR-S models is a direct replacement. It has a detachable mast so it's about an inch or so shorter but you do lose the Sirius antenna. Plus side if you don't use it is that when you unplug it, the option disappears from the radio.
    nvnv[QUOTED] likes this.
  2. May 23, 2019 at 8:07 AM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Makes sense. I think with my current setup I might have an inch or so. But the torsional flex thing makes sense since the bed and the cab are pretty close together and don’t touch.
  3. May 23, 2019 at 8:07 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    LTDSC[QUOTED] likes this.
  4. May 23, 2019 at 8:09 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    I joined the club this week. Waiting on my bed rack to get finished, but I'm going to borrow some bars to get it mounted. It's a no-name Smittybilt knockoff with a Tepui cover and upgraded mattress. The only problem with it is the cover straps have separated from the floor pan. Anyone know of a place to get the cover straps as a replacement part?
  5. May 23, 2019 at 8:10 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Ill go measure mine later, but i keep a sleeping bag and a pillow in mine (and ones in the past)
  6. May 23, 2019 at 8:10 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Yeah you have a lot more issues hitting things toward the edges of a roof rack or something or you'd have to consider that the tent will come closer toward the front but in that position, I've seen some super low setups and nobody has complained they hit
  7. May 23, 2019 at 8:12 AM
    fatfurious2
    David
    Ashburn, VA
    Why not hang over the bumper on the rear?
  8. May 23, 2019 at 8:15 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    If you can sew, I highly, highly recommend making your own. I'm converting mine to a single, wrap-around strap with Cobra buckles and from what I've seen, it's less stress on the frame because you're not pulling on the edge and you can tighten them down quite a bit more. Sandwiching them between the mounting rail and body will hold them in place and you can use the original mounts as guides to center them by only using the outside screws and inserting a washer to space it out a little.
    Even with the cost of the cobra buckles I'm still coming out cheaper.
    LTDSC and Beretta4x4[QUOTED] like this.
  9. May 23, 2019 at 8:17 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    For me it's the fact these beds are already prone to cracking and that puts a lot of stress on the rear-most part of the rack (and thus, the weakest part of the bed). With a Leitner or Brute Force rack that mounts to the floor I'd do it without hesitation but I've seen beds crack with less weight than a tent chilling 2 feet above the bed.
    fatfurious2[QUOTED] likes this.
  10. May 23, 2019 at 8:21 AM
    Beretta4x4
    Josh
    Temple, TX
    I've thought about making some type of webbing strap with a buckle. That's pretty nifty with the cobra buckles.
    I'm not home right now, but the original straps were riveted to the tent base. That's where they tore, so I'm going to need to either drill out the rivets and re-rivet with the new straps or come up with another fix
  11. May 23, 2019 at 8:21 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    A topper and bedding is a piece of cake in a standard tent but with the low-profile ones that are 7" tall, you only have like 5-5.5" of gap and 4" of that is mattress. You can get bedding into them and compress it all but it's tight. The standard tents have another 4" or so in them.
  12. May 23, 2019 at 8:23 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Ah yeah the Tepui ones have screwed-in brackets. In that case I'd for sure see if you can make your own because rivets will need to be bigger than the original to be snug. Honestly, you don't need the end brackets if you pinch them with the mounting rails... I'm just doing it because it's easy but the rail will provide more than enough force to keep them roughly in place with the weight of the tent on them.
    Beretta4x4[QUOTED] likes this.
  13. May 23, 2019 at 8:27 AM
    Beretta4x4
    Josh
    Temple, TX
    Thanks. Your help gives me a starting point.
  14. May 23, 2019 at 8:37 AM
    nvnv
    Connor
    I’m going to try to hang over the rear a bit but the back door on my shell opens pretty high so I don’t have a ton of room for rear overhang.
  15. May 23, 2019 at 8:49 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i swapped all my straps to the lashing straps linked at the bottom of this page. Ill link again. Highly recommend.
    https://www.amazon.com/dp/B017902W8G
    Not sure why black is no longer an option
    Beretta4x4[QUOTED] and velogeek like this.
  16. May 23, 2019 at 9:12 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I think orange would look pretty sweet... gotta color match your Maxtrax for maximum likes.
    All seriousness though, I have no idea why I didn't think of this and I'm disappointed in myself that I didn't. Cobra buckles will look cool and all but this would have been crazy simpler.
    DannyBFresco and LTDSC[QUOTED] like this.
  17. May 23, 2019 at 9:38 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    they work great too! I had my velcro blow open and come off and slam the side of my 4Runner for a few min until i could safely pull over. So i swapped over to these and it keeps the cover tighter as well.
    Use the buckle on the long side so you can get torque to pull down to tighten.
  18. May 23, 2019 at 11:27 AM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Likes are more important than your silly real world experiences @LTDSC
  19. May 23, 2019 at 4:27 PM
    taco_feevuh
    taco_feevuh SUUUUUUUUUUUUP?!
    Merritt Island, FL
    2018 cement Tacoma TRD OR 4x4 DCSB
    Rci sliders, Trd pro grill, Fox 2.5 fronts, Fox 2.0 rears w/resi, SCS Ray 10’s, Cooper stt pros
    Hmmm...interesting. Might not need extra padding as they say the mattress is 3” now. I have a 10” bed rack and a prinsu and my goal is to keep the tent tucked out of the wind for aerodynamics. I don’t think either tent will be a problem for me. I wish there was a store near me that I could get hands on with it but sadly there isn’t. The rei near me doesn’t stock them. But with their return policy, I can just try it out until I find one that works for me. It seems to be my only option17144B24-EED6-41A3-BFDF-01B23A12C0D7.jpg
    TNToyo79 and E-Paz 732NJ like this.
  20. May 24, 2019 at 5:34 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I run the CBI mid-height rack, and a little more than half of my tent height sticks up above the cab. My gas mileage has been unaffected -- it actually might even help and offset any loss for carrying more weight. It creates a smoother arc over the truck for air to flow. I wouldn't worry about it too much, focus on other features you want.
