*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Jun 7, 2019 at 1:28 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    What's the ladder system on this thing? Does it store in the tent? If so, doesn't that affect closing the lid with too much bedding inside? Also, with clips on both the head and foot end, how awkward is it to close it back up with 1 person?
    Edit* - I see it's one of those hand crank tents for setup. How's the sacrifice of it not being tall enough to sit up in? I think I saw 34" as the tallest part of the tent from mattress to ceiling.
  2. Jun 7, 2019 at 1:35 PM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I don’t have any pics of the ladder but it’s just a two piece telescoping aluminum ladder with hooks on the top that hook on to the edge of the tent. Autohome says you can store it in the tent and it comes with a storage bag but I found it’s easier to just throw it in the bed of the truck.
    The lift mechanism on the Maggiolina series is crank operated so the clips really don’t do much but add some additional pressure to the seal around the edge. Closing it with one person is super easy because you can crank it down until there’s about 6-10” gap and then go around and tuck all the material in then finish cranking it down.
    Blackout14 likes this.
  3. Jun 7, 2019 at 4:04 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    God I love having a bed outlet. Anyone find any alternate hardware they’ve used instead to go in the rails? Bolt stripped it.
  4. Jun 7, 2019 at 4:06 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    08 Lexus GX470 Sport
    Iron Man FCPs, Duratrac 285/70/17, Front Runner Slimline II, HIDs, LEDs, ETCs
    Im surprised you could run that on the stock inverter. The one in the GX is only 100 watts, the tacomas is what, 400?
  5. Jun 7, 2019 at 4:13 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    Yeah I've run an angle grinder off my bed outlet and it kept cutting out.
    Tantaco37 likes this.
  6. Jun 7, 2019 at 4:21 PM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Hmm to my understanding its 100W with the key half turned. But then can provide 400W when you turn on your truck.
    Mine did not cut out at all. Was your truck running when trying to?
  7. Jun 8, 2019 at 4:59 AM
    Irish Lion
    Irish Lion Member
    Jake
    Central NY
    ‘17 TRD OR DCSB
    Student Loans
    Recently purchased this one - rechargeable.
    COMLIFE Portable LED Camping Lantern https://www.amazon.com/dp/B07P7Z1J4B/ref=cm_sw_r_cp_api_i_Gk6-CbG5ZRN0V
  8. Jun 8, 2019 at 6:20 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Tacoma outlet is 100W while moving, 400W while parked (engine running). Anything pulling over 3.5 amps is gonna be sketchy.
  9. Jun 8, 2019 at 12:52 PM
    GoJo
    GoJo Well-Known Member
    Utah
    I use a vice grip to clamp to the exposed portion of the bolt and then ratchet the nut off. I stripped out my slide rail hardware the first day putting the tent on...
  10. Jun 8, 2019 at 5:23 PM
    nickrick78
    nickrick78 Well-Known Member
    Nick
    Pittsburgh PA
    Tacoless for now
    How sturdy are these rooftop tents? It seems they wouldn't be too sturdy being that portable and off the ground.
  11. Jun 8, 2019 at 8:51 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Sturdy enough to make babies and drunk stumble out of in the middle of the night.
  12. Jun 9, 2019 at 4:34 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    A little morning fire for something to do
  13. Jun 9, 2019 at 5:31 AM
    nickrick78
    Nick
    Pittsburgh PA
    Tacoless for now
    Good enough, thanks for the insight. :)
  14. Jun 9, 2019 at 6:36 AM
    fatfurious2
    David
    Ashburn, VA
    No RTT for my Lexus friend though
  15. Jun 9, 2019 at 9:12 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    National Luna touch lights installed.under each side of the tent. Overhead bed lighting complete. 3 brightness levels each in both white and amber. A nice little amount of side light spill-over to the ladder area and also under the awning. Wiring all ran secure under the netting from the tent power line.
    The 2 rear tailgate lights are different cheapie Amazons but I may switch them to these, too.
  16. Jun 9, 2019 at 7:41 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I've used it to run one of the Harbor Freight pancake compressors to air up before. It kept running and never had an issue other than taking more than 45 minutes to air up all 4 tires from 8 psi in the snow.
  17. Jun 10, 2019 at 8:34 AM
    KeystoneGoodie
    KeystoneGoodie Well-Known Member
    Ben
    '09 AxCab with meat shoes and axe handles
    Lots of dollars and no sense...
    Recently joined the ranks of the mobile tent life. Spent a night and counting the days until I can get back in it!
    I need some help though. My girlfriend and I struggled with multiple expletives tossed around getting the thing off the cap of my truck. Add a leaf and let the air out of the air bags. We are both vertically challenged, but not short people. Anyone find a trick or tip to help ease the process. I can't pull into my garage with it on and use the pulley system I've seen. Any help at this point would be greatly appreciated.
    Cheers!
  18. Jun 10, 2019 at 8:34 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    learn more expletives, you'll need 'em.
  19. Jun 10, 2019 at 8:38 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Kubota can help !o_O:thumbsup:
  20. Jun 10, 2019 at 8:51 AM
    fatfurious2
    David
    Ashburn, VA
    some good ideas of unloading/loading in this video, even though it doesnt involve a RTT..
    https://youtu.be/gIJVta2EQqg?t=91
