*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Sep 4, 2019 at 9:38 AM
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    Damn! I have the same rack and am about to use it next weekend. This has me worried about its reliability....
  2. Sep 4, 2019 at 9:48 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    So, ignoring all the KB product fails, I will say this. None of these 'modular racks will have the strength of a tube rack. It's basic engineering. Pound for pound, I tube (round or boxed) will always have the greater strength and by a healthy amount.
  3. Sep 4, 2019 at 10:01 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yeah, sorry about that last post. I realize with your question that I basically left everyone else hanging, hahahahaha. :sorry:
    I'll try to describe the right way to pack up an Exped - but shout if you have questions...
    A few points worth noting as part of this process:
    1. An Exped, at ~80" long is about 18" shorter than the length of the unfolded tent.
    2. The problem point is a very small one - it's right at the "joint" between the two halves of the tent - where the hinge pivots/scissors together as it opens and closes.
    3. The solution requires either 2 people or a bit of coordination and strength, as it entails moving the mattress during the fold/unfold process.
    OK, so those things said, let's talk about closing first, since that will be the first operation you do with an Exped, and because it's easier.
    As you push up half the tent using the ladder, slow down (but continue to support the ladder with one hand) when you're between 90 and 75 degrees to the other half. At this point, you have plenty of access to the center fold of the mattress. Take advantage of the fact that the mattress is 18" shorter than the tent, and push/slide it "forward" (away from the hinge) with your other hand so that you can see the entire hinge, and the ends of the mattress (and your bedding) will be pushed away from the middle and into the corners of the tent. At this point, you'll have plenty of room to store your tent poles on the hinge side, and the hinges won't be pinching the Exped.
    ...and opening...
    Essentially the reverse of closing, as you open the tent, support the half that's folding out using the ladder in one hand. Then, with the other, as the seam/hinge is starting to close, push the mattress up from the bottom so that it is "above" (or at least next to) the hinge. The way the hinge works, it scissors closed as the tent opens, and so ensuring that the matress is out of that scissoring area is your goal here.
  4. Sep 4, 2019 at 12:56 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Brilliant, thanks for that! I never even thought of storing my poles up there, makes more sense than putting them under the rear seat that is not easily accessible.
    turbodb[QUOTED] likes this.
  5. Sep 4, 2019 at 1:43 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Bad ass, thanks for taking the time to make the drawings. I will give this a try. Wish I could like this post more than once.
    Are you using the anticondensation mat with the exped?
  6. Sep 4, 2019 at 4:36 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Hope it helps.
    I do have the anti-condensation mat, which is a bit of a holdover from pre-Exped. I think the air and better insulation in the Exped mean that you don't really need the mat anymore, but I figured it couldn't hurt to keep it.
  7. Sep 4, 2019 at 8:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    My floor has at least four bolt heads sticking up a bit. The bolts are to attach the mounting rails below the floor for the bed rack to attach to. Without the anti-condensation mat, those bolt heads rub the fabric of the exped. While they are not sharp and only protrude a little above the floor, they are another potential wear spot.
  8. Sep 4, 2019 at 9:05 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Interesting point - and a difference between our setups. I wonder if some duct tape (or similar) over those bolts would be enough to keep sharp edges away from the mat. Or, a layer or two of old t-shirt fabric under some duct tape...
  9. Sep 4, 2019 at 9:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe. Couldn't hurt.
  10. Sep 5, 2019 at 3:55 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Pretty sure it's around 30"
    PNW/TRD Steve[QUOTED] likes this.
  11. Sep 5, 2019 at 6:27 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I’ve got the Hi-Vis Overland Crag 4+ and the condensation mat keeps bunching up and not folding up correctly when we open and close the tent. Any suggestions on keeping it flat or not making it move so it folds correctly?
  12. Sep 5, 2019 at 6:32 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Finally joined the RTT club and took it for a spin at Windrock park this past weekend. So much better than a ground tent!
    nftyper, Blackwolf, zippsub9 and 7 others like this.
  13. Sep 5, 2019 at 6:36 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    How congested was Trail 22 with all the overlanders this weekend?
  14. Sep 5, 2019 at 6:46 AM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Not too bad actually! We met a few people that had broke a CV on the trail but we were able to pass. Then @HrBrad8 blew a bead on his so they ended up catching back up to us. Aside from that, just a couple of dirt bikes and SXS's
    saundern likes this.
  15. Sep 5, 2019 at 6:50 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I know you have more pics :cool:
    PvilleJohn[QUOTED] likes this.
  16. Sep 5, 2019 at 7:12 AM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Haha, but of course I do :D
    IMG_2750.jpg IMG_2754.jpg IMG_2722.jpg IMG_2723.jpg IMG_2718.jpg IMG_2717.jpg IMG_2744.jpg IMG_2715.jpg
  17. Sep 5, 2019 at 7:39 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Where you there for ATR?
  18. Sep 5, 2019 at 8:04 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Thank you.
  19. Sep 5, 2019 at 8:28 AM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Kind of lol, all my buddies were but I didn’t get to register in time so I went through Windrock. Wasn’t actually in the event area though. I just camped in the campground and wheeled with them through the day
  20. Sep 5, 2019 at 8:49 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Still trying to find a solution.. any problems with the safety pin?
