*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Oct 7, 2019 at 4:09 PM
    07TacoLA
    07TacoLA Well-Known Member
    Brad
    2007 Tacoma PreRunner DCSB
    Also, link to the tent: https://overlandvehiclesystems.com/...se-with-green-rain-fly-black-cover-universal/
    (I should have gotten a great discount for all this promoting I'm doing, but hey they were a great group of people and have what appears to be (we'll see after many more uses) a great deal on an awesome tent!
  2. Oct 7, 2019 at 4:25 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Get some 1.5" (I think?) lashing straps. Run them all the way around, through the little retainers that hold the original straps to the edge of the frame, and between the rails and tent to hold them in place.
    LTDSC likes this.
  3. Oct 8, 2019 at 7:08 AM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    So i have been having an issue with my CVT Rainier. When i open it up the center portion of the floor along the hinge does not sit inside the groove like it should. it sags. I have been having this issue a lot lately but i dont camp enough do figure it out. I had this issue last weekend and back in May for two trips when the tent is folded up everything looks straight. with some finagling i can get it into the track and make it work but something is not right. do you guys follow what i am saying and has anybody else had this issue??
  4. Oct 8, 2019 at 7:10 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Pics would help but sounds like a bent or loose hinge.
  5. Oct 8, 2019 at 7:13 AM
    Trucko
    2005 Tacoma
    Thanks. i wish i would have gotten one. it is the long tongue and groove that wont set right and only in the middle. I look for a hinge but any other ideas
  6. Oct 8, 2019 at 12:21 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Have you checked with a straight edge? Sounds like it is slightly warped. Might be able to rig something up with your bottle jack to straighten it out.
  7. Oct 8, 2019 at 12:25 PM
    Trucko
    2005 Tacoma
    great idea i will check and let you all know. anybody else have any issue setting there's up
  8. Oct 8, 2019 at 12:30 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    only issues i've seen with the center parts not clicking is a loose hinge unless somehow you've bent the floor.
  9. Oct 8, 2019 at 12:39 PM
    Trucko
    2005 Tacoma
    what hinge should i check first? thanks hope its not a bent floor
  10. Oct 8, 2019 at 12:49 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    The main side hinges. I just check all the bolts and see. Maybe ones slightly loose causing it to drop a bit when opened up. Check the hinge to the floor bolts as well as the actual hinge itself.
  11. Oct 8, 2019 at 1:52 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    So the one I had (Mt. Hood, 74" wide) would do the same thing. To counter it, I would load a little weight inside on the overhanging side and then align the interlocking strip by hand. The wood floor has some flex and I figured that eventually, the fabric would stretch more and allow it to sessile in better without the help.
    LTDSC[QUOTED] likes this.
  12. Oct 8, 2019 at 1:54 PM
    Trucko
    2005 Tacoma
    so in essence on the inside portion of the tent. the part that does not flip over, the stationary side you would weight it down in the middle. am i understanding you correctly? thanks anybody else. wonder if it is a big tent issue
  13. Oct 8, 2019 at 2:01 PM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    No. I would weigh the fold out side with bedding/gear to help it combat the tent fabric that seemed to be holding it back from folding flat and engaging the (aluminum tongue and groove).
    Otherwise, it would get really screwed up once I got in.
    Basically, I could unfold the tent and set the ladder but the only way to get it level and the strip engaged was to hold it there by force.
  14. Oct 9, 2019 at 12:17 AM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Just push up from the center bottom. It will go into place. Or waste your time doing all that other shit
  15. Oct 9, 2019 at 12:43 AM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    For anyone having issues with the terrible mattresses... my buddy added 3 inch foam topper in his Tepui Kukenam 3. He replaced the “Velcro straps” that pull down the tent with actual ratchet straps. Picture below is what he replaced with actual ratchet straps.
    I’ll try to get a picture of his. He just drilled two holes through the strap itself as screwed it back in place where these Velcro straps would go. Allows you to use some foam topping and still be able to close it without difficulty
    4x4Taco09 likes this.
  16. Oct 9, 2019 at 6:08 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Be careful winching too hard on those side mounting points, I've definitely seen them pull out before.
    Once winter rolls around, I'm going to replace the velcro straps with new webbing set up with some of these guys. A little loop at the top point and these should be easy on and off with a better tension and without all the double-D ring and velcro bullshit.
  17. Oct 9, 2019 at 6:36 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Airing out my tent and swapping to winter sleeping bag, now that night temps are in the 40s
    POOLGUY and ready6delta like this.
  18. Oct 9, 2019 at 7:58 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    If you aren't using the annex then I think it doesn't matter which side it opens. User preference. But I have found in the colder months if you use the annex and wanna warm the truck up to get warm or defrost then the exhaust gets into the annex on passenger side. Just something I noticed so I switched mine to open driver side for fall/winter camping.
  19. Oct 9, 2019 at 7:59 AM
    ready6delta
    JACOB
    Airing mine tonight and doing the same with the bags.
    fatfurious2[QUOTED] likes this.
  20. Oct 9, 2019 at 8:12 AM
    ready6delta
    JACOB
    Man I love those bed racks.......If I change my setup this is at the top.
    4x4Taco09[QUOTED] likes this.
