*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Feb 22, 2020 at 6:51 PM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    All good since October.
    RTT 160lbs
    Me 185 + wife+ 2 daughters
    On a Leer shell.
    TRD_Nope[QUOTED] likes this.
  2. Feb 23, 2020 at 2:16 PM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    I know this is gonna get me some grief but for those that use heaters in your tents like I do have you figured out a way to suspend the heater from the bars above? I have the kovea Cupid heater and it’s awesome. Was thinking of suspending a metal sheet(cookie sheet?) with some metal wire. I am not that good at engineering clever ideas though so I thought I would see if anyone smarter than me has solved this idea lready? Thanks!
  3. Feb 23, 2020 at 2:21 PM
    Natenite
    Springfield Mo
    We have the 23zero walkabout 72. It’s big and weighs 160lbs. We are running it with 3 whispbars (until I can change to a rack) which are decently heavy and I haven’t seen any flex or cracking or anything in my old ARE shell. I had the SN ran and it was rated to 300 lbs but the rule of thumb seems to often be that the rating is a quarter of what the actual failure numbers would be. We took it all over some rough roads this last week in Big Bend and I see zero issues. Just my thoughts.
  4. Feb 23, 2020 at 2:26 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Hey, Im new to the rtt world. I just got a SB overlander. The ladders is very very iffy. Are there any replacements for it? Ive been looking at the tepui telescoping ones, but I keep hearing people saying that they end up sticking and not working very well. I will be camping at the beach in this tent often so that may be a problem. What do you guys recommend?
  5. Feb 23, 2020 at 5:34 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I swapped mine out for a Tepui telescoping ladder.
    MountainManGuy and Wixo[QUOTED] like this.
  6. Feb 23, 2020 at 5:39 PM
    TacoDia
    TacoDia Well-Known Member
    St. Louis
    11 DCSB SR5 V6 OME Kit H-Dakars
    I'm not familiar with the SB ladders but they seem very similar to the ladders on ARB tents which I have. I haven't deployed on sand but I would think some sort of base plate would help the sturdiness, maybe have some cotter pins to secure it while deployed. You can always drill your own holes if the ladder extension is usually the same length as well.
    WoodsGhost and Wixo[QUOTED] like this.
  7. Feb 23, 2020 at 6:30 PM
    Wixo
    Hank
    Tint, LED interior
    Do you have pics of where/how it drilled into the tent?
  8. Feb 23, 2020 at 6:30 PM
    Wixo
    Hank
    Tint, LED interior
    Ill explore these options
  9. Feb 23, 2020 at 6:47 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    I used one set of existing mounting holes and drilled a new set as the mounting locations are not exactly the same. Easy swap though.
    Wixo[QUOTED] and PNW/TRD Steve like this.
  10. Feb 24, 2020 at 6:16 AM
    Wixo
    Hank
    Tint, LED interior
    This is great man, thank you
  11. Feb 24, 2020 at 6:35 AM
    Wixo
    Hank
    Tint, LED interior
    Did you buy the ladder and the bracket mounting set, or did the original SB set work with the tepui ladder?
    https://tepui.com/products/ladder-mounting-brackets
  12. Feb 24, 2020 at 7:36 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Hope this can answer your question!
    Spoiler: It talks about static and dynamic loads. I hope you're not driving around with people in the tent lol
    https://youtu.be/G7TY9WjVSJo
  13. Feb 24, 2020 at 8:04 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    What about being on the shell was too tall? I have rack and DB cover as you do now and I'm looking to go to a shell to gain more bed space. My only concern is the tent being too high to be able to stuff it all together to pack it up.
  14. Feb 24, 2020 at 8:10 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Ordered my RTT:yay:
    BYJOSHCOOK likes this.
  15. Feb 24, 2020 at 8:58 AM
    Tacoma-Jack
    Tacoma-Jack Well-Known Member
    Somerville, MA
    2011 Silver Tacoma LB
    Finally joined the crew this weekend! Need to plan my first test night sleeping in it, might be a cold one :)
  16. Feb 24, 2020 at 9:02 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...Each time, as I'd find another turnaround spot, I'd call Ben forward, the steep mountains limiting the distances that even our ham radios would communicate. The entire road was only 1.7 miles long, but it took us nearly 45 minutes to make it to the end - parts of the drive a white-knuckle experience, at least for me.
    The view however - at the mine camp - was incredible.
    You'll want to read all about it in the last part of Death Valley Connections
    Part 4 - Full Circle
    There's more to this story.
    [part 1] [part 2] [part 3] [part 4]​
  17. Feb 24, 2020 at 10:09 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Any chance you have a picture? This is the layout I was thinking. get the 50/50 thing going, and on mine it would be about the same. My only concern is the 55" awnings are so damn tiny if you had it extended without the tent.
  18. Feb 24, 2020 at 10:47 AM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    The new ladder came with the mounting brackets. One bracket lined up and I drilled the holes for the other one.
    I ordered mine through Box Rocket on the forum.
    Wixo[QUOTED] likes this.
  19. Feb 24, 2020 at 10:52 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Not sure I understand your question. But with the tent on the shell, I was too tall to get into my garage or most parking decks. Now that I have the Diamondback set up, the top of the tent is just about the same height as the Prinsu rack so I can fit everywhere again.
    It's also MUCH easier to pack up when it is lower, and its safer to get my dogs in and out.
  20. Feb 24, 2020 at 10:55 AM
    littlefish
    Hudson Valley NY
    I wanted to know basically what you addressed. Right now my tent is on a bed rack and I'm considering going to a shell to get more storage space. But I am hesitant to do so because I think it would be more difficult to pack up. As it is now once I fold the tent up I climb on top of my Diamondback cover and stuff everything in before I put the cover on. Not sure how I would do that if it were all atop a shell and I couldn't climb up there.
